Native HA Backups - Hanging on Uploading to locations
The native HA Backups is Hanging on Uploading to locations.
  • This is the second time this has happened to me in the past few months.
  • While this is occurring I am unable to restart home assistant
Observations and Settings
  • Home Assistant Cloud is my only external location
  • 1.4GB X 3 = 4.2GB this should be within the 5GB limit
  • I do a daily backup with retention of 3 and System Optimal time between 06:45 and 07:45.
  • The naming of the automatic backups seem to be the same (based on HA release version) I am unsure if this naming convection is causing some sort of error. A date/time code would be nice in the name.
  • I do run Google Cloud Back-ups daily as well at 4:00am
  • The timings do not seem to be overlapping
STEPS THAT FAILED
  • Wait until the backup times out and come up with Failed, (Today this was 7hrs Ago)
  • There does not seem to be a backup.stop command
  • ‘ha supervisor reset’ this did not work
STEPS THAT WORKED
1. Identify the stuck backup
Go to:
Settings → System → Backups
Look for a backup in progress or labeled Creating / Uploading.
2. Delete or force-remove it
  • Try UI delete → THIS WORKED FOR ME
  • If it fails: Run in SSH or Terminal add-on:
ha backups list
Find the slug of the stuck backup and remove:
ha backups remove <slug>
3. Restart Home Assistant Core (if backup job is ghosted)
ha core restart
This flushes any stuck backup locks.
3. Check Backup has failed
Go to:
4. Check Restart is Working
Go to:
Developer Tools → YAML → CHECK CONFIGURATION → RESTART → RESTART
5. Should be All OK
Did you see the note that HA cloud only stores the latest backup? For those from my era, it is like Highlander: There can be only one. My backup is bigger though, it never failed on me.
The is also a Google integration for native backup. I use that one now, not the addon. EDIT, I’m mistaking, I dropped Google. Could it be, even without overlap, they are somehow interfering? I use HA cloud, Samba and Onedrive, all with the new HA backup system It takes a long time, but they have not failed on me yet.
Another thing I was wondering, could there be something else on your lan be messing with the upload? As I said, it can take quite long.
I remember all 3 original Highlander movies well.
I did not realise it only saves one, but I do have full generational back-ups set in Google Cloud. Do you do daily backups @Edwin_D?
Generally my backups are functioning fine it is just these two edge cases.
  • This would suggest it is not a network setting in my Unifi Dream Wall
  • Unsure if file names being the same is an issue?
I am not sure if anything is interfering to be quite honest.
  • This is the second time this has happened since I enabled HA Backups.
  • My Unifi Dream Wall shows no irregularities when the backup occurred.
  • Small yellow blip is high latency on Thursday Evening.
I’m doing dailies to 4 locations, two encrypted, two not encrypted, system optimal time.
I am not alone with this issue, even though it seems rare.
It is good to know you can help people get unstuck, better if we can identify what triggers the problem.
Yes definitely, I looked everywhere. I could not see any obvious errors in logs. Do you have anywhere you would suggest looking? Especially if I have the issue again.
SUPERVISOR LOGS
2025-07-20 12:09:43.320 INFO (MainThread) [supervisor.backups.manager] Found 5 backup files
2025-07-20 12:09:43.349 ERROR (MainThread) [supervisor.backups.backup] Can't read backup tarfile /data/backup/31e48303.tar: "filename './backup.json' not found"
2025-07-20 12:09:43.374 INFO (MainThread) [supervisor.discovery] Loaded 1 messages
2025-07-20 12:09:43.374 INFO (MainThread) [supervisor.ingress] Loaded 12 ingress sessions
e[32m2025-07-20 12:27:26.614 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation completee[0m
e[32m2025-07-20 12:27:27.411 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant Core state changed to APIState(core_state='NOT_RUNNING', offline_db_migration=False)e[0m
e[32m2025-07-20 12:27:57.914 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant Core state changed to APIState(core_state='RUNNING', offline_db_migration=False)e[0m
e[32m2025-07-20 12:27:57.915 INFO (MainThread) [supervisor.homeassistant.core] Detect a running Home Assistant instancee[0m
e[31m2025-07-20 10:44:01.588 ERROR (MainThread) [asyncio] Task exception was never retrieved
future: <Task finished name='Task-241611' coro=<_websocket_forward() done, defined at /usr/src/supervisor/supervisor/api/ingress.py:380> exception=ClientConnectionResetError('Cannot write to closing transport')>
  File "/usr/src/supervisor/supervisor/api/ingress.py", line 387, in _websocket_forward
    await ws_to.send_bytes(msg.data)
  File "/usr/local/lib/python3.13/site-packages/aiohttp/client_ws.py", line 252, in send_bytes
    await self._writer.send_frame(data, WSMsgType.BINARY, compress=compress)
  File "/usr/local/lib/python3.13/site-packages/aiohttp/_websocket/writer.py", line 72, in send_frame
    raise ClientConnectionResetError("Cannot write to closing transport")
aiohttp.client_exceptions.ClientConnectionResetError: Cannot write to closing transporte[0m
e[32m2025-07-20 11:00:05.356 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state runninge[0m
e[32m2025-07-20 04:01:46.256 INFO (MainThread) [supervisor.api.backups] Downloading backup 6b5735bbe[0m
e[32m2025-07-20 04:01:48.613 INFO (MainThread) [supervisor.backups.manager] Found 5 backup filese[0m
e[31m2025-07-20 04:01:48.646 ERROR (MainThread) [supervisor.backups.backup] Can't read backup tarfile /data/backup/31e48303.tar: "filename './backup.json' not found"e[0m
e[32m2025-07-20 04:03:29.415 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API tokene[0m
e[31m2025-07-19 08:01:48.587 ERROR (MainThread) [supervisor.backups.backup] Can't read backup tarfile /data/backup/31e48303.tar: "filename './backup.json' not found"e[0m
e[33m2025-07-19 03:08:00.026 WARNING (sentry-sdk.BackgroundWorker) [urllib3.connectionpool] Retrying (Retry(total=2, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NameResolutionError("<urllib3.connection.HTTPSConnection object at 0xffff7c454e10>: Failed to resolve 'o427061.ingest.sentry.io' ([Errno -3] Try again)")': /api/5370612/envelope/e[0m
e[33m2025-07-19 03:08:05.037 WARNING (sentry-sdk.BackgroundWorker) [urllib3.connectionpool] Retrying (Retry(total=1, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NameResolutionError("<urllib3.connection.HTTPSConnection object at 0xffff7c4565d0>: Failed to resolve 'o427061.ingest.sentry.io' ([Errno -3] Try again)")': /api/5370612/envelope/e[0m
e[33m2025-07-19 03:08:10.041 WARNING (sentry-sdk.BackgroundWorker) [urllib3.connectionpool] Retrying (Retry(total=0, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NameResolutionError("<urllib3.connection.HTTPSConnection object at 0xffff7c454050>: Failed to resolve 'o427061.ingest.sentry.io' ([Errno -3] Try again)")': /api/5370612/envelope/e[0m
[32m2025-07-18 08:14:07.128 INFO (MainThread) [supervisor.resolution.check] System checks completee[0m
e[32m2025-07-18 08:14:07.129 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state runninge[0m
e[32m2025-07-18 08:14:07.810 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation completee[0m
e[32m2025-07-18 08:14:07.810 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state runninge[0m
e[32m2025-07-18 08:14:07.811 INFO (MainThread) [supervisor.resolution.fixup] System autofix completee[0m
e[32m2025-07-18 08:17:29.944 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API tokene[0m
e[33m2025-07-18 08:27:48.923 WARNING (MainThread) [supervisor.api.proxy] [a0d7b954_vscode] Error WebSocket message received while proxying: ServerTimeoutError('No PONG received after 15.0 seconds')e[0m
e[33m2025-07-18 08:27:48.737 WARNING (MainThread) [supervisor.api.proxy] [a0d7b954_vscode] Error WebSocket message received while proxying: ServerTimeoutError('No PONG received after 15.0 seconds')e[0m
e[33m2025-07-18 08:27:48.870 WARNING (MainThread) [supervisor.api.proxy] [a0d7b954_vscode] Error WebSocket message received while proxying: ServerTimeoutError('No PONG received after 15.0 seconds')e[0m
e[33m2025-07-18 08:27:48.871 WARNING (MainThread) [supervisor.api.proxy] [a0d7b954_vscode] Error WebSocket message received while proxying: ServerTimeoutError('No PONG received after 15.0 seconds')e[0m
e[33m2025-07-18 08:27:48.872 WARNING (MainThread) [supervisor.api.proxy] [a0d7b954_vscode] Error WebSocket message received while proxying: ServerTimeoutError('No PONG received after 15.0 seconds')e[0m
e[33m2025-07-18 08:27:48.873 WARNING (MainThread) [supervisor.api.proxy] [a0d7b954_vscode] Error WebSocket message received while proxying: ServerTimeoutError('No PONG received after 15.0 seconds')e[0m
e[33m2025-07-18 08:27:48.875 WARNING (MainThread) [supervisor.api.proxy] [a0d7b954_vscode] Error WebSocket message received while proxying: ServerTimeoutError('No PONG received after 15.0 seconds')e[0m
e[33m2025-07-18 08:27:48.876 WARNING (MainThread) [supervisor.api.proxy] [a0d7b954_vscode] Error WebSocket message received while proxying: ServerTimeoutError('No PONG received after 15.0 seconds')e[0m
e[33m2025-07-18 08:27:49.525 WARNING (MainThread) [supervisor.misc.tasks] Watchdog missed an Home Assistant Core API response.e[0m
e[32m2025-07-18 08:27:54.681 INFO (MainThread) [supervisor.api.proxy] [a0d7b954_vscode] Home Assistant WebSocket API closede[0m
e[32m2025-07-18 08:27:54.790 INFO (MainThread) [supervisor.api.proxy] [a0d7b954_vscode] Home Assistant WebSocket API closede[0m
e[32m2025-07-18 08:27:54.791 INFO (MainThread) [supervisor.api.proxy] [a0d7b954_vscode] Home Assistant WebSocket API closede[0m
e[32m2025-07-18 08:27:54.793 INFO (MainThread) [supervisor.api.proxy] [a0d7b954_vscode] Home Assistant WebSocket API closede[0m
e[32m2025-07-18 08:27:54.794 INFO (MainThread) [supervisor.api.proxy] [a0d7b954_vscode] Home Assistant WebSocket API closede[0m
e[32m2025-07-18 08:27:54.796 INFO (MainThread) [supervisor.api.proxy] [a0d7b954_vscode] Home Assistant WebSocket API closede[0m
e[32m2025-07-18 08:27:54.800 INFO (MainThread) [supervisor.api.proxy] [a0d7b954_vscode] Home Assistant WebSocket API closede[0m
e[32m2025-07-18 08:27:54.801 INFO (MainThread) [supervisor.api.proxy] [a0d7b954_vscode] Home Assistant WebSocket API closede[0m
e[33m2025-07-18 08:27:54.831 WARNING (MainThread) [supervisor.misc.tasks] Watchdog/Application found a problem with observer plugin!e[0m
e[32m2025-07-18 08:27:55.591 INFO (SyncWorker_1) [supervisor.docker.manager] Stopping hassio_observer applicatione[0m
e[32m2025-07-18 08:27:57.533 INFO (SyncWorker_1) [supervisor.docker.manager] Cleaning hassio_observer applicatione[0m
e[32m2025-07-18 08:27:57.785 INFO (MainThread) [supervisor.plugins.observer] Starting observer plugine[0m
e[32m2025-07-18 08:27:59.030 INFO (MainThread) [supervisor.docker.observer] Starting Observer ghcr.io/home-assistant/aarch64-hassio-observer with version 2025.02.0 - 172.30.32.6e[0m
e[32m2025-07-18 08:28:04.617 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API request initializee[0m
e[32m2025-07-18 08:28:04.696 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API request initializee[0m
e[32m2025-07-18 08:28:04.709 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API request initializee[0m
e[32m2025-07-18 08:28:04.721 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API request initializee[0m
e[32m2025-07-18 08:28:04.727 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API request initializee[0m
e[32m2025-07-18 08:28:04.736 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API request initializee[0m
e[32m2025-07-18 08:28:04.740 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API request initializee[0m
e[32m2025-07-18 08:28:04.832 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API request initializee[0m
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
cont-init: info: running /etc/cont-init.d/udev.sh
[22:33:07] INFO: e[32mUsing udev information from hoste[0m
cont-init: info: /etc/cont-init.d/udev.sh exited 0
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
services-up: info: copying legacy longrun supervisor (no readiness notification)
services-up: info: copying legacy longrun watchdog (no readiness notification)
[22:33:07] INFO: e[32mStarting local supervisor watchdog...e[0m
s6-rc: info: service legacy-services successfully started
e[32m2025-07-17 22:33:10.233 INFO (MainThread) [__main__] Initializing Supervisor setupe[0m
e[32m2025-07-16 18:12:25.306 INFO (MainThread) [supervisor.docker.observer] Starting Observer ghcr.io/home-assistant/aarch64-hassio-observer with version 2025.02.0 - 172.30.32.6e[0m
e[31m2025-07-16 18:12:25.779 ERROR (MainThread) [supervisor.homeassistant.api] Error on call http://172.30.32.1:8123/api/states/binary_sensor.backups_stale: [Errno None] Can not write request body for http://172.30.32.1:8123/api/states/binary_sensor.backups_stalee[0m
e[31m2025-07-16 18:12:25.780 ERROR (MainThread) [supervisor.api.proxy] Error on API for request states/binary_sensor.backups_stalee[0m
e[32m2025-07-16 18:12:25.807 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API request initializee[0m
e[31m2025-07-16 18:12:25.850 ERROR (MainThread) [aiohttp.server] Error handling request from 172.30.33.3
  File "/usr/local/lib/python3.13/site-packages/aiohttp/web_protocol.py", line 510, in _handle_request
    resp = await request_handler(request)
  File "/usr/local/lib/python3.13/site-packages/sentry_sdk/integrations/aiohttp.py", line 157, in sentry_app_handle
    reraise(*_capture_exception())
  File "/usr/local/lib/python3.13/site-packages/sentry_sdk/utils.py", line 1746, in reraise
    raise value
  File "/usr/local/lib/python3.13/site-packages/sentry_sdk/integrations/aiohttp.py", line 140, in sentry_app_handle
    response = await old_handle(self, request)
  File "/usr/local/lib/python3.13/site-packages/aiohttp/web_app.py", line 569, in _handle
    return await handler(request)
  File "/usr/local/lib/python3.13/site-packages/aiohttp/web_middlewares.py", line 117, in impl
  File "/usr/src/supervisor/supervisor/api/middleware/security.py", line 198, in block_bad_requests
  File "/usr/src/supervisor/supervisor/api/middleware/security.py", line 208, in system_validation
  File "/usr/src/supervisor/supervisor/api/middleware/security.py", line 225, in token_validation
  File "/usr/src/supervisor/supervisor/api/middleware/security.py", line 289, in core_proxy
  File "/usr/src/supervisor/supervisor/api/proxy.py", line 227, in websocket
    await server.prepare(request)
  File "/usr/local/lib/python3.13/site-packages/aiohttp/web_ws.py", line 214, in prepare
    protocol, writer = self._pre_start(request)
  File "/usr/local/lib/python3.13/site-packages/aiohttp/web_ws.py", line 317, in _pre_start
    assert transport is not None
AssertionErrore[0m
e[32m2025-07-16 14:15:41.367 INFO (MainThread) [supervisor.backups.manager] Found 4 backup filese[0m
e[31m2025-07-16 14:15:41.388 ERROR (MainThread) [supervisor.backups.backup] Can't read backup tarfile /data/backup/31e48303.tar: "filename './backup.json' not found"e[0m
e[32m2025-07-16 14:15:50.194 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API tokene[0m
e[32m2025-07-15 18:13:33.589 INFO (MainThread) [supervisor.backups.manager] Found 4 backup filese[0m
e[31m2025-07-15 18:13:33.613 ERROR (MainThread) [supervisor.backups.backup] Can't read backup tarfile /data/backup/31e48303.tar: "filename './backup.json' not found"e[0m
e[32m2025-07-15 18:13:33.629 INFO (MainThread) [supervisor.discovery] Loaded 1 messagese[0m
e[31m2025-07-15 08:17:28.547 ERROR (MainThread) [supervisor.backups.backup] Can't read backup tarfile /data/backup/31e48303.tar: "filename './backup.json' not found"e[0m
e[31m2025-07-13 16:17:28.438 ERROR (MainThread) [supervisor.backups.backup] Can't read backup tarfile /data/backup/31e48303.tar: "filename './backup.json' not found"e[0m
e[33m2025-07-12 21:23:17.872 WARNING (sentry-sdk.BackgroundWorker) [urllib3.connectionpool] Retrying (Retry(total=2, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NameResolutionError("<urllib3.connection.HTTPSConnection object at 0xffff954af390>: Failed to resolve 'o427061.ingest.sentry.io' ([Errno -3] Try again)")': /api/5370612/envelope/e[0m
e[33m2025-07-12 21:23:22.877 WARNING (sentry-sdk.BackgroundWorker) [urllib3.connectionpool] Retrying (Retry(total=1, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NameResolutionError("<urllib3.connection.HTTPSConnection object at 0xffff954af750>: Failed to resolve 'o427061.ingest.sentry.io' ([Errno -3] Try again)")': /api/5370612/envelope/e[0m
e[33m2025-07-12 21:23:27.882 WARNING (sentry-sdk.BackgroundWorker) [urllib3.connectionpool] Retrying (Retry(total=0, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NameResolutionError("<urllib3.connection.HTTPSConnection object at 0xffff954aee90>: Failed to resolve 'o427061.ingest.sentry.io' ([Errno -3] Try again)")': /api/5370612/envelope/e[0m
e[32m2025-07-12 21:24:17.162 INFO (MainThread) [supervisor.host.info] Updating local host informatione[0m
e[33m2025-07-12 21:24:17.873 WARNING (sentry-sdk.BackgroundWorker) [urllib3.connectionpool] Retrying (Retry(total=2, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NameResolutionError("<urllib3.connection.HTTPSConnection object at 0xffff954afb10>: Failed to resolve 'o427061.ingest.sentry.io' ([Errno -3] Try again)")': /api/5370612/envelope/e[0m
e[32m2025-07-12 21:24:17.937 INFO (MainThread) [supervisor.host.services] Updating service informatione[0m
e[32m2025-07-12 21:24:17.951 INFO (MainThread) [supervisor.host.network] Updating local network informatione[0m
e[32m2025-07-12 21:24:18.149 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio informatione[0m
e[32m2025-07-12 21:24:18.160 INFO (MainThread) [supervisor.host.manager] Host information reload completede[0m
e[33m2025-07-12 21:24:22.878 WARNING (sentry-sdk.BackgroundWorker) [urllib3.connectionpool] Retrying (Retry(total=1, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NameResolutionError("<urllib3.connection.HTTPSConnection object at 0xffff954ada90>: Failed to resolve 'o427061.ingest.sentry.io' ([Errno -3] Try again)")': /api/5370612/envelope/e[0m
e[33m2025-07-12 21:24:27.883 WARNING (sentry-sdk.BackgroundWorker) [urllib3.connectionpool] Retrying (Retry(total=0, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NameResolutionError("<urllib3.connection.HTTPSConnection object at 0xffffa6aef4d0>: Failed to resolve 'o427061.ingest.sentry.io' ([Errno -3] Try again)")': /api/5370612/envelope/e[0m
e[33m2025-07-12 21:17:42.553 WARNING (MainThread) [supervisor.jobs] 'GitRepo.pull' blocked from execution, no supervisor internet connectione[0m
e[33m2025-07-12 21:17:52.679 WARNING (MainThread) [supervisor.jobs] 'GitRepo.pull' blocked from execution, no supervisor internet connectione[0m
e[31m2025-07-12 21:17:52.681 ERROR (MainThread) [supervisor.store] Could not reload repository 69755fa6 due to StoreJobError("'GitRepo.pull' blocked from execution, no supervisor internet connection")e[0m
e[31m2025-07-12 21:17:52.682 ERROR (MainThread) [supervisor.store] Could not reload repository 8bce8ef4 due to StoreJobError("'GitRepo.pull' blocked from execution, no supervisor internet connection")e[0m
e[31m2025-07-12 21:17:52.682 ERROR (MainThread) [supervisor.store] Could not reload repository 68e874ae due to StoreJobError("'GitRepo.pull' blocked from execution, no supervisor internet connection")e[0m
e[33m2025-07-12 21:18:17.871 WARNING (sentry-sdk.BackgroundWorker) [urllib3.connectionpool] Retrying (Retry(total=2, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NameResolutionError("<urllib3.connection.HTTPSConnection object at 0xffffa6aef4d0>: Failed to resolve 'o427061.ingest.sentry.io' ([Errno -3] Try again)")': /api/5370612/envelope/e[0m
e[33m2025-07-12 21:15:17.871 WARNING (sentry-sdk.BackgroundWorker) [urllib3.connectionpool] Retrying (Retry(total=2, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NameResolutionError("<urllib3.connection.HTTPSConnection object at 0xffffa1b42c10>: Failed to resolve 'o427061.ingest.sentry.io' ([Errno -3] Try again)")': /api/5370612/envelope/e[0m
e[33m2025-07-12 21:15:22.876 WARNING (sentry-sdk.BackgroundWorker) [urllib3.connectionpool] Retrying (Retry(total=1, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NameResolutionError("<urllib3.connection.HTTPSConnection object at 0xffff954ae0d0>: Failed to resolve 'o427061.ingest.sentry.io' ([Errno -3] Try again)")': /api/5370612/envelope/e[0m
e[32m2025-07-12 21:15:24.026 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state runninge[0m
e[32m2025-07-12 21:15:24.026 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_failed/dns_servere[0m
e[33m2025-07-12 21:15:27.878 WARNING (sentry-sdk.BackgroundWorker) [urllib3.connectionpool] Retrying (Retry(total=0, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NameResolutionError("<urllib3.connection.HTTPSConnection object at 0xffff954ad6d0>: Failed to resolve 'o427061.ingest.sentry.io' ([Errno -3] Try again)")': /api/5370612/envelope/e[0m
e[32m2025-07-12 21:15:30.680 INFO (MainThread) [supervisor.jobs] 'CheckDNSServer.run_check' blocked from execution, no supervisor internet connectione[0m
e[32m2025-07-12 21:15:30.680 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_ipv6_error/dns_servere[0m
e[32m2025-07-12 21:15:30.680 INFO (MainThread) [supervisor.jobs] 'CheckDNSServerIPv6.run_check' blocked from execution, no supervisor internet connectione[0m
e[32m2025-07-12 21:15:30.681 INFO (MainThread) [supervisor.resolution.checks.base] Run check for ipv4_connection_problem/systeme[0m
e[32m2025-07-12 21:15:30.681 INFO (MainThread) [supervisor.resolution.checks.base] Run check for security/coree[0m
e[32m2025-07-12 21:15:30.681 INFO (MainThread) [supervisor.resolution.checks.base] Run check for multiple_data_disks/systeme[0m
e[32m2025-07-12 21:15:30.682 INFO (MainThread) [supervisor.resolution.checks.base] Run check for free_space/systeme[0m
e[32m2025-07-12 21:15:30.687 INFO (MainThread) [supervisor.resolution.checks.base] Run check for docker_config/systeme[0m
e[32m2025-07-12 21:15:30.687 INFO (MainThread) [supervisor.resolution.checks.base] Run check for disabled_data_disk/systeme[0m
e[32m2025-07-12 21:15:30.688 INFO (MainThread) [supervisor.resolution.checks.base] Run check for pwned/addone[0m
e[32m2025-07-12 21:15:30.688 INFO (MainThread) [supervisor.jobs] 'CheckAddonPwned.run_check' blocked from execution, no supervisor internet connectione[0m
e[32m2025-07-12 21:15:30.688 INFO (MainThread) [supervisor.resolution.checks.base] Run check for trust/supervisore[0m
e[32m2025-07-12 21:15:30.700 INFO (MainThread) [supervisor.resolution.check] System checks completee[0m
e[32m2025-07-12 21:15:30.700 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state runninge[0m
e[32m2025-07-12 21:15:30.991 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation completee[0m
e[32m2025-07-12 21:15:30.993 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state runninge[0m
e[32m2025-07-12 21:15:30.993 INFO (MainThread) [supervisor.resolution.fixup] System autofix completee[0m
e[33m2025-07-12 21:16:17.871 WARNING (sentry-sdk.BackgroundWorker) [urllib3.connectionpool] Retrying (Retry(total=2, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NameResolutionError("<urllib3.connection.HTTPSConnection object at 0xffffa6aef4d0>: Failed to resolve 'o427061.ingest.sentry.io' ([Errno -3] Try again)")': /api/5370612/envelope/e[0m
e[32m2025-07-12 20:15:24.013 INFO (MainThread) [supervisor.resolution.fixup] System autofix completee[0m
e[32m2025-07-12 20:17:28.361 INFO (MainThread) [supervisor.backups.manager] Found 4 backup filese[0m
e[31m2025-07-12 20:17:28.380 ERROR (MainThread) [supervisor.backups.backup] Can't read backup tarfile /data/backup/31e48303.tar: "filename './backup.json' not found"e[0m
e[32m2025-07-12 20:17:36.473 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API tokene[0m
e[32m2025-07-12 20:17:38.392 INFO (MainThread) [supervisor.api.middleware.security] /supervisor/info access from cebe7a76_hassio_google_drive_backupe[0m
e[32m2025-07-12 20:17:38.399 INFO (MainThread) [supervisor.api.middleware.security] /backups access from cebe7a76_hassio_google_drive_backupe[0m
e[33m2025-07-12 20:28:17.865 WARNING (sentry-sdk.BackgroundWorker) [urllib3.connectionpool] Retrying (Retry(total=2, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NameResolutionError("<urllib3.connection.HTTPSConnection object at 0xffffa6aaf4d0>: Failed to resolve 'o427061.ingest.sentry.io' ([Errno -3] Try again)")': /api/5370612/envelope/e[0m
e[33m2025-07-12 20:28:22.881 WARNING (sentry-sdk.BackgroundWorker) [urllib3.connectionpool] Retrying (Retry(total=1, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NameResolutionError("<urllib3.connection.HTTPSConnection object at 0xffff954ae0d0>: Failed to resolve 'o427061.ingest.sentry.io' ([Errno -3] Try again)")': /api/5370612/envelope/e[0m
e[33m2025-07-12 20:28:52.889 WARNING (sentry-sdk.BackgroundWorker) [urllib3.connectionpool] Retrying (Retry(total=0, connect=None, read=None, redirect=None, status=None)) after connection broken by 'ConnectTimeoutError(<urllib3.connection.HTTPSConnection object at 0xffff954ad1d0>, 'Connection to o427061.ingest.sentry.io timed out. (connect timeout=30)')': /api/5370612/envelope/e[0m
e[33m2025-07-12 20:29:18.558 WARNING (sentry-sdk.BackgroundWorker) [urllib3.connectionpool] Retrying (Retry(total=2, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<urllib3.connection.HTTPSConnection object at 0xffff954aec10>: Failed to establish a new connection: [Errno 113] Host is unreachable')': /api/5370612/envelope/e[0m
e[33m2025-07-12 20:29:21.626 WARNING (sentry-sdk.BackgroundWorker) [urllib3.connectionpool] Retrying (Retry(total=1, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<urllib3.connection.HTTPSConnection object at 0xffff954ae490>: Failed to establish a new connection: [Errno 113] Host is unreachable')': /api/5370612/envelope/e[0m
e[33m2025-07-12 20:29:24.698 WARNING (sentry-sdk.BackgroundWorker) [urllib3.connectionpool] Retrying (Retry(total=0, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<urllib3.connection.HTTPSConnection object at 0xffff954aed50>: Failed to establish a new connection: [Errno 113] Host is unreachable')': /api/5370612/envelope/e[0m
e[33m2025-07-12 20:30:16.926 WARNING (sentry-sdk.BackgroundWorker) [urllib3.connectionpool] Retrying (Retry(total=2, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<urllib3.connection.HTTPSConnection object at 0xffffa6aef4d0>: Failed to establish a new connection: [Errno 113] Host is unreachable')': /api/5370612/envelope/e[0m
e[33m2025-07-12 20:30:19.995 WARNING (sentry-sdk.BackgroundWorker) [urllib3.connectionpool] Retrying (Retry(total=1, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<urllib3.connection.HTTPSConnection object at 0xffffa6aaf4d0>: Failed to establish a new connection: [Errno 113] Host is unreachable')': /api/5370612/envelope/e[0m
e[33m2025-07-12 20:30:23.067 WARNING (sentry-sdk.BackgroundWorker) [urllib3.connectionpool] Retrying (Retry(total=0, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<urllib3.connection.HTTPSConnection object at 0xffffa6aaf250>: Failed to establish a new connection: [Errno 113] Host is unreachable')': /api/5370612/envelope/e[0m
e[33m2025-07-12 20:31:15.291 WARNING (sentry-sdk.BackgroundWorker) [urllib3.connectionpool] Retrying (Retry(total=2, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<urllib3.connection.HTTPSConnection object at 0xffffa6aaf250>: Failed to establish a new connection: [Errno 113] Host is unreachable')': /api/5370612/envelope/e[0m
e[33m2025-07-12 20:31:21.435 WARNING (sentry-sdk.BackgroundWorker) [urllib3.connectionpool] Retrying (Retry(total=1, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<urllib3.connection.HTTPSConnection object at 0xffffa6aaf4d0>: Failed to establish a new connection: [Errno 113] Host is unreachable')': /api/5370612/envelope/e[0m
e[33m2025-07-12 20:31:27.579 WARNING (sentry-sdk.BackgroundWorker) [urllib3.connectionpool] Retrying (Retry(total=0, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<urllib3.connection.HTTPSConnection object at 0xffff954afc50>: Failed to establish a new connection: [Errno 113] Host is unreachable')': /api/5370612/envelope/e[0m
e[32m2025-07-12 20:31:49.409 INFO (SyncWorker_1) [supervisor.docker.manager] Stopping addon_d5369777_music_assistant applicatione[0m
e[32m2025-07-12 20:31:49.599 INFO (MainThread) [supervisor.api.proxy] [d5369777_music_assistant] Home Assistant WebSocket API closede[0m
e[32m2025-07-12 20:31:59.979 INFO (SyncWorker_1) [supervisor.docker.manager] Cleaning addon_d5369777_music_assistant applicatione[0m
e[32m2025-07-12 20:32:00.576 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on ghcr.io/music-assistant/server with version 2.5.5e[0m
e[33m2025-07-12 20:32:07.232 WARNING (MainThread) [supervisor.api.middleware.security] No API token provided for /coree[0m
e[32m2025-07-12 20:32:12.570 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API request initializee[0m
e[32m2025-07-12 20:32:12.579 INFO (MainThread) [supervisor.api.proxy] WebSocket access from d5369777_music_assistante[0m
e[32m2025-07-12 20:32:12.588 INFO (MainThread) [supervisor.api.proxy] [d5369777_music_assistant] Home Assistant WebSocket API proxy runninge[0m
e[33m2025-07-12 20:32:19.803 WARNING (sentry-sdk.BackgroundWorker) [urllib3.connectionpool] Retrying (Retry(total=2, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<urllib3.connection.HTTPSConnection object at 0xffffa1b425d0>: Failed to establish a new connection: [Errno 113] Host is unreachable')': /api/5370612/envelope/e[0m
DNS LOGS
[INFO] 127.0.0.1:59703 - 35077 "NS IN . udp 17 false 512" REFUSED qr,aa,rd 17 0.000150383s
[INFO] 127.0.0.1:57909 - 43259 "NS IN . udp 17 false 512" REFUSED qr,aa,rd 17 0.000144716s
[INFO] 172.30.32.1:42435 - 21465 "A IN ap-southeast-1-0.ui.nabu.casa. udp 47 false 512" - - 0 12.008798613s
[ERROR] plugin/errors: 2 ap-southeast-1-0.ui.nabu.casa. A: read udp 127.0.0.1:38812->127.0.0.1:5553: i/o timeout
[INFO] 127.0.0.1:35244 - 10851 "NS IN . udp 17 false 512" REFUSED qr,aa,rd 17 0.000282556s
[INFO] 172.30.32.1:42435 - 22173 "AAAA IN ap-southeast-1-0.ui.nabu.casa. udp 47 false 512" - - 0 12.013432014s
[ERROR] plugin/errors: 2 ap-southeast-1-0.ui.nabu.casa. AAAA: read udp 127.0.0.1:60488->127.0.0.1:5553: i/o timeout
[INFO] 127.0.0.1:44335 - 10334 "NS IN . udp 17 false 512" REFUSED qr,aa,rd 17 0.000200635s
[INFO] 127.0.0.1:43211 - 52908 "NS IN . udp 17 false 512" REFUSED qr,aa,rd 17 0.000133298s
[INFO] 172.30.32.1:42435 - 21465 "A IN ap-southeast-1-0.ui.nabu.casa. udp 47 false 512" - - 0 12.006838926s
[ERROR] plugin/errors: 2 ap-southeast-1-0.ui.nabu.casa. A: read udp 127.0.0.1:56302->127.0.0.1:5553: i/o timeout
[INFO] 172.30.32.1:42435 - 22173 "AAAA IN ap-southeast-1-0.ui.nabu.casa. udp 47 false 512" - - 0 12.006912347s
[ERROR] plugin/errors: 2 ap-southeast-1-0.ui.nabu.casa. AAAA: read udp 127.0.0.1:39452->127.0.0.1:5553: i/o timeout
[INFO] 172.30.32.2:35647 - 9759 "A IN o427061.ingest.sentry.io. udp 42 false 512" - - 0 12.006458804s
[ERROR] plugin/errors: 2 o427061.ingest.sentry.io. A: read udp 127.0.0.1:40406->127.0.0.1:5553: i/o timeout
I’m seeing this as well. Did you ever identify what caused it for you?
No never found out. I have not had one hang in quite some time now.
The solution is Native HA Backups - Hanging on Uploading to locations
I’m having this issue now with 2025.12.2 and .3. This started happening after adding the Backblaze B2 integration for backup target (but could have been coincidence, considering that’s 2025.12 so it could be that instead).
The automatic backup is hanging for over 4 hours. It doesn’t actually say creating/uploading for any of the backups on the list: /config/backup/overview just shows “uploading” on top of the page.
This backup and previous backups uploaded successfully to my NAS + Home Assistant Cloud - it doesn’t show any icon for Backblaze, so not sure if that’s where it is hanging, but I can actually see that.
Wish there was either a timeout or a stop command - ended up having to follow your instructions to stop it.
I can’t see anything in the logs to indicate what is failing unfortunately.
When I try a manual backup I can get it to upload to all locations successfully (including Backblaze), so I can’t quite understand why the automated one hang for the last 2 nights (well, it hang somewhere but it still seemingly uploaded everywhere?).
Weird one.
I still run the Home Assistant Google Drive Backup Add-On daily at 04:00 and;
Native Backup (Locally & Nabu Casa Cloud) daily at 05:30
Unfortunately the only solution for me was to follow this process. Delete or force remove hung back-up then Restart Core.
I have had no issues since 20 July 2025, I always stay up to date with the latest HA stable updates.
Possibly related issues
Thanks for the list. I’m going to look into it as my overnight backup is showing “uploading” again.
Looks like it successfully uploaded to NAS and Home Assistant Cloud so this might relate specifically to the new Backblaze integration.
Edit: or this might well relate to the fact that I added a new clan network interface. Saw this mentioned on one of the issues as well.
Maybe bad timing on my end as all 3 things I changed on my end happened in the same couple of days the issue started, so I can’t quite point out which is causing the issue.
After a few more automated backups, the issue seems to only happen once I add Backblaze as a target destination.
Manual backups do upload so it’s oddly specific.
For the benefit of anyone who might have the same issue, literally toggling off Backblaze as a destination target for the automated backup makes it work.
No need to disable or do anything to the automation.
I’m going to try and gather a bit more details after Christmas and open a GitHub issue.
I have the same issue with the Synology DSM backup location. It was working fine until 3 days ago.
Well, my issue (specific to Backblaze B2) seems to have been fixed in 2026.1.1 based on this: Add asyncio-level timeout to Backblaze B2 uploads by ElCruncharino · Pull Request #160468 · home-assistant/core · GitHub
Edit: it seems the issue isn’t actually fixed, my upload is still hanging.
