Need help decyphering Home Assistant log to locate device reporting runner.py:238 error
I am new to home assistant. I can’t attach the log file per ha regulation
I have the log file and would be glad to send to anybody that wants to help. I just need your email address. Ty so much-Mark
Issue:
I am receiving this error source: runner.py:238 (once a hour)
Things I’ve tried:
  1. Deleted custom_components folder that somehow loaded all the genmon files when I setup the Generac generator last year. Rebooted ha. Result- no luck.
  2. Added code in confirguration.yaml :
Log- default :critical.
(Works but masking issue)I want to fix right.
Attached screen shot of log
From what I can tell, the error is that the genmon integration isn't disconnecting like Home Assistant is expecting it to. As I don't use a Generac brand generator here, I can't go much beyond that.
