Need help setting up irrigation control system
Hey Everybody,
I’m in need of some advice, mostly hardware. So I hope im in the right part of the forum.
The situation is the following. I have a groundwater pump, it operates very simply. Power = water, no power = no water. It’s connected to two water wells. These wells provide our horse arena and round pen with water. This way you do not have to spray from above, but you can feed water from below. The water well has an overflow, so when it rains water runs away and when it’s too dry you can fill it. That way the horse arena is always at the right level.
Now I would like to automate this whole setup and preferably with HA. Ideally I would like to get sensors in both wells, so that when the water level gets to low, it starts up the water pump. But in addition it will need to controle a valve, because otherwise if one well has too low level it will fill both wells.
Are there any recommendations in hardware to realize a setup this?
Any help is welcome.
