Need: cloudless WLAN roller shutter with RF433 support (as alternative to DieseRC WiFi+RF curtain module)
I bought roller shutter modules “DieseRC Wi-Fi+RF Courtain Module” due to the combination of WiFi and RF433 and integrated them via tuya to my Home Assistant (Intel NUC) and Alexa. To do this, I need a tuya account, run the tuya smart app, add the modules there and and link my account to my Amazon account.
https://images.app.goo.gl/pNeqgssuF2XC35gPA
However, I don’t like the idea of my roller shutter modules talking to the tuya cloud for daily operation, requiring a stable Internet connection and the tuya service to be available. I also would like to avoid any other smartphone app than Home Assistant, where I will do my automation.
I want to be as independent as possible and operate only locally, avoiding cloud integration and esp. external communication via some cloud for every button I push or every script that I run.
QUESTION: Does anyone have an idea for a roller shutter module that communicates only locally within my WLAN SSID to Home Assistant and in addition supports RF433 (or Zigbee or Z-Wave) for independent operation via an RC or push-button?
as an ex blindmaker, i suggest go aliexpress or google for dooya or raex although they now use tuya they (used to) make stand alone rf & ir controls and probably still do. You will need a broadlink or similar. If you were in spain i could sell you one from ex my redundant stock. ps woulds have to be dumb motor.
I doubt if Tuya allow for volt free contacts on motors now. If they do thats another route.
Hope it makes sense
Thanks for the hints :pray: I really want to avoid tuya and also additional RF modules at the motor (want to operate both ways, via direct communication between wall mounted push buttons and via HA gateway).
I have decided to use two roller shutter modules (NodOn SIN-4-RS-20 due to small form factor and large temperature range) and link them via Zigbee binding in MQTT. However, am still having issues. See my other post:
Find my final solution here: Solved: Roller Shutter control without seperated up/down wires
