Need help with adding Docker for the add-on
Hi Team,
I’m working on add-on and mostly done from coding perspective, but I’m having issues with adding proper scripts to make it running properly in a Docker container.
Let me please describe in more details:
  1. My add-on is a .net core application;
  2. The application itself needs MariaDb server - currently I’m using MariaDb add-on, but I would like to have database server inside my container;
  3. Currently I’m using Kestrel web server, but I would like to configure NGINX and use SSL to secure the connection.
So all in all I have the application running, here is for example the configuration I’m currently have and it is working:
But as I said, I am struggling to bring NGINX with SSL and MariaDb into my Docker… :frowning:
I tried to follow script of the community add-ons, and I took the following one as an example - https://github.com/hassio-addons/addon-bookstack - and here is how the scripts are looking like after trying to reproduce the approach:
And then things get more complicated with /etc folder:
But I can’t make it working unfortunately… and it is missing MariaDb which I’m also not sure how to configure properly using the above approach.
I would really appreciate if someone can help me with gaining this knowledge…
Thanks a lot
Team,
I sorted it out - if somebody will have the same issue with building the container, I might help if needed.
