I have simple code with two autodiscovery objects.
One is sensor - it’s work without problems.
But second is number (slider).
I don’t know why but always I have publish failed. MQTT Explorer doesn’t show this topic, payload.
Connection to mqtt broker is working.
Can anyone help me?
Code on esp8266 Arduino, pubsubclient library.
#define MQTT_MAX_PACKET_SIZE = 512;
const char* device_id = "schodyDuze";
const char* hass_prefix = "homeassistant";
const char* topic_jasnoscLED = "schodyDuze/jasnoscLED";
String discTopic = String(hass_prefix) + "/number/" + String(device_id) + "_jasnoscLED/config";
StaticJsonDocument<512> doc;
doc["name"] = "SchodyDuze Jasnosc LED";
doc["unique_id"] = String(device_id) + String("_jasnoscLED");
doc["state_topic"] = String(topic_jasnoscLED);
doc["command_topic"] = String(topic_jasnoscLED) + "/set";
doc["platform"] = "number";
doc["min"] = 10;
doc["max"] = 100;
doc["step"] = 5;
doc["mode"] = "slider";
doc["unit_of_measurement"] = "%";
JsonObject device = doc.createNestedObject("device");
JsonArray identifiers = device.createNestedArray("identifiers");
identifiers.add(String(device_id));
device["name"] = String(device_id);
String payload; serializeJson(doc, payload);
Serial.println(discTopic);
Serial.println(payload);
Serial.print("Payload length: ");
Serial.println(payload.length());
if(client.publish(discTopic.c_str(), payload.c_str(), true))
Serial.println("Published successfully");
else
Serial.println("Publish failed");
