I have 4 DS18B20 measuring Temperatures of my Heatingsystem and Solarthermie,
the Automation i use in HA works, but i want to move this direktly into ESPHome because it must run
by itself, even if HA doesn’t work.
So i need help writing an Automation in ESPHome, can someone help me?
here the HA Automation:
TurnOn:
alias: Heizung Sonnenkollektor warm
description: ''
- platform: numeric_state
entity_id: sensor.sonnenkollektor_temp
value_template: >-
{{ states('sensor.sonnenkollektor_temp')|float(0) -
states('sensor.ruecklauf_heizkoerper_temp')|float(0) }}
above: 27
- type: turn_on
device_id: 522e4952768a46569d6810551128cfd2
entity_id: switch.switch_4_2
domain: switch
- type: turn_on
entity_id: switch.switch_5_2
domain: switch
- type: turn_off
entity_id: switch.switch_6_2
domain: switch
- type: turn_on
entity_id: switch.switch_7_2
domain: switch
mode: parallel
max: 500
TurnOff:
alias: Heizung Sonnenkollektor kalt
description: ''
below: sensor.ruecklauf_heizkoerper_temp
- type: turn_off
domain: switch
- type: turn_off
domain: switch
- type: turn_on
domain: switch
- type: turn_off
domain: switch
mode: parallel
max: 500
At the moment this is my ESPHome Config:
esphome:
platform: ESP8266
board: d1_mini
logger:
api:
password: "xxxx"
ota:
password: "xxxx"
wifi:
networks:
- ssid: "xxxx"
password: "xxxx"
- ssid: "xxxx"
password: "xxxx"
- ssid: "xxxx"
password: "xxxx"
manual_ip:
static_ip: 192.168.3.18
gateway: 192.168.2.1
subnet: 255.255.252.0
web_server:
port: 80
dallas:
- pin: GPIO05
update_interval: 10s
- platform: dallas
# Kollektor Sensor 1
address: 0xc8672ae90264ff28
filters:
- filter_out: nan
- platform: dallas
# Rücklauf Kessel Sensor 2
address: 0x295b94bf0164ff28
name: "Ruecklauf Kessel Temp"
filters:
- filter_out: nan
- platform: dallas
# Rücklauf Heizkörper Sensor 3
address: 0x4e8965b90164ff28
name: "Ruecklauf Heizkoerper Temp"
filters:
- filter_out: nan
- platform: dallas
# Vorlauf Kessel Sensor 4
address: 0x206b61b90164ff28
name: "Vorlauf Kessel Temp"
filters:
- filter_out: nan
spi:
clk_pin: 14
mosi_pin: 13
display:
- platform: max7219
cs_pin: 04
num_chips: 1
intensity: 2
lambda: |-
it.printf(0, " ");
it.printf(1, "%.1f", id(DS18B20_KOLLEKTOR).state);
it.printf(4, " ");
it.printf(5, "%.1f", id(DS18B20_RUECKLAUF_HEIZKOERPER).state);
