Need help with automation for heat pump
Automating heating and climate control with flow temperature ajustment , thermostat automation , Smart Thermostat with PID controller ,adjust the temperature accordingly surpus eneegy from PV ,Automating climate control with Solar PV output Estimated Power Production - Now (in Watt) ,Estimated Power Production - Next Hour (in Watt) . The resulting optimised flow temperatures mean increased efficiencies, potential savings,
I need some help to write this scrip or to find a similar script ( I dont have programig experiece )
1.connection to heat pump is via local tuya TCPIP ( number.set4temp ; switch.pdc_on_off ;sensor.21senzor_return;sensor.22senzor_flow)
2.conection to PV invertor Huawei FusionSolar invertor or via local modbus TCPIP , Power Sensor (sensor.power_sensor_active_power ;sensor.power_sensor_realtime_power
3.conection with a room termometer is via local tuya (sensor.t1_3_real_temp second room/ sensor.t2_realtemp )
4.conection txternal temperature and humidyt is done via API(sensor.wupws_temp,sensor.wupws_humidity)
5.Solar production forecast (sensor.power_production_now ;sensor.energy_current_hour;sensor.energy_next_hour
Some conection are lostet over some issie with signal , is nsesary a controll loop and some extra feadback info .
