NameCheap SSL Cert Upload?
I have a Comodo Positive SSL cert this morning and it’s asking me to upload the txt file. Having a Duckdns address, I don’t know what to do to get this file accessable to them to verify. Could anyone assist?
Hi, I have the same problem, here… Did you find a way to do it ?
Not yet. I still have my SSL and not using it. Now that I’m using docker and Hass, maybe I can get it to work
Okay, thanks. If I ever find a solution, I will post here.
Can you explain what steps did you take so far and when you got stuck?
I installed one month ago new certificate from NamecheapDNS / Comodo and it works for me but I needed the work a lot to make it work…
I generated the requested files with OpenSSL, then I created a DCV by giving the CSR code to NameCheap and I am to the point where I need to activate the certificate, with one of the three methods: e-mail, HTTP, or DNS.
I done it over HTTP, download the file and placed in under www folder of the hass config
Did you replicate the url, like “config/www/.well-known/pki-validation/file.txt” or did you just put the file in ‘www’ ?
full path (with well known)
I already tried that and I’m stuck… What was the next step for you ?
can you access that URL from outside your network?
