SECURITY CONTROL PANEL
Introduced in release 0.101.0
Alexa will require a 4 digit voice personal identification number (PIN) for disarming. Configure a 4 digit PIN in the Alexa app, or use an existing 4 digit PIN code
configured for the security_control_panel.
To use the exiting code
configured for the security_control_panel the code
must be 4 digits and the code_format
attribute must be FORMAT_NUMBER
. After discovery the Alexa app will offer the ability to use the existing code
, or create an additional 4 digit PIN to use with Alexa. The existing code
is never communicated to Alexa from Home Assistant. During disarming, Alexa will ask for a PIN. The PIN spoken to Alexa is relayed to Home Assistant and passed to the alarm_control_panel.alarm_disarm
service. If the alarm_control_panel.alarm_disarm
service fails for any reason, it is assumed the PIN was incorrect and reported to Alexa as an invalid PIN.
Alexa does not support arming with voice PIN at this time. Therefore if the security_control_panel requires a code
for arming or the code_arm_required
attribute is true
the entity will not be exposed during discovery. Note that code_arm_required
may default to true
even if the integration does not support it. Use the Entity Customization Tool in the Home Assistant Configuration and override code_arm_required
to false
to expose your security_control_panel during discovery.
security_control_panel state must be disarmed
before arming. Alexa does not support switching from one armed state to another without first disarming. e.g. switching from armed_away
to armed_home
The security_control_panel state armed_custom_bypass
isn’t supported by Alexa and is treated as armed_home
Security Panel Utterances
Alexa, arm my home in away mode.
Alexa, arm my home.
Alexa, disarm my home.
Alexa, is my home armed?
COVER
Introduced in release 0.104.0
In addition to using on/off utterances. Home Assistant configures covers with semantics that allow you to say “raise”, “lower”, “open”, and “close” for covers.
Open/Close Utterances
Alexa, open the blinds.
Alexa, close the curtain.
Alexa, lower the shades.
Alexa, raise the roof!
Covers with a device_class
of garage
will enable the Open by Voice option in the Alexa app.
Covers that SUPPORT_SET_POSITION
can be controlled using percentages.
Set Cover Position Utterances
Alexa, set the shades to thirty percent.
Alexa, increase shades by ten percent.
Alexa, decrease shades by twenty percent.
