Need help with an automation blueprint: "TypeError: 'int' object is not iterable"
I am trying to create a light automation blueprint, which changes light brightness, temperature and color depending on presence, time and current room illuminance.
I have a pretty good idea how to do it, but in the moment, the automation generated by the blueprint doesn’t even start. :worried:
I am a seasoned C# developer but completely new to python. I have stripped down the blueprint to isolate the error and now I am stuck with the error
"TypeError: 'int' object is not iterable".
I don’t see any code where I try to iterate an int variable.
Here comes the complete trace with the error and the automation config:
  "trace": {
    "last_step": null,
    "run_id": "ab87b02b8e864e1c3a9ab2e5502d24b4",
    "state": "stopped",
    "script_execution": null,
    "timestamp": {
      "start": "2025-11-13T17:57:54.050867+00:00",
      "finish": "2025-11-13T17:57:54.051606+00:00"
    "domain": "automation",
    "item_id": "1763056465127",
    "error": "TypeError: 'int' object is not iterable",
    "trigger": null,
    "trace": {},
    "config": {
      "mode": "restart",
      "variables": {
        "target_lux": 300,
        "motion_timeout": 1,
        "light_entity": [
          "light.box_rechts"
        "motion_entity": [
          "binary_sensor.prasenzmelder_buro_uli_anwesenheit"
        "lux_entity": "sensor.prasenzmelder_buro_uli_beleuchtungsstarke",
        "current_lux": "{{ states[lux_entity].state | float(0) }}",
        "lux_deficit": "{{ [0, target_lux - current_lux] | max }}",
        "required_brightness": "{{ (lux_deficit / target_lux * 255) | int | min(255) }}"
      "triggers": [
          "trigger": "state",
          "entity_id": [
          "to": "on",
          "id": "motion_detected"
          "trigger": "state",
          "entity_id": [
          "to": "off",
          "for": {
            "minutes": "{{ motion_timeout }}"
          "id": "motion_timeout"
          "trigger": "time_pattern",
          "minutes": "/5",
          "id": "periodic_update"
          "trigger": "state",
          "entity_id": "sensor.prasenzmelder_buro_uli_beleuchtungsstarke",
          "id": "lux_changed"
      "actions": [
          "choose": [
              "alias": "Bewegung erkannt oder zu dunkel -> Licht an/anpassen",
              "conditions": [
                  "or": [
                      "condition": "trigger",
                      "id": "lux_changed"
                  "condition": "template",
                  "value_template": "{{ current_lux < target_lux }}"
              "sequence": [
                  "if": [
                      "value_template": "{{ required_brightness > 0 }}"
                  "then": [
                      "action": "light.turn_on",
                      "target": {
                        "entity_id": "{{ light_entity }}"
                      "data": {
                        "brightness": "{{ required_brightness }}",
                        "color_temp_kelvin": 3000,
                        "transition": 2
                  "else": [
                      "action": "light.turn_off",
                      "target": {
                      "data": {
                        "transition": 2
              "alias": "Es ist hell genug -> Licht aus",
              "conditions": [
                  "value_template": "{{ current_lux > target_lux }}"
              "sequence": [
                  "target": {
                  "data": {
                    "transition": 5
              "alias": "Bewegungs-Timeout -> Licht aus",
              "conditions": [
              "sequence": [
                  "target": {
                  "data": {
                    "transition": 3
      "conditions": [],
      "id": "1763056465127",
      "alias": "Auto Light White",
      "description": ""
    "blueprint_inputs": {
      "description": "",
      "use_blueprint": {
        "path": "homeassistant/autolight_white.yaml",
        "input": {
          "light_target": [
            "light.box_rechts"
          "motion_sensor": [
          "lux_sensor": "sensor.prasenzmelder_buro_uli_beleuchtungsstarke",
          "motion_timeout": 1
    "context": {
      "id": "01K9Z5VS82APTSQQ11SNQX9BGY",
      "parent_id": "01K9Z5VS82NEKKKKCSXYM2MT7H",
      "user_id": null
  "logbookEntries": []
we need to see the blueprint and the inputs you’re using for each input.
And we need to see the full traceback from the logs.
I’d wager this is your problem though.
You’re trying to execute min on an integer. If you’re trying to min between the value and your calculation it would be
{{ [(lux_deficit / target_lux * 255) | int, 255] | min }}
Thank you @petro, you saved my day! :joy: :relieved:
I really need to better understand the python details.
That’s not python, that’s jinja
Oh great! Another layer. :grimacing:
You don’t need to know python at all to use home assistant. So clear that from your mind. Learn Jinja and the objects available in jinja for templates. Learn yaml as well. Understand the differences between the 2.
OK, good to learn this.
I know YAML from Azure DevOps quite well, but Jinja still confuses me.
Thank you for guiding me in the right direction.
