Am I wrong or is homeassistant not able to translate this type of json response:
"{\"DeviceResponse\":[{\"DeviceID\":\"
Cheers
Cheers
Could you please provide a bit more context? That sample snippet is clearly not valid JSON.
it’s not json, it starts with a " its a string. Most likely there isn’t valid json later on in the response, but you only posted the first 50 characters. If that’s the entire response, then it’s definitely not valid for many reasons.
You can always use this website to check if json is valid before event attempting to use it in home assistant.
Also, WTH is not for support. Moving this to configuration.
That looks like a string that has encapsulated JSON within it. Fairly common in web responses but certainly not ideal. You’ll need to take the string pass it into a JSON parser.
This is the whole response:
"{\"DeviceResponse\":[{\"DeviceID\":\"5167877\",\"DeviceName\":\"Heizung\",\"Medium\":\"Ă–l\",\"LastUpdate\":\"10/1/2022 8:00:02 AM\",\"MaxVolume\":\"2000\",\"ActualVolume\":\"982\",\"ActualVolumePercent\":\"54\",\"Battery\":\"2.9\",\"Temperature\":\"68\",\"MessData\":\"96\"}]}"
I’m trying to get the data out of this with the following yaml:
name: 'proteus level sensor'
value_template: "OK"
json_attributes_path: "$.deviceresponse"
json_attributes:
- DeviceID
- DeviceName
- Medium
- LastUpdate
- MaxVolume
- ActualVolume
- ActualVolumePercent
- Battery
- Temperature
scan_interval: 120
Getting this error:
Logger: homeassistant.components.rest.sensor
Source: components/rest/sensor.py:170
Integration: RESTful (documentation, issues)
First occurred: 16:54:14 (1 occurrences)
Last logged: 16:54:14
JSON result was not a dictionary or list with 0th element a dictionary
because your response starts with “”, that’s not a dictionary its’ a string. Fix the response or use commandline to remove the first and last quote.
thx for your help! the response is generated from the sensor api. so no idea how or if i can fix this.
any hint on how to use commandline to remove the quotes?
didn’t made any progress as of today.
Logger says:
Data fetched from resource:
"{\"DeviceResponse\":[{\"DeviceID\":\"5167877\",\"DeviceName\":\"Heizung\",\"Medium\":\"Ă–l\",\"LastUpdate\":\"11/11/2022 8:00:02 AM\",\"MaxVolume\":\"2000\",\"ActualVolume\":\"1697\",\"ActualVolumePercent\":\"91\",\"Battery\":\"2.9\",\"Temperature\":\"69\",\"MessData\":\"27\"}]}"
yaml looks like this:
- platform: rest
resource: http://aes-gate-ecofrog.azurewebsites.net/Api/FuncDevice
method: POST
headers:
Content-Type: application/json
payload: '{DeviceRequest: {"Username": "xyz", "Email": "xyz", "SecurityStamp": "xyz", "DeviceID": "xyz"}}'
value_template: '{{ value_json }}'
And State in HA:
Can anyone help me with the correct value template to get the sensor states properly.
Put this in configuration.yaml. Do not put it in the sensor section.
rest:
- resource: http://aes-gate-ecofrog.azurewebsites.net/Api/FuncDevice
method: POST
headers:
- name: Heizung Max Volume
device_class: volume
unit_of_measurement: ftÂł
value_template: >
{% set name = 'Heizung' %}
{% set device = value_json.DeviceResponse | select('DeviceName', 'eq', name) | list | first | default({}) %}
{{ device.get('MaxVolume') }}
- name: Heizung Actual Volume
value_template: >
{{ device.get('ActualVolume') }}
- name: Heizung Actual Volume Percent
unit_of_measurement: %
value_template: >
{{ device.get('ActualVolumePercent') }}
- name: Heizung Battery
device_class: battery
value_template: >
{{ device.get('Battery') }}
- name: Heizung Temperature
device_class: temperature
unit_of_measurement: °F
value_template: >
{{ device.get('Temperature') }}
- name: Heizung Mess Data
value_template: >
{{ device.get('MessData') }}
Thank you very much for your help!!!
Sadly there’s still something wrong
Logger says:
2022-11-12 20:56:09.128 DEBUG (MainThread) [homeassistant.components.rest.sensor] Data fetched from resource: "{\"DeviceResponse\":[{\"DeviceID\":\"5167877\",\"DeviceName\":\"Heizung\",\"Medium\":\"Ă–l\",\"LastUpdate\":\"11/12/2022 8:00:02 AM\",\"MaxVolume\":\"2000\",\"ActualVolume\":\"1683\",\"ActualVolumePercent\":\"90\",\"Battery\":\"2.9\",\"Temperature\":\"69\",\"MessData\":\"28\"}]}"
2022-11-12 20:56:09.128 WARNING (MainThread) [homeassistant.helpers.template] Template variable warning: 'str object' has no attribute 'DeviceResponse' when rendering '{% set name = 'Heizung' %} {% set device = value_json.DeviceResponse | select('DeviceName', 'eq', name) | list | first | default({}) %} {{ device.get('MaxVolume') }}'
2022-11-12 20:56:09.130 DEBUG (MainThread) [homeassistant.components.rest.sensor] Data fetched from resource: "{\"DeviceResponse\":[{\"DeviceID\":\"5167877\",\"DeviceName\":\"Heizung\",\"Medium\":\"Ă–l\",\"LastUpdate\":\"11/12/2022 8:00:02 AM\",\"MaxVolume\":\"2000\",\"ActualVolume\":\"1683\",\"ActualVolumePercent\":\"90\",\"Battery\":\"2.9\",\"Temperature\":\"69\",\"MessData\":\"28\"}]}"
2022-11-12 20:56:09.131 WARNING (MainThread) [homeassistant.helpers.template] Template variable warning: 'str object' has no attribute 'DeviceResponse' when rendering '{% set name = 'Heizung' %} {% set device = value_json.DeviceResponse | select('DeviceName', 'eq', name) | list | first | default({}) %} {{ device.get('ActualVolume') }}'
2022-11-12 20:56:09.134 DEBUG (MainThread) [homeassistant.components.rest.sensor] Data fetched from resource: "{\"DeviceResponse\":[{\"DeviceID\":\"5167877\",\"DeviceName\":\"Heizung\",\"Medium\":\"Ă–l\",\"LastUpdate\":\"11/12/2022 8:00:02 AM\",\"MaxVolume\":\"2000\",\"ActualVolume\":\"1683\",\"ActualVolumePercent\":\"90\",\"Battery\":\"2.9\",\"Temperature\":\"69\",\"MessData\":\"28\"}]}"
2022-11-12 20:56:09.134 WARNING (MainThread) [homeassistant.helpers.template] Template variable warning: 'str object' has no attribute 'DeviceResponse' when rendering '{% set name = 'Heizung' %} {% set device = value_json.DeviceResponse | select('DeviceName', 'eq', name) | list | first | default({}) %} {{ device.get('ActualVolumePercent') }}'
2022-11-12 20:56:09.136 DEBUG (MainThread) [homeassistant.components.rest.sensor] Data fetched from resource: "{\"DeviceResponse\":[{\"DeviceID\":\"5167877\",\"DeviceName\":\"Heizung\",\"Medium\":\"Ă–l\",\"LastUpdate\":\"11/12/2022 8:00:02 AM\",\"MaxVolume\":\"2000\",\"ActualVolume\":\"1683\",\"ActualVolumePercent\":\"90\",\"Battery\":\"2.9\",\"Temperature\":\"69\",\"MessData\":\"28\"}]}"
2022-11-12 20:56:09.137 WARNING (MainThread) [homeassistant.helpers.template] Template variable warning: 'str object' has no attribute 'DeviceResponse' when rendering '{% set name = 'Heizung' %} {% set device = value_json.DeviceResponse | select('DeviceName', 'eq', name) | list | first | default({}) %} {{ device.get('Battery') }}'
2022-11-12 20:56:09.139 DEBUG (MainThread) [homeassistant.components.rest.sensor] Data fetched from resource: "{\"DeviceResponse\":[{\"DeviceID\":\"5167877\",\"DeviceName\":\"Heizung\",\"Medium\":\"Ă–l\",\"LastUpdate\":\"11/12/2022 8:00:02 AM\",\"MaxVolume\":\"2000\",\"ActualVolume\":\"1683\",\"ActualVolumePercent\":\"90\",\"Battery\":\"2.9\",\"Temperature\":\"69\",\"MessData\":\"28\"}]}"
2022-11-12 20:56:09.139 WARNING (MainThread) [homeassistant.helpers.template] Template variable warning: 'str object' has no attribute 'DeviceResponse' when rendering '{% set name = 'Heizung' %} {% set device = value_json.DeviceResponse | select('DeviceName', 'eq', name) | list | first | default({}) %} {{ device.get('Temperature') }}'
2022-11-12 20:56:09.141 DEBUG (MainThread) [homeassistant.components.rest.sensor] Data fetched from resource: "{\"DeviceResponse\":[{\"DeviceID\":\"5167877\",\"DeviceName\":\"Heizung\",\"Medium\":\"Ă–l\",\"LastUpdate\":\"11/12/2022 8:00:02 AM\",\"MaxVolume\":\"2000\",\"ActualVolume\":\"1683\",\"ActualVolumePercent\":\"90\",\"Battery\":\"2.9\",\"Temperature\":\"69\",\"MessData\":\"28\"}]}"
2022-11-12 20:56:09.142 WARNING (MainThread) [homeassistant.helpers.template] Template variable warning: 'str object' has no attribute 'DeviceResponse' when rendering '{% set name = 'Heizung' %} {% set device = value_json.DeviceResponse | select('DeviceName', 'eq', name) | list | first | default({}) %} {{ device.get('MessData') }}'
This goes back to my original response, you need to fix the incoming data. It’s not json.
