So I think this has something to do with my “2017 Shield” androidtv entry that has the adbkey field set. I just got the RSA fingerprint of my existing key and it has the same fingerprint that keeps showing up on my new Shield. Here is my config for reference (Basement Shield TV is the shield with the issue):
I don’t see why /config/adbkey should affect the 2019 Shield… If you set the log level for the component (homeassistant.components.androidtv.media_player) to debug, it will tell you the key that it used.
Sorry about late response. I am running a 4k FireTV Stick. I installed the androidTV settings in my configuration.yaml after the 0.113 update(s). I am not use an adb server. I also have not forced a key but it is the same key each time. Thoughts?
It’s fixed in 0.113.4 (or 0.114 if they don’t make a 0.113.4 release). You can either wait for that release or use this custom component: https://github.com/JeffLIrion/ha-androidtv
If you use the custom component, after you tell it to remember the connection you can remove the custom component and go back to using the native component and the connection will be remembered.
I’m having problems with starting some of the apps on the shield using the media_player.select_source.
The apps that are predefined by the integration work fine, but the others don’t. I’m running latest Hassio (113.3)
I have found the following app IDs: nl.nlziet, com.ziggo.tv and nl.rtl.videoland.
Im pretty sure I have the correct IDs, as I extracted them with NodeRed and als the naming of the app to include it in the source list works. Is this a known error, or am I overlooking something?
hello
I have MI android tv box which is connected to home-assistant via suggested integrations, so everything works but the state of android tv changes sometimes and third-party apps don’t work.
For this, I have checked the internet and found a solution via addon in ha ie ADB so, I have installed everything and also done with configuration but the problem comes here
I cannot see the new entity in states don’t know why.
I have checked addon logs and also home assistant logs and restarted many times, everything is ok and they say connected but no entity
And by the way after addon installation, I removed previous media player integration so now even that is not coming I am struck here
I have 2 FireStick 4K working via ADB connected via hass.io add-on, without too many issues (unavailability).
Still then, I found that if I use the Wireless Display functionality from Windows10 (it is what I tried in both FireSticks), once you cancel this connection, FireStick becomes immediately unavailable.
Don’t know exactly if all needed, but only got it to work properly again (back online) after rebooting the FireStick itself and then HA. Restarting the hass.io add-on didn’t seem to do the trick, for an availability perspective.
Has anyone else experienced this issue or is this something new? Can I provide any more useful info for this to be looked at?
Thanks in advance for the amazing work on this component.
