Basically been running Home Assistant 0.45.1 for a while without a glitch… for some reason upgrading to 0.55 broke my devices. The rpi_gpio switches disappeared.
little background… used to run hassbian with 0.45.1… when I update using SUDO APT-GET UPDATE && SUDO APT-GET UPGRADE the OS; it would break the whole system. The PI3 would not even boot… my work around is install hassbian from scratch and just update the HA part using
sudo su -s /bin/bash homeassistant
source /srv/homeassistant/bin/activate
pip3 install --upgrade homeassistant
exit
Everything works until I stumbled around 0.55. that’s when everything got weird. The rpi_gpio switches disappear. log said “RuntimeError: No access to /dev/mem. Try running as root!” … of course googling around gave some work around but none of them work… I updated my OS using SUDO APT-GET UPDATE && SUDO APT-GET UPGRADE thinking updated HA need updated hassbian… nope I was wrong
I tried starting from scratch using the new HASSBIAN… that didn’t work… I did start again from scratch using hassbian then run the AIO installer… that didn’t work… I keep ending up with working HA but my rpi_rf switches are not showing. log shows same error
tried running
sudo chown root.gpio /dev/mem
sudo chmod g+rw /dev/mem
sudo usermod -a -G hass,gpio hass
sudo usermod -a -G homeassistant,gpio homeassistant
sudo usermod -a -G pi,gpio pi
Tried the new Raspbian Stretch Lite and run the AIO installer that one would not even complete the installation…
so now I looked around and I found a backup of my working image back in 06-13-17… thinking yes this is the answer to my prayer… nope … that one is now also broken… I get the “RuntimeError: No access to /dev/mem. Try running as root!”… which I find weird because when I backed up my Pi back in 06-13-17 (0.45.1) everything is working thats why I backed it up in case something like this happen.
now I Just need some guide to get a working HA with working rpi_gpio switches… maybe there’s another way i missed trying?? any suggestion would be great
thank you guys
