Need Help With Automation Comparing Sensor Value Now To Sensor Value An Hour Ago
I’m trying to create an automation that compares a sensor value now to a sensor value an hour ago, and if it’s more than 30% higher do something. I’m not sure how get the sensor value from an hour ago, or how to set up the math equation to check if the (now value / old value) is 1.3 or greater.
The sensor value I’m trying to use is:
sensor.pi_hole_dns_queries_today
My ultimate goal is to have Home Assistant use TTS and have Alexa tell me the PiHole saw an unusual spike in DNS queries. I know how to do the TTS to Alexa part, I just don’t know how check and compare the sensor values throughout the day.
Thanks in advance.
  1. Create a SQL sensor that get you the value from 1h ago:
- platform: sql
  queries:
    - name: Queries 1h ago
      query: "select state from states where entity_id = 'sensor.pi_hole_dns_queries_today' and created < datetime('now','-1 hour') order by created DESC LIMIT 1;"
      column: 'state'
  1. Compare
{{ states('sensor.pi_hole_dns_queries_today')|float > states('sensor.pihole_queries_1h_ago')|float * 1.3 }}
EDIT: Fixed syntax of compare
The SQL sensor works.
For the compare I tried using it with a Template Trigger, but that didn’t seem to work, what type of type of Trigger should I use?
Please show what you have
I modified the name slightly from your original example, and it’s showing a value so I don’t think that’s the problem. Right now I just have it switching my office light on and off, so I know it’s working, eventually it will do a TTS announcement to an Amazon Echo, but I wanted to get the Trigger working with something simple to start.
Here’s the yaml:
alias: Network Status PiHole Large Increase in Queries
    value_template: >-
      {{ sensor.pi_hole_dns_queries_today|float > (sensor.sensor.pihole_queries_1h_ago|float * 1.3) }}
  - type: turn_off
    device_id: dd39fc1e2a344b7a9e25bdc40e44a408
    entity_id: switch.office_light
    domain: switch
  - type: turn_on
    domain: switch
mode: queued
max: 10
Seems fine.
What are the values of the sensors when the automation should have been triggered?
There’s some syntax errors here.
    value_template: >
Hi!
I found this old post on how to get old sensor values with the SQL-sensor, but I can´t get it to work.
Has anything changed since the original question was created (except from the fact that the integration has been moved to GUI)?
The query I´m trying looks like this:
SELECT state FROM states WHERE entity_id = 'sensor.probe1' and created = datetime('now','-1 hour') ORDER BY created DESC LIMIT 1;
and the result is always ‘Unknown’
I have also tested (just to check the SQL-integration) this qurey:
SELECT * FROM states WHERE entity_id = 'sensor.probe1' ORDER BY state_id DESC LIMIT 1;
And that works fine and gives me the latest sensor value.
I found the solution.
created should be replaced with last_updated, so here is what I´m using now:
SELECT state from states where entity_id = 'sensor.probe1' and last_updated < datetime('now','-5 minutes') order by last_updated DESC LIMIT 1;
