MySQL Command
Hi, Thanks for the create components. Works very well and opens up a whole new area of possibilities.
One thing that would be good is to allow for calling stored procedures. I have changed my notify.py file to have this line
cursor.callproc(message)
on line 83.
Then I can just put the name of the stored procedure in the message attribute in the service call.
Would be good if there was an option to allow this. Thanks
Dear qrioniclabs,
I run into a collation error, see HA log:
Logger: homeassistant.helpers.script.websocket_api_script
Source: helpers/script.py:526
First occurred: 22:27:35 (1 occurrences)
Last logged: 22:27:35
websocket_api script: Error executing script. Unexpected error for call_service at pos 1: 1273 (HY000): Unknown collation: 'utf8mb4_0900_ai_ci'
  File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 526, in _async_step
    await getattr(self, handler)()
  File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 764, in _async_call_service_step
    response_data = await self._async_run_long_action(
  File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 727, in _async_run_long_action
    return await long_task
  File "/usr/src/homeassistant/homeassistant/core.py", line 2802, in async_call
    response_data = await coro
  File "/usr/src/homeassistant/homeassistant/core.py", line 2845, in _execute_service
    return await target(service_call)
  File "/usr/src/homeassistant/homeassistant/components/notify/legacy.py", line 256, in _async_notify_message_service
    await self.async_send_message(**kwargs)
  File "/usr/src/homeassistant/homeassistant/components/notify/legacy.py", line 236, in async_send_message
    await self.hass.async_add_executor_job(
  File "/usr/local/lib/python3.12/concurrent/futures/thread.py", line 58, in run
  File "/config/custom_components/mysql_command/notify.py", line 74, in send_message
    cnx = mysql.connector.connect(
  File "/usr/local/lib/python3.12/site-packages/mysql/connector/pooling.py", line 323, in connect
    return MySQLConnection(*args, **kwargs)
  File "/usr/local/lib/python3.12/site-packages/mysql/connector/connection.py", line 179, in __init__
    self.connect(**kwargs)
  File "/usr/local/lib/python3.12/site-packages/mysql/connector/abstracts.py", line 1438, in connect
    self._post_connection()
  File "/usr/local/lib/python3.12/site-packages/mysql/connector/abstracts.py", line 1378, in _post_connection
    self.set_charset_collation(charset=self._charset_id)
  File "/usr/local/lib/python3.12/site-packages/mysql/connector/abstracts.py", line 1353, in set_charset_collation
    self._execute_query(f"SET NAMES '{charset_name}' COLLATE '{collation_name}'")
  File "/usr/local/lib/python3.12/site-packages/mysql/connector/connection.py", line 1333, in _execute_query
    self.cmd_query(query)
  File "/usr/local/lib/python3.12/site-packages/mysql/connector/opentelemetry/context_propagation.py", line 97, in wrapper
    return method(cnx, *args, **kwargs)
  File "/usr/local/lib/python3.12/site-packages/mysql/connector/connection.py", line 872, in cmd_query
    result = self._handle_result(self._send_cmd(ServerCmd.QUERY, query))
  File "/usr/local/lib/python3.12/site-packages/mysql/connector/connection.py", line 648, in _handle_result
    raise get_exception(packet)
mysql.connector.errors.DatabaseError: 1273 (HY000): Unknown collation: 'utf8mb4_0900_ai_ci'
as i did it with the query component.
Would it be possible to you to add such a parameter to your component?
after some googling, probably the library generating the issue*.
*edit. in the case of MariaDB. So the improvement would help those with MariaDB.
With MySQL, the component is sound.
Thank you in advance.
I have the same issue too :frowning:
Working solution :
Go into : custom_components/mysql_command/notify.py
Find the function send_message and add two lines :
        charset='utf8mb4',
        collation='utf8mb4_unicode_ci',
Before :
    def send_message(self, message="", **kwargs):
        """Send a message as command to a MySQL server."""
            host=self.host,
            port=self.port,
            user=self.username,
            password=self.password,
            database=self.db,
            connect_timeout=self.timeout,
The fix :
            host=self.host,
            port=self.port,
            user=self.username,
            database=self.db,
            charset='utf8mb4',
Restart HA and it should work.
