I finished building smart rollerblinds, and now I would like to place a wallswitch which can control the rollerblind.
It should have 3 buttons: Up, Stop, Down.
It should NOT require in-wall mounting (instead just beeing placed on the wall)
it should be either Zigbee or Z-wave. Alternatives would be 433mhz radio, and if nothing else helps, W-LAN would be okay. But I want to avoid polluting my network with IoT devices, thus, Z*/433 is preferred.
So now I have been searching quite a bit, but I fail to find viable other switches. Either they’re ugly, or they require in-wall mounting, or they don’t have 3 buttons.
The remotes that you mentioned above with 27A battery are still near the original charge, or recorded only a drop of less than 0.02 V after 3 years of use (actually it is a combo use as I also have 433 Mhz motion sensors controlling the lights so I’m not using only the wall switch for turning on; but they would probably last more than 10 years in the current environment).
It is more close to a blinds remote but I had to remove it from the setup as it was confusing for other users This model used CR2032 battery and it was still at 3.09 V after 6 months of usage. I remember there were some options with CR2450, a little more bulky, but I don’t think the battery will run out for either before 8-10 years.
