I have a couple of esp8266 devices each running a webserver that has UI to configure those devices. Each of these devices uses the homeassistant mqtt auto discovery feature and l am able to see my lights or switches and manipulate them from homeassistant. I use default Lovelace UI nothing custom.
What l would like to achieve is when in homeassistant for example l can tap on the device name say “Kitchen Light” . This currently takes me to another screen still in homeassistant where l can look at history. Is there a way in that next screen l could tap or double tap on the name again but this time it should navigate to an external url in this case the ip address of that device as reported to mqtt. The ip address is already known due to the mqtt integration.
I want a solution that l do not need to update on each auto discovered device. Has anyone done that or offer any help.
This would prevent me from having to leave homeassistant find the ip address of the device launch browser and do my configuration and then comeback to homeassistant. The device ip addresses are on dhcp its tedious and would be nice to do it all from homeassistant.
