Hi, I have a question that probably has a pretty obvious answer but I can’t figure it out. The question is about how to name esphome entities in HA. I have an esphome set up with a ld2410 and my problem is the way to name the entity in home assistant as it repeats twice the entity name.
For example any entity (it happens with all of them) is sensor.esp_dummy_esp_dummy_connected_bssid. As you can see “esp_dummy” is repeated twice and my intention is that sensor.esp_dummy_connected_bssid only appears once.
In esphome i have this
substitutions:
devicename: esp-dummy
bssid:
I don’t know where you get that the chain is repeated twice at the HA level.
Regards
