Hello guys, i have a doubt.
i see this code in mysensors.
RelayWithButtonActuator.ino
- DESCRIPTION
- Example sketch for a “light switch” where you can control light or something
- else from both HA controller and a local physical button
- (connected between digital pin 3 and GND).
- This node also works as a repeader for other nodes
http://www.mysensors.org/build/relay
// Enable debug prints to serial monitor
#define MY_DEBUG
// Enable and select radio type attached
#define MY_RADIO_NRF24
//#define MY_RADIO_RFM69
// Enabled repeater feature for this node
#define MY_REPEATER_FEATURE
#include <SPI.h>
#include <MySensors.h>
#include <Bounce2.h>
#define RELAY_PIN 4 // Arduino Digital I/O pin number for relay
#define BUTTON_PIN 3 // Arduino Digital I/O pin number for button
#define CHILD_ID 1 // Id of the sensor child
#define RELAY_ON 1
#define RELAY_OFF 0
Bounce debouncer = Bounce();
int oldValue=0;
bool state;
MyMessage msg(CHILD_ID,V_LIGHT);
void setup()
// Setup the button
pinMode(BUTTON_PIN,INPUT);
// Activate internal pull-up
digitalWrite(BUTTON_PIN,HIGH);
// After setting up the button, setup debouncer
debouncer.attach(BUTTON_PIN);
debouncer.interval(5);
// Make sure relays are off when starting up
digitalWrite(RELAY_PIN, RELAY_OFF);
// Then set relay pins in output mode
pinMode(RELAY_PIN, OUTPUT);
// Set relay to last known state (using eeprom storage)
state = loadState(CHILD_ID);
digitalWrite(RELAY_PIN, state?RELAY_ON:RELAY_OFF);
void presentation() {
// Send the sketch version information to the gateway and Controller
sendSketchInfo(“Relay & Button”, “1.0”);
// Register all sensors to gw (they will be created as child devices)
present(CHILD_ID, S_LIGHT);
- Example on how to asynchronously check for new messages from gw
void loop()
debouncer.update();
// Get the update value
int value = debouncer.read();
if (value != oldValue && value==0) {
send(msg.set(state?false:true), true); // Send new state and request ack back
oldValue = value;
void receive(const MyMessage &message) {
// We only expect one type of message from controller. But we better check anyway.
if (message.isAck()) {
Serial.println(“This is an ack from gateway”);
if (message.type == V_LIGHT) {
// Change relay state
state = message.getBool();
// Store state in eeprom
saveState(CHILD_ID, state);
// Write some debug info
Serial.print("Incoming change for sensor:");
Serial.print(message.sensor);
Serial.print(", New status: ");
Serial.println(message.getBool());
my doubt is:
when i press the button and relay is ON home assistant knows the relays is on and put STATUS ON?
But if I have a button in the home assistant and click OFF … does the relay go off and the status in the home assistant also goes off?
