The display does not seem to be controlled correctly (all pixels shows white).
Note: The test output of the counter works with a completely different display (1.3 inch 4-pin oled I2C: ssd1306_i2c). Therefore, it must be related to the configuration or wiring of the new 2.8 inch display."
I would need some hints on what I could try to get the display working. Has anyone successfully controlled this display with ESPHome? Thank you in advance, Jarny.
Thank you for the reply. This was my fault. It was already the third or fourth try to get the display running with another driver or other settings.
Now I am switching back to the driver ST7735 which is not working but should at least be the correct driver. I also tried setting invert_colors to False.
Maybe the log helps to get more ideas:
[15:56:23][I][app:115]: ESPHome version 2025.5.0 compiled on May 24 2025, 15:56:00
[15:56:23][C][wifi:600]: WiFi:
[15:56:23][C][wifi:428]: Local MAC: 70:04:1D:36:DB:C4
[15:56:23][C][wifi:433]: SSID: [redacted]
[15:56:23][C][wifi:436]: IP Address: 192.168.6.172
[15:56:23][C][wifi:439]: BSSID: [redacted]
[15:56:23][C][wifi:441]: Hostname: 'devboard-c3neu'
[15:56:23][C][wifi:443]: Signal strength: -61 dB ▂▄▆█
[15:56:23][C][wifi:447]: Channel: 8
[15:56:23][C][wifi:448]: Subnet: 255.255.255.0
[15:56:23][C][wifi:449]: Gateway: 192.168.6.1
[15:56:23][C][wifi:450]: DNS1: 192.168.6.1
[15:56:23][C][wifi:451]: DNS2: 0.0.0.0
[15:56:23][C][logger:224]: Logger:
[15:56:23][C][logger:225]: Max Level: DEBUG
[15:56:23][C][logger:226]: Initial Level: DEBUG
[15:56:23][C][logger:228]: Log Baud Rate: 115200
[15:56:23][C][logger:229]: Hardware UART: USB_SERIAL_JTAG
[15:56:23][C][logger:233]: Task Log Buffer Size: 768
[15:56:23][C][spi:068]: SPI bus:
[15:56:23][C][spi:069]: CLK Pin: GPIO10
[15:56:23][C][spi:070]: SDI Pin:
[15:56:23][C][spi:071]: SDO Pin: GPIO6
[15:56:23][C][spi:076]: Using HW SPI: SPI2_HOST
[15:56:23][C][ili9xxx:091]: ili9xxx
[15:56:23][C][ili9xxx:091]: Rotations: 0 °
[15:56:23][C][ili9xxx:091]: Dimensions: 128px x 160px
[15:56:23][C][ili9xxx:092]: Width Offset: 0
[15:56:23][C][ili9xxx:093]: Height Offset: 0
[15:56:23][C][ili9xxx:099]: Color mode: 16bit
[15:56:23][C][ili9xxx:108]: Data rate: 40MHz
[15:56:23][C][ili9xxx:110]: Reset Pin: GPIO9
[15:56:23][C][ili9xxx:112]: DC Pin: GPIO8
[15:56:23][C][ili9xxx:114]: Color order: RGB
[15:56:23][C][ili9xxx:115]: Swap_xy: NO
[15:56:23][C][ili9xxx:116]: Mirror_x: NO
[15:56:23][C][ili9xxx:117]: Mirror_y: NO
[15:56:23][C][ili9xxx:118]: Invert colors: YES
[15:56:23][C][ili9xxx:123]: Update Interval: 5.0s
[15:56:23][C][mdns:120]: mDNS:
[15:56:23][C][mdns:121]: Hostname: devboard-c3neu
[15:56:23][C][esphome.ota:073]: Over-The-Air updates:
[15:56:23][C][esphome.ota:074]: Address: devboard-c3neu.local:3232
[15:56:23][C][esphome.ota:075]: Version: 2
[15:56:23][C][esphome.ota:078]: Password configured
[15:56:23][C][safe_mode:018]: Safe Mode:
[15:56:23][C][safe_mode:019]: Boot considered successful after 60 seconds
[15:56:23][C][safe_mode:021]: Invoke after 10 boot attempts
[15:56:23][C][safe_mode:022]: Remain in safe mode for 300 seconds
[15:56:23][C][api:170]: API Server:
[15:56:23][C][api:171]: Address: devboard-c3neu.local:6053
[15:56:23][C][api:178]: Using noise encryption: NO
[15:57:17][I][safe_mode:041]: Boot seems successful; resetting boot loop counter
I found the solution. There where several mistakes in my config.
In my setup I wired the display cs pin to ground. That doesnt work and after I configure the cs signal in the display config, wired the signal, the display shows random color pixels instead of the white pixels. After that I correct my other mistakes in my yaml: wrong display resolution and wrong color depth https://github.com/esphome/issues/issues/6772 !
Now my display setup look like that:
