i have downloaded Frigate from HACS, and can see frigate from integration menu. frigate is running as a docker on my hose, HA is running as a VM.
I could access [frigate IP]:5000 and can access via API on a browser
but if i add [frigate IP]:5000 to the frigate integration, it prompt failed to connect.
im getting stuck and running around like a headless chicken, and if you guys could get me some advice to where to go from here for trouble shooting would be amazing
sorry that i confused you guys a little bit, I ran HA inside Unraid as a VM (192.168.66.5), the Frigate are setup via Docker in side Unraid (192.168.66.4),
i can access frigate via 192.168.66.4:8971
i can ping 192.168.66.4 within HA’s terminal
how can i verify if HA have access to 192.168.66.4:5000??
i have no idea why, but when HA connect to Frigate via port 5000 it has time out error, i am running out of ideas and end up reinstalling frigate, and it works…issue is gone but i have no clue…
