I know Naim products are not mass market oriented. I haven’t found any official integration for Naim. I wonder if anybody has done something with a Naim Uniti Atom and home assistant. I currently own a Marantz player and it works well with HA, but I have set my eyes on this beast by Naim, and I wonder to what extend i can have my hopes high and expect an integration down the road.
I have a Unity Star and a Muso2. i can see them as ‘DLNA Digital Media Renderer’ and adjust the volume, that’s about it. Not sure I feel this is a high priority TBH.
Thanks, this information helps a lot in deciding whether to get one. There is not a lot to find re the Naim Uniti and how it integrates so hopefully it will be possible for you to help out on some additional questions I had.
Is it really just the volume you can adjust or do the Uniti and Muso support any other services from the HA media player? E.g. would it be possible to play media like an internet radio station or a local track and to turn on or off the device from Home Assistant?
I’ve written a custom component media player for the naim atom. I use it myself on my naim atom. It just talks directly to the API and also listens on the broadcast port 4545. Many kudos to the author of this repo here for starting place. I’m in the process of releasing it to HACS.
Thank you for writing an integration! HA tells me, I have to add it manually to the configuration.yaml where you write “follow the config flow”. Am I doing something wrong? Or what exactly has to been written into the yaml-file? Thanks and best regards!
