I have a z-wave wall dimmer ZDB5400 that is not working right. I can turn on and off or dim the light locally with the buttons on the dimmer, but when I try to turn it on or off or dim it from homeassistant, nothing happens. Communication seems to be ok both because I get updates in homeassistant for current state on/off and dim level when I dim using the buttons on the device and because I can make configuration changes from the z-wave js 2 mqtt ui that take effect immediately.
In an attempt to troubleshoot, I turned on logging and this is a part of the log for when changing the dimmer from homeassistant.
2022-09-13T09:20:00.686Z CNTRLR [Node 013] [setValue] calling SET_VALUE API MultilevelSwitchCCAPI:
property: targetValue
property key: undefined
optimistic: true
2022-09-13T09:20:00.703Z SERIAL » 0x011800a9010d0c600d00056c01a004260132ff25000000001535 (26 bytes)
2022-09-13T09:20:00.705Z DRIVER » [Node 013] [REQ] [SendDataBridge]
│ source node id: 1
│ transmit options: 0x25
│ callback id: 21
└─[MultiChannelCCCommandEncapsulation]
│ source: 0
│ destination: 5
└─[SupervisionCCGet]
│ session id: 32
│ request updates: true
└─[MultilevelSwitchCCSet]
target value: 50
duration: default
2022-09-13T09:20:00.711Z SERIAL « [ACK] (0x06)
2022-09-13T09:20:00.713Z SERIAL « 0x010401a90152 (6 bytes)
2022-09-13T09:20:00.715Z SERIAL » [ACK] (0x06)
2022-09-13T09:20:00.716Z DRIVER « [RES] [SendDataBridge]
was sent: true
2022-09-13T09:20:00.865Z SERIAL « 0x011d00a91500000e01a07f7f7f7f02010309000000010100007f7f7f7f7f87 (31 bytes)
2022-09-13T09:20:00.866Z SERIAL » [ACK] (0x06)
2022-09-13T09:20:00.867Z DRIVER « [REQ] [SendDataBridge]
callback id: 21
transmit status: OK, took 140 ms
repeater node IDs: 9
routing attempts: 1
protocol & route speed: Z-Wave, 9.6 kbit/s
ACK RSSI: -96 dBm
ACK RSSI on repeaters: N/A
ACK channel no.: 2
TX channel no.: 1
2022-09-13T09:20:02.050Z CNTRLR [Node 013] Timed out while waiting for a response from the node (ZW0201)
2022-09-13T09:20:02.052Z CNTRLR [Node 013] [translateValueEvent: value updated]
commandClass: Multilevel Switch
endpoint: 5
property: currentValue
propertyKey: undefined
internal: false
secret: false
event source: undefined
2022-09-13T09:20:02.052Z CNTRLR [Node 013] [~] [Multilevel Switch] currentValue: 99 => 50 [Endpoint 5]
2022-09-13T09:20:02.053Z CNTRLR [Node 013] [translateValueEvent: value updated]
is root endpoint: false
is application CC: true
should hide root values: true
2022-09-13T09:20:02.055Z CNTRLR [Node 013] [setValue] result of SET_VALUE API call for MultilevelSwitchCCAPI:
undefined
2022-09-13T09:20:02.056Z CNTRLR [Node 013] [setValue] updating value with event
2022-09-13T09:20:02.056Z CNTRLR [Node 013] [translateValueEvent: value updated]
endpoint: 5
internal: false
secret: false
event source: driver
2022-09-13T09:20:02.057Z CNTRLR [Node 013] [translateValueEvent: value updated]
2022-09-13T09:20:07.064Z SERIAL » 0x011200a9010d06600d0005260225000000001631 (20 bytes)
2022-09-13T09:20:07.065Z DRIVER » [Node 013] [REQ] [SendDataBridge]
│ source node id: 1
│ callback id: 22
│ source: 0
│ destination: 5
└─[MultilevelSwitchCCGet]
2022-09-13T09:20:07.074Z SERIAL « [ACK] (0x06)
2022-09-13T09:20:07.077Z SERIAL « 0x010401a90152 (6 bytes)
2022-09-13T09:20:07.078Z SERIAL » [ACK] (0x06)
2022-09-13T09:20:07.079Z DRIVER « [RES] [SendDataBridge]
was sent: true
2022-09-13T09:20:07.215Z SERIAL « 0x011d00a91600000d01a07f7f7f7f02010309000000010100007f7f7f7f7f87 (31 bytes)
2022-09-13T09:20:07.216Z SERIAL » [ACK] (0x06)
2022-09-13T09:20:07.217Z DRIVER « [REQ] [SendDataBridge]
callback id: 22
transmit status: OK, took 130 ms
routing attempts: 1
ACK RSSI: -96 dBm
ACK channel no.: 2
TX channel no.: 1
2022-09-13T09:20:08.383Z CNTRLR [Node 013] Timed out while waiting for a response from the node (ZW0201)
When I instead go for changing a configuration parameter, things look ok:
2022-09-13T09:25:02.939Z CNTRLR [Node 013] [setValue] calling SET_VALUE API ConfigurationCCAPI:
property: 26
property key: 16711680
optimistic: true
2022-09-13T09:25:03.125Z SERIAL » 0x012400a9010d189f033e00d2b616c65d2c061faa5c3ee4a54aeee2a6d21c37250 (38 bytes)
000000019b4
2022-09-13T09:25:03.127Z DRIVER » [Node 013] [REQ] [SendDataBridge]
│ source node id: 1
│ callback id: 25
└─[Security2CCMessageEncapsulation]
│ sequence number: 62
│ session id: 34
└─[ConfigurationCCSet]
parameter #: 26
reset to default: false
value size: 4
value format: UnsignedInteger
value: 17124096
2022-09-13T09:25:03.136Z SERIAL « [ACK] (0x06)
2022-09-13T09:25:03.138Z SERIAL « 0x010401a90152 (6 bytes)
2022-09-13T09:25:03.140Z SERIAL » [ACK] (0x06)
2022-09-13T09:25:03.142Z DRIVER « [RES] [SendDataBridge]
was sent: true
2022-09-13T09:25:03.336Z SERIAL « 0x011d00a91900001301a17f7f7f7f02010309000000010100007f7f7f7f7f97 (31 bytes)
2022-09-13T09:25:03.337Z SERIAL » [ACK] (0x06)
2022-09-13T09:25:03.338Z DRIVER « [REQ] [SendDataBridge]
callback id: 25
transmit status: OK, took 190 ms
routing attempts: 1
ACK RSSI: -95 dBm
ACK channel no.: 2
TX channel no.: 1
2022-09-13T09:25:03.487Z SERIAL « 0x011a00a800010d119f03b60079c66de3a0c3ad10379d40ee2d00a01c (28 bytes)
2022-09-13T09:25:03.491Z SERIAL » [ACK] (0x06)
2022-09-13T09:25:03.492Z DRIVER « [Node 013] [REQ] [BridgeApplicationCommand]
│ RSSI: -96 dBm
│ sequence number: 182
└─[SupervisionCCReport]
session id: 34
more updates follow: false
status: Success
duration: 0s
2022-09-13T09:25:03.497Z CNTRLR [Node 013] [setValue] result of SET_VALUE API call for ConfigurationCCAPI: (Su
pervisionResult)
status: Success
2022-09-13T09:25:03.497Z CNTRLR [Node 013] [setValue] updating value with event
2022-09-13T09:25:03.498Z CNTRLR [Node 013] [translateValueEvent: value updated]
commandClass: Configuration
endpoint: 0
property: 26
propertyKey: 16711680
internal: false
secret: false
2022-09-13T09:25:03.499Z CNTRLR [Node 013] [translateValueEvent: value updated]
is root endpoint: true
I do not understand why communication works for configuration changes yet does not work for dimming commands. Any help solving this would be much appreciated!
