Need help go-e charger power control
i would like to control the power of my wallbox (go-e charger) but somehow i can’t do it with the automation. If I enter this it works
service: goecharger.set_max_current
  max_current: 6
with the formula the correct result comes out in services but nothing happens in the automation - thank you very much for your help.
 max_current: {{ states('sensor.goecharger_wallbox_charger_max_current')|float + 1 }}
solved
  max_current: '{{ states(''sensor.goecharger_wallbox_charger_max_current'')|float + 1 }}'
This is not working for me. The value in the Charger is set to maximum (e.g.: 32).
I use firmware: 56.1.
Any Idea?
