Navbar card: easily navigate through dashboards
Hi…about badge i tried tò use the following Line as i ready in the documetation
badge:
template: states[‘climate.thermostat’].state === ‘heat’
I would like that badge depends by the state of two entities, so “or” “or”, the second entity Is climate.heater state “auto”. I tried many different way buy uncessuful.
Can someone help me?
Is possible thate the badge ‘blink 2s ease infinite’ too?
Thanks in advance
Somehow I missed that in the docs. I should’ve done better. Works like a charm. Thanks.
@AndreaDR You might be using the old syntax for badge configuration, take a look at the new one.
For your current use case, it could look something like:
type: custom:navbar-card
routes:
    badge:
      show: >
        [[[ return states[‘climate.thermostat’].state === ‘heat’ || another_condition_here ]]]
And regarding the blinking animation, try this:
styles: |
  @keyframes blink {
    50% {
      opacity: 0;
  .badge {
    animation: blink 2s ease infinite;
Docs might need a rewrite anyway, so no worries! :sweat_smile:
is it possible the make it vertical view?
The new update with popup_action is great.
I use it to have open a popup on hold with options to switch scenes per room.
Thanks @joseluis9595 :raised_hands:
Here is my config and image:
navbar-templates:
    routes:
      - url: /lovelace/living
        icon: mdi:sofa-outline
        icon_selected: mdi:sofa
        label: "Living\_Room"
        hold_action:
          action: open-popup
        popup:
          - tap_action:
              action: call-service
              service: script.activate_scene
              service_data:
                area_id: living_room
                scene: Work
            label: Work
            icon: mdi:briefcase
          - tap_action:
              service_data:
                scene: Chill
            label: Chill
            icon: mdi:hot-tub
          - tap_action:
              service_data:
                scene: TV
            label: TV
            icon: mdi:television
          - tap_action:
              service_data:
                scene: TV Night
            label: TV Night
            icon: mdi:television-ambient-light
          - tap_action:
              service_data:
                scene: Night
            label: Night
            icon: mdi:lightbulb-night
          - tap_action:
              service_data:
                scene: 'Off'
            label: 'Off'
            icon: mdi:lightbulb-group-off
Hi @ald112 , is this what you are aiming for?
If so, you simply need to configure the position value in desktop mode.
Quick example:
desktop:
  position: left
routes:
Looks good! Might steal the idea for my own dashboard :sweat_smile:
(thanks to you for requesting the popup action on github!)
@joseluis9595 thank u so much might
@joseluis9595 there is way in order to get “back” in the “home route” automatically after “x” seconds?
3 suggestions!
  1. use badges in popup labels aswell!
  2. change color of custom icons through color:
  3. Hide icon depending on state of an entity state & person state ( or is this possible ? )
Hi @laurens362 , thanks for taking the time to help improve navbar-card :slight_smile:
Good news is, 1 and 3 are already possible! Quick example:
desktop:
  position: bottom
routes:
  - icon: mdi:dots-horizontal
    label: More
    # Use the prop "hidden" to control the visibility of this route
    # using JS templates
    hidden: |
        return user.name !== "jose";
    tap_action:
      action: open-popup
    popup:
      - icon: mdi:cog
        url: /config/dashboard
        # "badge" configuration is also available in popup items!
        badge:
          show: |
              return states["binary_sensor.docker_hub_update_available"].state === "on";
[quote=“joseluis9595, post:73, topic:832917”]
hi,
this doesnt seem to work for me: s
And i also cant make one hidden with anything else then person though…
routes:
  - url: /dashboard-2-0/0
    icon: mdi:home
    label: Home
  - url: "#f1"
    icon: mdi:racing-helmet
    label: F1
    hold_action:
      action: navigate
      navigation_path: "#f1"
    badge:
      show: |
          return states["light.woonkamer"].state === "on";
  - url: /config/automation/dashboard
    icon: mdi:creation
    label: Automations
  - url: "#plex-list"
    icon: mdi:plex
    label: Plex
    hidden: |
      [[[ return user.name != "Adna"; ]]]
  - url: "#plex-list"
    icon: mdi:plex
    label: Plex
    tap_action:
      action: open-popup
    popup:
      - icon: mdi:movie-plus
        url: "#plex-list"
        label: plex added
      - icon: mdi:plex
        url: "#plex"
        label: plex watching
    hidden: |
      [[[ return user.name != "Laurens"; ]]]
    badge:
      show: |
        [[[ return states['sensor.tautulli_stream_count'].state > 0; ]]]
      color: green
    label: More
    tap_action:
      action: open-popup
    badge:
      show: |
        [[[ return states['group.all_update_entities'].state === 'on'; ]]]
      color: green
    popup:
      - icon: mdi:silverware-fork-knife
        url: "#eetlijst"
        label: Eetlijst
      - icon: mdi:wifi
        url: "#wifi"
        label: Wifi
        badge:
          show: |
      - icon: mdi:docker
        url: "#docker"
        label: Docker
        hidden: |
      - icon: mdi:update
        url: "#updates"
        label: Updates
        hidden: |
styles: |
  .navbar {
    background: #000000;
    --navbar-primary-color: lightblue;
  .icon {
    --mdc-icon-size: 30px;
Still doesnt work after the new update :frowning:
Can you open the JS console, and check which version of navbar card you have installed? Seems like the latest release had some kind of problem with the compiled file, and is still downloading the 0.6.0 version.
Will force a new release, to see if that cleans things up.
You should be able to access the states variable as well as the person one, in any JS template used across navbar-card.
Should be fixed with the latest release :slight_smile:
Still not working! Im on 0.7.0 according to js
I am using a custom:button-card. How do I set the style to be 50% transparent on a button card custom_fields?
I only have one icon, how would I make it centered and show up bigger?
Is it possible to add these to the template?
desktop:
  position: left
  min_width: 768
  show_labels: true
mobile:
  show_labels: false
Sorry @laurens362 , haven’t checked HA community for a while :frowning:
Was the problem solved? If not, feel free to open an issue on github and I’ll take a proper look at it :slight_smile:
Also, quick tip, for debugging templates in navbar-card, you can use console.log to print debug data to the JS console if needed.
