Need help clearing unsupported warning after resolution
I got this warning by supervisor (I am using HAOS on a raspberry pi4) about unsupported software, in the logs in yellow, pi CEC was pointed out as unsupported (i tried using it to get use of the Pi’s CEC but didnt work), I have went into the ad-ons section and uninstalled it and restarted home assistant, but the warning will not go away, Do i need to rollback my entire HAOS install to clear it? while it seems ignorable, I rather the warning be a full dismiss if possible
Have you tried rebooting the Host machine, as opposed to just restarting Home Assistant?
i have just tried that, now i cant access the instance
EDIT: nvm, it never made it to boot because the pi cooked when it re-powered, had to cool it first, the warning seems to have dissapeared for now, thanks
Did you just pull the plug or did you shutdown from Settings → System → Power button?
Can you connect a monitor and keyboard to your pi?
i powered down from the HASS shutdown menus
Glad to hear it worked.
