Hi everyone,
I’ve had a Vaillant aroTHERM Plus since June and would like to display various metrics in Home Assistant. Controlling the system isn’t on the table right now. Currently, the MyVaillant app is set up and working. I’ve also submitted the myVAILLANT integration, and it’s basically working so far. Unfortunately, I’m having issues with the API calls. The temperatures are “only” queried twice an hour. I think a short delay causes the API calls to the Vaillant Cloud to be blocked. I only retrieve the energy data once an hour, and yet the efficiency data in HA still shows as “not available.” After restarting HA, it works briefly.
Does anyone have any tips for me regarding the settings in the myVAILLANT integration? Additionally, I’d actually prefer not to be dependent on the Vaillant Cloud and the API calls. That’s why I’m thinking—since the VR940f internet module is also available—of using the eebus interface to retrieve the values locally. However, I have absolutely no experience with eebus, ebus, or Modbus. According to my online research, EVCC could read the data, but the EVCC documentation only lists SensoNET (API). Can I read data from the aroTHERM heat pump using EVCC? Is anyone here using this? What data can I retrieve?
I was thinking of installing EVCC as an LXC container on Proxmox and then sending the data to HA via MQTT. Would that approach be feasible?
Thanks for your help and support.
Translated with DeepL.com (free version)
