Need Help Have two modbus humidity sensors running same buzzer script on value range, have a button on press disbling the buzzer for 15 minutes running script but if sensor value changes it bypasses the mute how to compile code?
Need Help Have two Modbus surface humidity sensors running same buzzer script on value range, have a button on press disabling the buzzer for 15 minutes running on script but if sensor value changes it bypasses the mute and continues to go off, I want to be able to press the button and mute the buzzer and ignore sensore value changes but still be able to use the button because i have a double press to restart the esp32 . if anyone can help or point me in right direction?
 esphome:
  friendly_name: esp32
  on_boot:
      priority: 500
      then:
        - delay: 500ms
        - lambda: |-
            id(modbus_value).publish_state(0.0);
            id(modbus_value2).publish_state(0.0);
 esp32:
  board: esp32-s3-devkitc-1
  cpu_frequency: 160MHZ
  framework:
    type: esp-idf
 globals:
  - id: buzzer_locked_out
    type: bool
    initial_value: "false"
  - id: last_sensor_1_value
    type: float
    restore_value: true
    initial_value: "0.0"
  - id: last_sensor_2_value
    type: float
    restore_value: true
# Enable logging
 logger:
 #Enable Home Assistant API
 api:
  reboot_timeout: 0s
  encryption:
   key: "rtliFhRg9XMooTHhaMqI9BQNx042QjbcAQ1Gvi9L5zU="
 ota:
  - platform: esphome
    password: "028d130b722b21e478343843e0b70972"
 #wifi:
 # ssid: SkyNet831
 # password: recon831
 # power_save_mode: none
 #time:
  #- platform: sntp
 #   id: sntp_time
  #  timezone: US/Pacific
  #  servers:
   #   - 0.pool.ntp.org
   #   - 1.pool.ntp.org
   #   - 2.pool.ntp.org
 ethernet:
  setup_priority: 250
  type: W5500
  clk_pin: GPIO13
  mosi_pin: GPIO11
  miso_pin: GPIO12
  cs_pin: GPIO14
  interrupt_pin: GPIO10
  reset_pin: GPIO9
 script:
  - id: buzzer
    mode: queued
    then:
      - rtttl.play:              "two_short:d=4,o=5,b=100:16e6,16e6,16e6,16e6"                                   ##"Death March:d=6,o=5,b=100,b=100:4c,16p,c,8c,32p,2c,d#,8d,32p,d,8c,32p,c,8b4,32p,2c"                        #"SOS:d=8,o=5,b=100:8c,8c,8c,4p,4c,4c,4c,4p,8c,8c,8c"
      - delay: 500ms
  - id: buzzersiren
    mode: queued
    then:
      - rtttl.play:  "two_short:d=9,o=1,b=70:16e6,16e6"  #     "siren:d=6,o=9,b=150:d,e,d,e,d,e,d,e"
      - delay: 2000ms
      - script.execute: buzzersiren
  - id: mute_buzzer
    mode: Restart # Restart the script (and the timer) if the button is pressed again
    then:
      # Step 1: Turn off the buzzer.
      - script.stop: buzzersiren
      - switch.turn_off: buzzer_output0
      # Step 2: Log the mute event for confirmation.
      - logger.log: "Buzzer muted for 15 minutes"
      # Step 3: Wait for 15 minutes.
      - delay: 15min
      # Step 4: After the delay, log that the buzzer is unmuted and turn it back on.
      - logger.log: "Buzzer unmuted"
      - switch.turn_on: buzzer_output0
  - id: lightleds
    mode: restart
    then:
      # dot-dot-dot
      - light.turn_on:  my_red_led_output
      - delay: 400ms
      - light.turn_off: my_red_led_output
      - delay: 400ms
      - delay: 400ms
      - delay: 400ms
      - delay: 400ms
      - delay: 400ms
      # dash-das-dash
      - delay: 800ms
      - delay: 400ms
      - delay: 600ms
      - delay: 400ms
      - delay: 600ms
      - delay: 400ms
      # dot-dot-dot
      - delay: 400ms
      - delay: 400ms
      - delay: 400ms
      - delay: 400ms
      - delay: 400ms
      - delay: 400ms
      - delay: 400ms
      - script.execute: lightleds
 output:
 - platform: ledc
   pin: GPIO36
   max_power: 1.0
   #frequency: 35Hz
 - platform: ledc  # Or esp8266_pwm for ESP8266
   pin: GPIO37  # Replace with your ESP32's GPIO pin
   frequency: 1500Hz # Set a base frequency
 - platform: ledc
   pin: GPIO35
   max_power: 1.0
   #frequency: 30Hz
 rtttl:
   output: rtttl_out
   on_finished_playback:
     - logger.log: "Song ended!"
   gain: 80.0%
 switch:
    #restore_mode: DISABLED
    setup_priority: 500
    #output: buzzer_output
    turn_on_action:
    turn_off_action:
      - rtttl.stop:
  - platform: restart
    name: "My Device Restart"
    # This switch will be exposed to Home Assistant
    # To restart, you can simply toggle the switch in HA
  - platform: gpio
    pin: GPIO15
    on_turn_on:
      - delay: 2000ms
    on_turn_off:
      - delay: 1000ms
    setup_priority: 400
    #restore_mode: ALWAYS_ON
    # Use lambda to call the turn_on() and turn_off() methods on your display ID
    turn_on_action:
      - lambda: |-
          id(mydisplay).turn_on();
    turn_off_action:
      - delay: 15s
      - lambda: |-
          id(mydisplay).turn_off();
 light:
 - platform: monochromatic
   output: GPIO_36
   output: GPIO_35
   effects:
    - flicker:
        alpha: 100%
        intensity: 50%
  # restore_mode: ALWAYS_ON
#rs485-ttl
 uart:
   tx_pin: GPIO43
   rx_pin: GPIO44
   baud_rate: 9600
   stop_bits: 1
   data_bits: 8
   parity: NONE
 modbus:
 - uart_id : uart_sensor
   #flow_control_pin: GPIO3
   send_wait_time: 2000ms
 modbus_controller:
 - id: modbus_uartsensor1
   address: 0x01
   modbus_id: modbus1
   setup_priority: 600
   update_interval: 1s
   allow_duplicate_commands: True
   offline_skip_updates: 5
   command_throttle: 100ms
 - id: modbus_uartsensor2
   address: 0x02
   modbus_id: modbus1
   setup_priority: 600
   update_interval: 2s
   offline_skip_updates: 1
   command_throttle: 2000ms
 i2c:
  sda: GPIO47
  scl: GPIO48
  frequency: 800kHz
 font:
  - file: "gfonts://Roboto"
  - file: "gfonts://Roboto" # Use your font filename
    glyphs:
      - "0123456789.:"
      - "°F"
 display:
  - platform: ssd1306_i2c
    setup_priority: 800
    model: "SSD1306 128x64"
    contrast: 40%
    address: 0x3C
    lambda: |-
      it.printf(0, 5, id(my_font1), TextAlign::TOP_LEFT, " ___________________________________");
      it.printf(51, 0, id(my_font1), TextAlign::TOP_LEFT, "MIRA");
      it.printf(100, 45, id(my_font2), TextAlign::TOP_LEFT, "");
      it.printf(13, 45, id(my_font2), TextAlign::TOP_LEFT, "");
      it.printf(125, 27, id(my_font2), TextAlign::TOP_RIGHT , "%.1f%", id(modbus_value).state);
      it.printf(45, 27, id(my_font2), TextAlign::TOP_RIGHT , "%.1f%", id(modbus_value2).state);
      it.printf(53, 60, id(my_font3), TextAlign::BASELINE_LEFT, "%.1f%%", id(sht4xRH).state);
      it.printf(53, 51, id(my_font3), TextAlign::BASELINE_LEFT, "%.1f°F", id(sht4xtemperature).state);
      it.printf(95, 15, id(my_font3), TextAlign::TOP_LEFT, "FORK");
      it.printf(8, 15, id(my_font3), TextAlign::TOP_LEFT, "FLOOR");
      it.printf(3, 59, id(my_font4), TextAlign::BASELINE_LEFT ,"%.1f°F", id(my_internal_temp).state);
  - platform: modbus_controller
    modbus_controller_id: modbus_uartsensor1
    address: 0x20
    register_type: holding
    register_count: 1
    icon: "mdi:water-percent"
    device_class: "moisture"
    unit_of_measurement: "%"
    skip_updates: 1
    #value_type: FP32
    value_type: U_WORD
    accuracy_decimals: 0
    filters:
      - lambda: return x * 0.3;
    on_value_range:
      - below: 5
        then:
           - switch.turn_off: oledswitch
           - rtttl.stop:
           - script.stop: lightleds
           #- switch.turn_off: buzzer_output0
           - light.turn_off: blue_led
      - above: 60
        then:
           - light.turn_on: blue_led
      - below: 60
        then:
          # - switch.turn_on: oledswitch
           #- script.execute: buzzersiren
          # - script.stop: buzzersiren
      - above: 5
        below: 100
        then:
           #- switch.turn_on: buzzer_output0
           #- switch.turn_on: oledswitch
      - above: 5
        below: 300
        then:
    modbus_controller_id: modbus_uartsensor2
    address: 0x20
    skip_updates: 1
    register_count: 1
    value_type:  U_WORD
    filters:
    on_value_range:
      - below: 5
        then:
           - rtttl.stop:
      - above: 60
        then:
      - below: 60
        then:
      - above: 5
        below: 100
        then:
      - above: 5
        below: 300
        then:
  - platform: sht4x
    setup_priority: 600
    update_interval: 1s
    temperature:
     filters:
      - lambda: return x * (9.0/5.0) + 32.0;
     unit_of_measurement: "°F"
     on_value_range:
      - above: 89.0
        then:
          - switch.turn_on: fan
      - below: 84.90
        then:
          - switch.turn_off: fan
    humidity:
     on_value_range:
      - above: 95
        then:
      - below: 85
        then:
  - platform: internal_temperature
    name: "Internal Temperature"
    update_interval: 1s
    internal: False # Prevents the sensor from being published to Home Assistant
    filters:
    on_value_range:
      - above: 150
        then:
      - below: 130
        then:
 binary_sensor:
  - platform: gpio
    setup_priority: 800
    pin:
      number: GPIO3
      mode: INPUT_PULLUP
      inverted: true
    on_press:
      then:
      - script.execute: mute_buzzer
    on_double_click:
     min_length: 50ms
     max_length: 350ms
     then:
       - delay: 3s
       - switch.turn_on: my_device_restart
    on_multi_click:
    - timing:
        - ON for 1s to 2s
        - OFF for at least 0.5s
      then:
        - delay: 1min
Never tried conditions?
You can also record when it is turned off manually in a helper, and any logic you have that turns it back on, add an if statement to check that helper value such that it will not turn back on unless the time you have saved in the helper is more than 15 minutes ago. I do this kind of logic a large number of places for a variety of reasons. You can even have that 15 minutes stored in a helper and then shown as a sllider in your dashboard so the 15 minutes is not hard coded, but adjustable on the fly.
