I need help converting Sonoff from Tasmota to ESPhome.
I have successfully run tasmotized devices in HA, but I want to get to know the flavor of ESPhome. That’s why I flashed a sonoff basic, equipped with a Dallas DS18B20, to ESPhome using the ESPhome integration.
During integration, the device appears online indicated by a green bar in ESPhome. When opening the logbook I see the address of the sensor, the temperature, when toggling the button the log shows and the relay is indeed switching.
But I don’t see the device appear in the device list of the configuration and therefore the associated entities. What am I missing?
INFO Reading configuration /config/esphome/esphome92.yaml...
INFO Starting log output from esphome92.lan using esphome API
INFO Connecting to esphome92.lan:6053 (192.168.178.92)
WARNING Initial connection failed. The ESP might not be connected to WiFi yet (Error connecting to 192.168.178.92: timed out). Re-Trying in 1 seconds
INFO Successfully connected to esphome92.lan
[21:35:03][I][app:105]: ESPHome version 1.16.2 compiled on Apr 22 2021, 21:45:57
[21:35:03][C][status_led:019]: Status LED:
[21:35:03][C][status_led:020]: Pin: GPIO13 (Mode: OUTPUT, INVERTED)
[21:35:03][C][wifi:443]: WiFi:
[21:35:03][C][wifi:303]: SSID:
[redacted]
[21:35:03][C][wifi:304]: IP Address: 192.168.178.92
[21:35:03][C][wifi:306]: BSSID:
[redacted]
[21:35:03][C][wifi:307]: Hostname: 'esphome92'
[21:35:03][C][wifi:311]: Signal strength: -50 dB ▂▄▆█
[21:35:03][C][wifi:315]: Channel: 8
[21:35:03][C][wifi:316]: Subnet: 255.255.255.0
[21:35:03][C][wifi:317]: Gateway: 192.168.178.1
[21:35:03][C][wifi:318]: DNS1: 192.168.178.60
[21:35:03][C][wifi:319]: DNS2: (IP unset)
[21:35:03][C][gpio.binary_sensor:015]: GPIO Binary Sensor 'Sonoff Basic Button'
[21:35:03][C][gpio.binary_sensor:016]: Pin: GPIO0 (Mode: INPUT_PULLUP, INVERTED)
[21:35:03][C][switch.gpio:042]: GPIO Switch 'Sonoff Basic Relay'
[21:35:03][C][switch.gpio:043]: Pin: GPIO12 (Mode: OUTPUT)
[21:35:03][C][switch.gpio:059]: Restore Mode: Restore (Defaults to OFF)
[21:35:03][C][logger:185]: Logger:
[21:35:03][C][logger:186]: Level: DEBUG
[21:35:03][C][logger:187]: Log Baud Rate: 115200
[21:35:03][C][logger:188]: Hardware UART: UART0
[21:35:04][C][dallas.sensor:072]: DallasComponent:
[21:35:04][C][dallas.sensor:073]: Pin: GPIO14 (Mode: INPUT)
[21:35:04][C][dallas.sensor:074]: Update Interval: 60.0s
[21:35:04][D][dallas.sensor:079]: Found sensors:
[21:35:04][D][dallas.sensor:082]: 0xD20114330C912828
[21:35:04][C][dallas.sensor:087]: Device 'esphome92 Temperature'
[21:35:04][C][dallas.sensor:087]: Unit of Measurement: '°C'
[21:35:04][C][dallas.sensor:087]: Accuracy Decimals: 1
[21:35:04][C][dallas.sensor:087]: Icon: 'mdi:thermometer'
[21:35:04][C][dallas.sensor:089]: Index 0
[21:35:04][C][dallas.sensor:095]: Address: 0xD20114330C912828
[21:35:04][C][dallas.sensor:096]: Resolution: 12
[21:35:04][C][captive_portal:169]: Captive Portal:
[21:35:04][C][ota:029]: Over-The-Air Updates:
[21:35:04][C][ota:030]: Address: esphome92.lan:8266
[21:35:04][C][ota:032]: Using Password.
[21:35:04][C][api:095]: API Server:
[21:35:04][C][api:096]: Address: esphome92.lan:6053
[21:35:26][D][binary_sensor:036]: 'Sonoff Basic Button': Sending state ON
[21:35:26][D][switch:029]: 'Sonoff Basic Relay' Toggling ON.
[21:35:26][D][switch:045]: 'Sonoff Basic Relay': Sending state ON
[21:35:27][D][binary_sensor:036]: 'Sonoff Basic Button': Sending state OFF
[21:35:28][D][binary_sensor:036]: 'Sonoff Basic Button': Sending state ON
[21:35:28][D][switch:029]: 'Sonoff Basic Relay' Toggling OFF.
[21:35:28][D][switch:045]: 'Sonoff Basic Relay': Sending state OFF
[21:35:28][D][binary_sensor:036]: 'Sonoff Basic Button': Sending state OFF
[21:35:29][D][binary_sensor:036]: 'Sonoff Basic Button': Sending state ON
[21:35:29][D][switch:029]: 'Sonoff Basic Relay' Toggling ON.
[21:35:29][D][switch:045]: 'Sonoff Basic Relay': Sending state ON
[21:35:29][D][binary_sensor:036]: 'Sonoff Basic Button': Sending state OFF
A weird observation: As soon as I stop using the “log” from the device in the ESPhome integration, the build-in LED of the sonoff basic starts blinking with a ~ 1Hz frequency.
