Need a sample for a "simple button" blueprint
I’m looking for a blueprint that can do the following:
Let’s say I have a smartswith that provides only
  single-click
  long-press
What the blueprint is supposed to do
single-click:
	toggle light (turn off or turn on on at last recorded light intensity)
long-press:
	turn on light (at last recorded light intensity) AND
	if initial brightness < 50%
		start "brightness up"
		stop at single-click or brightness = 100%
	if initial brightness > 50%
		start "brightness-down"
		stop at single click or brightness = 1%
long-press (within 1 sec of previous long-press):
	if previous action "brightness-down":
		start "brightness-up"
		stop at single click or brightness = 100%
	if previous action brightness-up:
		start brightness-down
Is anybody aware of such a blueprint and/or automation?
Kind regards
bartplessers
I’d like to share an automation I’ve created for the Xiaomi/Aqara Wireless Mini Switch (WXKG11LM). You can find more details about this “simple button” here: Aqara WXKG11LM control via MQTT | Zigbee2MQTT
Before setting up this automation, you’ll need to create two helper entities:
  1. input_text.minibutton_last_state
  2. input_text.minibutton_last_controlled_entity
This automation supports the following button actions:
  • Single press
  • Double press
  • Triple press
  • Quintuple press
  • Many press
  • Hold
For the single, double, triple, quintuple, and many press actions, I’ve set them up to toggle different lights in my home. Feel free to adjust these to control whatever devices suit your needs.
The hold action is used to dim or brighten the last controlled light. This is particularly useful when you want to adjust the brightness after turning on a light without having to use a separate control.
Feel free to modify this automation to fit your specific needs. I hope you find it useful!
alias: Minibutton with Dimming
description: "Control lights with a mini button"
mode: parallel
triggers:
  - platform: state
    entity_id:
      - sensor.0x54ef441000a859fe_action
actions:
  # Store the button state. Essential for the hold function.
  - choose:
      - conditions:
          - condition: template
            value_template: "{{ trigger.to_state.state != '' }}"
        sequence:
          - service: input_text.set_value
              entity_id: input_text.minibutton_last_state
              value: "{{ trigger.to_state.state }}"
  # Handle all button presses
  - choose:
      # Single press: Toggle office lights
      - conditions:
            value_template: "{{ trigger.to_state.state == 'single' }}"
        sequence:
          - service: light.toggle
              entity_id: light.office_lights
              entity_id: input_text.minibutton_last_controlled_entity
              value: light.office_lights
      # Double press: Toggle living room hues
      - conditions:
            value_template: "{{ trigger.to_state.state == 'double' }}"
        sequence:
              entity_id: light.all_hue_bulbs
              value: light.all_hue_bulbs
      # triple press: livingroom_all_spots
      - conditions:
            value_template: "{{ trigger.to_state.state == 'triple' }}"
        sequence:
              entity_id: light.livingroom_all_spots_2
              value: light.livingroom_all_spots_2
      # Quintuple press: living_room_all_lights
      - conditions:
            value_template: "{{ trigger.to_state.state == 'quintuple' }}"
        sequence:
          - service: script.toggle_living_room_lights
              value: light.living_room_all_lights
      # Many press: kitchen_main_hue
      - conditions:
            value_template: "{{ trigger.to_state.state == 'many' }}"
        sequence:
              entity_id: light.kitchen_main_huex2
              value: light.kitchen_main_huex2
      # Long press (hold): Dimming
      - conditions:
            value_template: "{{ trigger.to_state.state == 'hold' }}"
        sequence:
          - choose:
              # Dim down if light is on and brightness > 50%
              - conditions:
                    value_template: >-
                      {{ states(states('input_text.minibutton_last_controlled_entity')) == 'on' and
                         (state_attr(states('input_text.minibutton_last_controlled_entity'), 'brightness') | int > 127) }}
                sequence:
                  - repeat:
                      while:
                          value_template: "{{ states('input_text.minibutton_last_state') == 'hold' }}"
                      sequence:
                        - service: light.turn_on
                            entity_id: "{{ states('input_text.minibutton_last_controlled_entity') }}"
                            brightness_step_pct: -15
                            transition: 0.15
                        - delay: 0.2
              # Dim up if light is off or brightness <= 50%
              - conditions:
                    value_template: >-
                      {{ states(states('input_text.minibutton_last_controlled_entity')) == 'off' or
                         (state_attr(states('input_text.minibutton_last_controlled_entity'), 'brightness') | int <= 127) }}
                sequence:
                  - repeat:
                      while:
                      sequence:
                            brightness_step_pct: 15
                            transition: 0.15
                        - delay: 0.2
