Need help by detecting reason for some further errors in the log
Hi there,
does anyone have an idea what might cause these errors in the log?
Logger: homeassistant.setup
Source: setup.py:179
First occurred: 15:38:03 (1 occurrences)
Last logged: 15:38:03
Setup failed for default_config: Could not set up all dependencies.
Source: setup.py:159
Unable to set up dependencies of default_config. Setup failed for dependencies: zeroconf
Source: components/zeroconf/__init__.py:119
Error during setup of component zeroconf
  File "/usr/src/homeassistant/homeassistant/setup.py", line 255, in _async_setup_component
    result = await task
  File "/usr/src/homeassistant/homeassistant/components/zeroconf/__init__.py", line 157, in async_setup
    aio_zc = await _async_get_instance(hass, **zc_args)
  File "/usr/src/homeassistant/homeassistant/components/zeroconf/__init__.py", line 119, in _async_get_instance
    zeroconf = HaZeroconf(**zcargs)
  File "/usr/local/lib/python3.9/site-packages/zeroconf/_core.py", line 410, in __init__
    listen_socket, respond_sockets = create_sockets(interfaces, unicast, ip_version, apple_p2p=apple_p2p)
  File "/usr/local/lib/python3.9/site-packages/zeroconf/_utils/net.py", line 360, in create_sockets
    respond_socket = new_respond_socket(i, apple_p2p=apple_p2p)
  File "/usr/local/lib/python3.9/site-packages/zeroconf/_utils/net.py", line 319, in new_respond_socket
    respond_socket = new_socket(
  File "/usr/local/lib/python3.9/site-packages/zeroconf/_utils/net.py", line 244, in new_socket
    s.bind((bind_addr[0], port, *bind_addr[1:]))
OSError: [Errno 99] Address not available
does anyone know where I might look for these errors?
unfortunately, the error text doesn’t really point me to any area atm :frowning:
seems that I’ve found the issue.
I don’t know why, but Supervisor did show an IP configuration with /32 for subnet mask.
After changing this to /24 it seems to be resolved.
