Native Shelly Integration and Shelly 1L Not Discovered (only firmware)
I have installed a new shelly mode: SHELLY 1L
Device is reconized but i have only firmware update and it does not expose any entity.
you have the new on the shelly?
Current version: 20201228-092147/v1.9.3@ad2bb4e3
Yes Informations sur l’appareil
SHSW-L
par Allterco
Firmware: 1.9.3
perfect, this is the last :slight_smile:
Yes, but it doesn’t work.Switch entity doesn’t appear. I have switched to MQTT
mh, dont test with “MQTT” test it with default “shelly:”
Works with beta 2.2
I’m having the same issue as you, how did you resolve it? Where did you get beta 2.2? The only beta that shows for me is 1.10.0-rc1
Nevermind, I figured it out. I realized you meant beta 2.2 of the Shelly integration for HASS and not the beta firmware.
After updating the firmware on the Shelly 1L (1.10), the relay disappeared from the Home Assistant, if you delete it and try to add it again, after entering the login and password, it swears at the inability to add the device. This is my local problem or any ideas how to fix this. Everything works through the Shelly app and cloud.
After update to 1.10 all my Shelly except Shelly 1L turn on CoIoT by default, after i turn on CoIoT on Shelly 1L all data transfer to HA and Shelly 1L work fine …
