Need help how to set switch on HAdashborad
Hello guys
I install and config HAdashborad and try to understand how to work With .dash file
I have Sonoff switch that work using Mqtt ,and I like to add this switch to my dashboard that will display on my
tablet .
The are some explanation how I do it and what is the code I need to put in dash file?
How I build the dash file that show time and more?
You could take a look at the dasboard creation docs here:
http://appdaemon.readthedocs.io/en/latest/DASHBOARD_CREATION.html
That is good thanks my friend
One more thing the entity I need to use on dash file for the switch is the same name I use for the switch on configuration.yeml?
AppDaemon uses the same entity names as HomeAssistant, yes.
