It seems that a recent update has quite some Impact on the way devices are added to HA. I had one YAML file and just created a BIN file and flash my new device quickly using the online flasher. But nowadays, this is no longer accepted by HA.
Getting the following message: "Name conflict The name xxx is already being used by another device: xxx (MAC address: xxx)
To continue, please choose one of the following options:
Migrate configuration to new device: If this is a replacement, migrate the existing settings to the new device (xxx). Overwrite the existing configuration: If this is not a replacement, delete the old configuration for xxx and use the new device instead."
Anyone having the same issue or a way to fix this with keeping one YAML? Why this change when it worked perfect. Never had an issue with filtering based on MAC.
Thanks.
