I have a GoControl/Nortek WA00Z-1 WALL MOUNTED SWITCH that was working fine to turn 2 zwave plugs and a zwave switch off/on until I had to replace the wall switch. Unfortunately, the zwave panels have change since the last year and I can’t seem to figure out how to go back and rebuild the config on the switch to add the replacement switch. I’m open to just having HA activate a scene when the button is pressed on the WA00Z-1, but I have yet to figure that out.
Here is the zwave config panel for the wall switch:
Here is the debug info from the Bottom button:
Subscribed to Z-Wave JS Log Messages…
2023-01-21T19:07:14.572Z SERIAL « 0x01180049841b120418015e86725b8559737080845a7aef5b20a0 (26 bytes)
2023-01-21T19:07:14.576Z SERIAL » [ACK] (0x06)
2023-01-21T19:07:14.580Z DRIVER « [Node 027] [REQ] [ApplicationUpdateRequest]
payload: 0x1b120418015e86725b8559737080845a7aef5b20
2023-01-21T19:07:14.591Z CNTRLR « [Node 027] Received updated node info
2023-01-21T19:07:14.597Z SERIAL « 0x010b0004001b055b031e0002aa (13 bytes)
2023-01-21T19:07:14.599Z SERIAL » [ACK] (0x06)
2023-01-21T19:07:14.603Z DRIVER « [Node 027] [REQ] [ApplicationCommand]
└─[CentralSceneCCNotification]
sequence number: 30
key attribute: KeyPressed
scene number: 2
2023-01-21T19:07:14.609Z CNTRLR [Node 027] [!] [Central Scene] scene[002]: 0
2023-01-21T19:07:14.611Z CNTRLR « [Node 027] received CentralScene notification {
“nodeId”: 27,
“ccId”: “Central Scene”,
“ccCommand”: “0x03”,
“payload”: “0x1e0002”
2023-01-21T19:07:14.721Z SERIAL « 0x01090004000d03200300df (11 bytes)
2023-01-21T19:07:14.727Z SERIAL » [ACK] (0x06)
2023-01-21T19:07:14.732Z CNTRLR [Node 013] [~] [Basic] currentValue: 99 => 0 [Endpoint 0]
2023-01-21T19:07:14.737Z DRIVER « [Node 013] [REQ] [ApplicationCommand]
└─[BasicCCReport]
current value: 0
2023-01-21T19:07:14.744Z CNTRLR [Node 013] [~] [Binary Switch] currentValue: true => false [Endpoint 0]
2023-01-21T19:07:14.830Z SERIAL « 0x01090004000a03200300d8 (11 bytes)
2023-01-21T19:07:14.834Z SERIAL » [ACK] (0x06)
2023-01-21T19:07:14.839Z CNTRLR [Node 010] [~] [Basic] currentValue: 99 => 0 [Endpoint 0]
2023-01-21T19:07:14.844Z DRIVER « [Node 010] [REQ] [ApplicationCommand]
└─[BasicCCReport]
current value: 0
2023-01-21T19:07:14.852Z CNTRLR [Node 010] [~] [Binary Switch] currentValue: true => false [Endpoint 0]
2023-01-21T19:07:14.876Z SERIAL « 0x01090004000d03200300df (11 bytes)
2023-01-21T19:07:14.878Z SERIAL » [ACK] (0x06)
2023-01-21T19:07:14.882Z CNTRLR [Node 013] [~] [Basic] currentValue: 0 => 0 [Endpoint 0]
2023-01-21T19:07:14.885Z DRIVER « [Node 013] [REQ] [ApplicationCommand]
└─[BasicCCReport]
current value: 0
2023-01-21T19:07:14.891Z CNTRLR [Node 013] [~] [Binary Switch] currentValue: false => false [Endpoint 0]
Top button log:
Log Level changed to: Debug
2023-01-21T19:05:43.000Z SERIAL « 0x01180049841b120418015e86725b8559737080845a7aef5b20a0 (26 bytes)
2023-01-21T19:05:43.013Z SERIAL » [ACK] (0x06)
2023-01-21T19:05:43.018Z DRIVER « [Node 027] [REQ] [ApplicationUpdateRequest]
2023-01-21T19:05:43.023Z CNTRLR « [Node 027] Received updated node info
2023-01-21T19:05:43.025Z CNTRLR [Node 027] The node is now awake.
2023-01-21T19:05:43.060Z SERIAL » 0x010c00131b057004010101252f81 (14 bytes)
2023-01-21T19:05:43.063Z DRIVER » [Node 027] [REQ] [SendData]
│ transmit options: 0x25
│ callback id: 47
└─[ConfigurationCCSet]
parameter #: 1
reset to default: false
value size: 1
value format: SignedInteger
value: 1
2023-01-21T19:05:43.068Z SERIAL « 0x010b0004001b055b03180001af (13 bytes)
2023-01-21T19:05:43.072Z SERIAL » [ACK] (0x06)
2023-01-21T19:05:43.074Z SERIAL « [CAN] (0x18)
2023-01-21T19:05:43.078Z CNTRLR Failed to execute controller command after 1/3 attempts. Scheduling next try i
n 100 ms.
2023-01-21T19:05:43.083Z DRIVER « [Node 027] [REQ] [ApplicationCommand]
sequence number: 24
scene number: 1
2023-01-21T19:05:43.090Z CNTRLR [Node 027] [!] [Central Scene] scene[001]: 0
2023-01-21T19:05:43.093Z CNTRLR « [Node 027] received CentralScene notification {
“nodeId”: 27,
“payload”: “0x180001”
2023-01-21T19:05:43.113Z SERIAL « 0x01090004000d032003ff20 (11 bytes)
2023-01-21T19:05:43.116Z SERIAL » [ACK] (0x06)
2023-01-21T19:05:43.120Z CNTRLR [Node 013] [~] [Basic] currentValue: 99 => 99 [Endpoint 0]
2023-01-21T19:05:43.123Z DRIVER « [Node 013] [REQ] [ApplicationCommand]
└─[BasicCCReport]
current value: 99
2023-01-21T19:05:43.131Z CNTRLR [Node 013] [~] [Binary Switch] currentValue: true => true [Endpoint 0]
2023-01-21T19:05:43.181Z SERIAL » 0x010c00131b057004010101252f81 (14 bytes)
2023-01-21T19:05:43.185Z DRIVER » [Node 027] [REQ] [SendData]
│ callback id: 47
parameter #: 1
value size: 1
value: 1
2023-01-21T19:05:43.191Z SERIAL « [ACK] (0x06)
2023-01-21T19:05:43.198Z SERIAL « 0x0104011301e8 (6 bytes)
2023-01-21T19:05:43.201Z SERIAL » [ACK] (0x06)
2023-01-21T19:05:43.204Z DRIVER « [RES] [SendData]
was sent: true
2023-01-21T19:05:43.214Z SERIAL « 0x010700132f000003c7 (9 bytes)
2023-01-21T19:05:43.215Z SERIAL » [ACK] (0x06)
2023-01-21T19:05:43.218Z DRIVER « [REQ] [SendData]
callback id: 47
transmit status: OK
2023-01-21T19:05:43.239Z SERIAL » 0x010c00131b057004020101253c91 (14 bytes)
2023-01-21T19:05:43.242Z DRIVER » [Node 027] [REQ] [SendData]
│ callback id: 60
parameter #: 2
value size: 1
value: 1
2023-01-21T19:05:43.249Z SERIAL « 0x01090004000a032003ff27 (11 bytes)
2023-01-21T19:05:43.252Z SERIAL » [ACK] (0x06)
2023-01-21T19:05:43.254Z SERIAL « [CAN] (0x18)
2023-01-21T19:05:43.263Z CNTRLR Failed to execute controller command after 1/3 attempts. Scheduling next try i
n 100 ms.
2023-01-21T19:05:43.268Z CNTRLR [Node 010] [~] [Basic] currentValue: 99 => 99 [Endpoint 0]
2023-01-21T19:05:43.271Z DRIVER « [Node 010] [REQ] [ApplicationCommand]
└─[BasicCCReport]
current value: 99
2023-01-21T19:05:43.277Z CNTRLR [Node 010] [~] [Binary Switch] currentValue: true => true [Endpoint 0]
2023-01-21T19:05:43.280Z SERIAL « 0x01090004000d032003ff20 (11 bytes)
2023-01-21T19:05:43.282Z SERIAL » [ACK] (0x06)
2023-01-21T19:05:43.286Z CNTRLR [Node 013] [~] [Basic] currentValue: 99 => 99 [Endpoint 0]
2023-01-21T19:05:43.289Z DRIVER « [Node 013] [REQ] [ApplicationCommand]
└─[BasicCCReport]
current value: 99
2023-01-21T19:05:43.294Z CNTRLR [Node 013] [~] [Binary Switch] currentValue: true => true [Endpoint 0]
2023-01-21T19:05:43.365Z SERIAL » 0x010c00131b057004020101253c91 (14 bytes)
2023-01-21T19:05:43.369Z DRIVER » [Node 027] [REQ] [SendData]
│ callback id: 60
parameter #: 2
value size: 1
value: 1
2023-01-21T19:05:43.376Z SERIAL « [ACK] (0x06)
2023-01-21T19:05:43.383Z SERIAL « 0x0104011301e8 (6 bytes)
2023-01-21T19:05:43.386Z SERIAL » [ACK] (0x06)
2023-01-21T19:05:43.390Z DRIVER « [RES] [SendData]
was sent: true
2023-01-21T19:05:43.506Z SERIAL « 0x01090004000d032003ff20 (11 bytes)
2023-01-21T19:05:43.509Z SERIAL » [ACK] (0x06)
2023-01-21T19:05:43.514Z CNTRLR [Node 013] [~] [Basic] currentValue: 99 => 99 [Endpoint 0]
2023-01-21T19:05:43.518Z DRIVER « [Node 013] [REQ] [ApplicationCommand]
└─[BasicCCReport]
current value: 99
2023-01-21T19:05:43.527Z CNTRLR [Node 013] [~] [Binary Switch] currentValue: true => true [Endpoint 0]
2023-01-21T19:05:43.552Z SERIAL « 0x010700133c000012c5 (9 bytes)
2023-01-21T19:05:43.554Z SERIAL » [ACK] (0x06)
2023-01-21T19:05:43.557Z DRIVER « [REQ] [SendData]
callback id: 60
transmit status: OK
2023-01-21T19:05:43.582Z SERIAL » 0x010c00131b057004010101253d93 (14 bytes)
2023-01-21T19:05:43.584Z DRIVER » [Node 027] [REQ] [SendData]
│ callback id: 61
parameter #: 1
value size: 1
value: 1
2023-01-21T19:05:43.591Z SERIAL « 0x01090004000a032003ff27 (11 bytes)
2023-01-21T19:05:43.596Z SERIAL » [ACK] (0x06)
2023-01-21T19:05:43.598Z SERIAL « [CAN] (0x18)
2023-01-21T19:05:43.602Z CNTRLR Failed to execute controller command after 1/3 attempts. Scheduling next try i
n 100 ms.
2023-01-21T19:05:43.606Z CNTRLR [Node 010] [~] [Basic] currentValue: 99 => 99 [Endpoint 0]
2023-01-21T19:05:43.609Z DRIVER « [Node 010] [REQ] [ApplicationCommand]
└─[BasicCCReport]
current value: 99
2023-01-21T19:05:43.619Z CNTRLR [Node 010] [~] [Binary Switch] currentValue: true => true [Endpoint 0]
2023-01-21T19:05:43.706Z SERIAL » 0x010c00131b057004010101253d93 (14 bytes)
2023-01-21T19:05:43.711Z DRIVER » [Node 027] [REQ] [SendData]
│ callback id: 61
parameter #: 1
value size: 1
value: 1
2023-01-21T19:05:43.716Z SERIAL « [ACK] (0x06)
2023-01-21T19:05:43.724Z SERIAL « 0x0104011301e8 (6 bytes)
2023-01-21T19:05:43.726Z SERIAL » [ACK] (0x06)
2023-01-21T19:05:43.730Z DRIVER « [RES] [SendData]
was sent: true
2023-01-21T19:05:43.737Z SERIAL « 0x010700133d000002d4 (9 bytes)
2023-01-21T19:05:43.739Z SERIAL » [ACK] (0x06)
2023-01-21T19:05:43.742Z DRIVER « [REQ] [SendData]
callback id: 61
transmit status: OK
2023-01-21T19:05:43.764Z SERIAL » 0x010c00131b057004010100253e91 (14 bytes)
2023-01-21T19:05:43.768Z DRIVER » [Node 027] [REQ] [SendData]
│ callback id: 62
parameter #: 1
value size: 1
value: 0
2023-01-21T19:05:43.778Z SERIAL « [ACK] (0x06)
2023-01-21T19:05:43.782Z SERIAL « 0x0104011301e8 (6 bytes)
2023-01-21T19:05:43.785Z SERIAL » [ACK] (0x06)
2023-01-21T19:05:43.789Z DRIVER « [RES] [SendData]
was sent: true
2023-01-21T19:05:43.875Z SERIAL « 0x010700133e00000adf (9 bytes)
2023-01-21T19:05:43.878Z SERIAL » [ACK] (0x06)
2023-01-21T19:05:43.883Z DRIVER « [REQ] [SendData]
callback id: 62
transmit status: OK
2023-01-21T19:05:44.328Z SERIAL « 0x01090004001b038003375e (11 bytes)
2023-01-21T19:05:44.333Z SERIAL » [ACK] (0x06)
2023-01-21T19:05:44.339Z CNTRLR [Node 027] [~] [Battery] level: 52 => 55 [Endpoint 0]
2023-01-21T19:05:44.344Z CNTRLR [Node 027] [~] [Battery] isLow: false => false [Endpoint 0]
2023-01-21T19:05:44.350Z DRIVER « [Node 027] [REQ] [ApplicationCommand]
└─[BatteryCCReport]
level: 55
is low: false
2023-01-21T19:05:44.600Z SERIAL » 0x010a00131b03700502253f93 (12 bytes)
2023-01-21T19:05:44.607Z DRIVER » [Node 027] [REQ] [SendData]
│ callback id: 63
└─[ConfigurationCCGet]
parameter #: 2
2023-01-21T19:05:44.613Z SERIAL « [ACK] (0x06)
2023-01-21T19:05:44.617Z SERIAL « 0x0104011301e8 (6 bytes)
2023-01-21T19:05:44.620Z SERIAL » [ACK] (0x06)
2023-01-21T19:05:44.622Z DRIVER « [RES] [SendData]
was sent: true
2023-01-21T19:05:44.632Z SERIAL « 0x010700133f000003d7 (9 bytes)
2023-01-21T19:05:44.634Z SERIAL » [ACK] (0x06)
2023-01-21T19:05:44.637Z DRIVER « [REQ] [SendData]
callback id: 63
transmit status: OK
2023-01-21T19:05:44.646Z SERIAL « 0x010b0004001b0570060201019a (13 bytes)
2023-01-21T19:05:44.649Z SERIAL » [ACK] (0x06)
2023-01-21T19:05:44.654Z CNTRLR [Node 027] [~] [Configuration] 2: 1 => 1
2023-01-21T19:05:44.658Z DRIVER « [Node 027] [REQ] [ApplicationCommand]
└─[ConfigurationCCReport]
parameter #: 2
value size: 1
value: 1
2023-01-21T19:05:44.918Z SERIAL » 0x010a00131b037005012540ef (12 bytes)
2023-01-21T19:05:44.922Z DRIVER » [Node 027] [REQ] [SendData]
│ callback id: 64
parameter #: 1
2023-01-21T19:05:44.927Z SERIAL « [ACK] (0x06)
2023-01-21T19:05:44.932Z SERIAL « 0x0104011301e8 (6 bytes)
2023-01-21T19:05:44.935Z SERIAL » [ACK] (0x06)
2023-01-21T19:05:44.938Z DRIVER « [RES] [SendData]
was sent: true
2023-01-21T19:05:44.946Z SERIAL « 0x0107001340000002a9 (9 bytes)
2023-01-21T19:05:44.948Z SERIAL » [ACK] (0x06)
2023-01-21T19:05:44.951Z DRIVER « [REQ] [SendData]
callback id: 64
transmit status: OK
2023-01-21T19:05:44.961Z SERIAL « 0x010b0004001b05700601010098 (13 bytes)
2023-01-21T19:05:44.963Z SERIAL » [ACK] (0x06)
2023-01-21T19:05:44.982Z CNTRLR [Node 027] [~] [Configuration] 1: 0 => 0
2023-01-21T19:05:44.985Z DRIVER « [Node 027] [REQ] [ApplicationCommand]
parameter #: 1
value size: 1
value: 0
2023-01-21T19:05:45.327Z SERIAL « 0x01080004001b02840769 (10 bytes)
2023-01-21T19:05:45.332Z SERIAL » [ACK] (0x06)
2023-01-21T19:05:45.336Z DRIVER « [Node 027] [REQ] [ApplicationCommand]
└─[WakeUpCCWakeUpNotification]
2023-01-21T19:05:45.348Z CNTRLR « [Node 027] received wakeup notification
