Need Help with Calendar and Weather Forecast Template Sensors
Hi there, apologize for my lack of knowledge but I copied and pasted some code from some tutorials for retrieving calendar entities and creating a forecast for a weather entity. I added a few different ones and the only thing that is working is the first calendar sensor named “family calendar feed”. I am not sure if I am placing them in the correct location (template.yaml or sensors.yaml- i don’t know the difference and why one should go in there versus the other). I also noticed that when i created these sensors i got a legacy syntax issue with “platform” so I changed it to “trigger” and it would for the first calendar sensor but not the rest. I have no idea if I just am adding more sensors incorrectly or what. Any help would be appreaciated. Code from the template.yaml is below. PS- I get this error in Studio Code Server whenever I try to save anything: “Failed to save ‘template.yaml’: The content of the file is newer. Please compare your version with the file contents or overwrite the content of the file with your changes.”
- trigger:
    - trigger: time_pattern
      hours: /1
    - trigger: homeassistant
      event: start
  - action: calendar.get_events
      entity_id:
        - calendar.family
      duration:
        days: 30
    response_variable: calendar_events
  - name: Family Calendar Feed
    unique_id: calenddar_family_feed
    icon: mdi:calendar
    state: "{{ calendar_events['calendar.family'].events | count() }}"
    attributes:
      events: "{{ calendar_events['calendar.family'].events }}"
- trigger:
      hours: /1
      event: start
      entity_id:
        - calendar.jen
      duration:
        days: 30
  - name: Ben's Calendar Feed
    unique_id: calendar_ben_feed
    icon: mdi:calendar
    state: "{{ calendar_events['calendar.Ben'].events | count() }}"
    attributes:
      events: "{{ calendar_events['calendar.Ben'].events }}"
- trigger:
      hours: /1
      event: start
      entity_id:
        - calendar.bob
      duration:
        days: 30
  - name: Bob's Calendar Feed
    unique_id: calenddar_bob_feed
    icon: mdi:calendar
    state: "{{ calendar_events['calendar.bob'].events | count() }}"
    attributes:
      events: "{{ calendar_events['calendar.bob'].events }}"
- trigger:
      hours: /1
      event: start
      entity_id:
        - calendar.d
      duration:
        days: 30
  - name: D's Calendar Feed
    unique_id: calendar_d_feed
    icon: mdi:calendar
    state: "{{ calendar_events['calendar.d'].events | count() }}"
    attributes:
      events: "{{ calendar_events['calendar.d'].events }}"
- trigger:
      hours: /1
      event: start
      entity_id:
        - calendar.ziggy
      duration:
        days: 30
  - name: Ziggy's Calendar Feed
    unique_id: calendar_ziggy_feed
    icon: mdi:calendar
    state: "{{ calendar_events['calendar.ziggy'].events | count() }}"
    attributes:
      events: "{{ calendar_events['calendar.ziggy'].events }}"
- trigger:
      hours: /1
      event: start
      entity_id:
        - calendar.natsra
      duration:
        days: 30
  - name: natsra Calendar Feed
    unique_id: calenddar_natsra_feed
    icon: mdi:calendar
    state: "{{ calendar_events['calendar.natsra'].events | count() }}"
    attributes:
      events: "{{ calendar_events['calendar.natsra'].events }}"
- trigger:
      hours: /1
      event: start
      entity_id:
        - calendar.birthdays
      duration:
        days: 30
  - name: Birthdays Calendar Feed
    unique_id: calendar_birthdays_feed
    icon: mdi:calendar
    state: "{{ calendar_events['calendar.birthdays'].events | count() }}"
    attributes:
      events: "{{ calendar_events['calendar.birthdays'].events }}"
- trigger:
      hours: /1
      event: start
      entity_id:
        - calendar.school
      duration:
        days: 30
  - name: School Calendar Feed
    unique_id: calendar_school_feed
    icon: mdi:calendar
    state: "{{ calendar_events['calendar.school'].events | count() }}"
    attributes:
      events: "{{ calendar_events['calendar.school'].events }}"
- trigger:
      hours: /1
      event: start
  - action: weather.get_forecasts
      entity_id: weather.homefc
      type: hourly
    response_variable: hourly
    target: entity_id:weather.homefc
      type: daily
    response_variable: daily
  - name: Weather Forecast Test
    unique_id: weather_forecast_test
    state: "{{ now().isoformat() }}"
    attributes:
      now_condition: "{{ daily['weather.homefc'].forecast[0].condition }}"
      now_icon: >
        {% set weather = hourly['weather.homefc'].forecast[0].condition %}
        {% if is_state('sun.sun', 'above_horizon') %}
        {{ '/local/weather/' + weather + '.svg' }}
        {% else %}
        {{ '/local/weather/' + weather + '_night.svg' }}
        {% endif %}
      now_temp: "{{ hourly['weather.homefc'].forecast[0].temperature }}"
      now_wind_speed: "{{ ((hourly['weather.homefc'].forecast[0].wind_speed | float) / 3.6) | round(1) }}"
      now_wind_bearing: "{{ hourly['weather.homefc'].forecast[0].wind_bearing }}"
      now_precipitation: "{{ hourly['weather.homefc'].forecast[0].precipitation }}"
      now_precipitation_probability: "{{ hourly['weather.homefc'].forecast[0].precipitation_probability }}"
      now_humidity: "{{ hourly['weather.homefc'].forecast[0].humidity }}"
      now_feels_like: >
        {% set T = (hourly['weather.homefc'].forecast[0].temperature | float) %}
        {% set K = (hourly['weather.homefc'].forecast[0].wind_speed | float)/3.6 %}
        {% set V = (K/1000*60*60) %}
        {% set A = 13.12 + 0.6215*T - 11.37*(V**0.16) + 0.3965*T*(V**0.16) %}
        {{ (A) | round(1) }}
      now_wind_direction: >
        {% set direction = ['N','NNØ','NØ','ØNØ','Ø','ØSØ','SØ','SSØ','S','SSV','SV','VSV','V','VNV','NV','NNV','N'] %}
        {% set degree = (hourly['weather.homefc'].forecast[0].wind_bearing | float) %}
        {{ direction[((degree+11.25)/22.5)|int] }}
      now_wind_desc: "{{ hourly['weather.homefc'].forecast[0].wind_speed | float }}"
      today_condition: "{{ daily['weather.homefc'].forecast[0].condition }}"
      today_icon: >
        {% set weather = daily['weather.homefc'].forecast[0].condition %}
      today_temp: "{{ daily['weather.homefc'].forecast[0].temperature }}"
      today_wind_speed: "{{ ((daily['weather.homefc'].forecast[0].wind_speed | float) / 3.6) | round(1) }}"
      today_wind_bearing: "{{ daily['weather.homefc'].forecast[0].wind_bearing }}"
      today_precipitation: "{{ daily['weather.homefc'].forecast[0].precipitation }}"
      today_precipitation_probability: "{{ daily['weather.homefc'].forecast[0].precipitation_probability }}"
      today_humidity: "{{ daily['weather.homefc'].forecast[0].humidity }}"
      today_feels_like: >
        {% set T = (daily['weather.homefc'].forecast[0].temperature | float) %}
        {% set K = (daily['weather.homefc'].forecast[0].wind_speed | float)/3.6 %}
      today_wind_direction: >
        {% set degree = (daily['weather.homefc'].forecast[0].wind_bearing | float) %}
      today_wind_desc: "{{ daily['weather.homefc'].forecast[0].wind_speed | float }}"
      forc1_datetime: "{{ daily['weather.homefc'].forecast[1].datetime }}"
      forc1_condition: "{{ daily['weather.homefc'].forecast[1].condition }}"
      forc1_icon: >
        {% set weather = ['dailyweather.homefc'].forecast[1].condition %}
      forc1_temp: "{{ daily['weather.homefc'].forecast[1].temperature }}"
      forc1_precipitation: "{{ daily['weather.homefc'].forecast[1].precipitation }}"
      forc2_datetime: "{{ daily['weather.homefc'].forecast[2].datetime }}"
      forc2_condition: "{{ daily['weather.homefc'].forecast[2].condition }}"
      forc2_icon: >
        {% set weather = ['dailyweather.homefc'].forecast[2].condition %}
      forc2_temp: "{{ daily['weather.homefc'].forecast[2].temperature }}"
      forc2_precipitation: "{{ daily['weather.homefc'].forecast[2].precipitation }}"
      forc3_datetime: "{{ daily['weather.homefc'].forecast[3].datetime }}"
      forc3_condition: "{{ daily['weather.homefc'].forecast[3].condition }}"
      forc3_icon: >
        {% set weather = daily['weather.homefc'].forecast[3].condition %}
      forc3_temp: "{{ daily['weather.homefc'].forecast[3].temperature }}"
      forc3_precipitation: "{{ daily['weather.homefc'].forecast[3].precipitation }}"
      forc4_datetime: "{{ daily['weather.homefc'].forecast[4].datetime }}"
      forc4_condition: "{{ daily['weather.homefc'].forecast[4].condition }}"
      forc4_icon: >
        {% set weather = ['dailyweather.homefc'].forecast[4].condition %}
      forc4_temp: "{{ daily['weather.homefc'].forecast[4].temperature }}"
      forc4_precipitation: "{{ daily['weather.homefc'].forecast[4].precipitation }}"
      forc5_datetime: "{{ daily['weather.homefc'].forecast[5].datetime }}"
      forc5_condition: "{{ daily['weather.homefc'].forecast[5].condition }}"
      forc5_icon: >
        {% set weather = daily['weather.homefc'].forecast[5].condition %}
      forc5_temp: "{{ daily['weather.homefc'].forecast[5].temperature }}"
      forc5_precipitation: "{{ daily['weather.homefc'].forecast[5].precipitation }}"
- trigger:
      hours: /1
      event: start
  - service: weather.get_forecasts
      type: daily
  - name: Tutorial Weather Forecast
    unique_id: tutorial_weather_forecast
    state: "Something"
    attributes:
      temperature: "{{ daily['weather.homefc'].forecast[0].temperature }}"
      precipitation_percent: "{{ daily['weather.homefc'].forecast[0].precipitation_probability }}"
      wind_speed: "{{ daily['weather.homefc'].forecast[0].wind_speed }}"
      cond_icon: >
        {{ '/local/ic/weather_icons/' + weather + '.svg' }}
        {% else %}
        {{ '/local/ic/weather_icons/' + weather + '_night.svg' }}
        {% endif %}
      feels_like: >
      wind_dir: >
        {% set direction = ['N','NNE','NE','ENE','E','ESE','SE','SSE','S','SSW','SW','WSW','W','WNW','NW','NNW','N'] %}
      wind_desc: >
        {% set sensor = (daily['weather.homefc'].forecast[0].wind_speed | float) %}
        {% if sensor > 0 and sensor < 0.99 %}
        Calm
        {% elif sensor > 1 and sensor < 6.99 %}
        Light air
        {% elif sensor > 7 and sensor < 11.99 %}
        Light breeze
        {% elif sensor > 12 and sensor < 19.99 %}
        Gentle breeze
        {% elif sensor > 20 and sensor < 29.99 %}
        Moderate breeze
        {% elif sensor > 30 and sensor < 39.99 %}
        Fresh breeze
        {% elif sensor > 40 and sensor < 50.99 %}
        Strong breeze
        {% elif sensor > 51 and sensor < 62.99 %}
        Near gale
        {% elif sensor > 63 and sensor < 75.99 %}
        Gale
        {% elif sensor > 76 and sensor < 87.99 %}
        Strong gale
        {% elif sensor > 88 and sensor < 102.99 %}
        Storm
        {% elif sensor > 103 and sensor < 117.99 %}
        Violent storm
        {% else %}
        Hurricane
        {% endif %}
      datetime1: "{{ daily['weather.homefc'].forecast[1].datetime }}"
      condition1: "{{ daily['weather.homefc'].forecast[1].condition }}"
      cond_icon1: >
        {% set weather = daily['weather.homefc'].forecast[1].condition %}
        {{ '/local/ic/weather_icons/animated3/' + weather + '.svg' }}
        {% else %}
        {{ '/local/ic/weather_icons/animated3/' + weather + '_night.svg' }}
        {% endif %}
      temperature1: "{{ daily['weather.homefc'].forecast[1].temperature }}"
      precipitation1: "{{ daily['weather.homefc'].forecast[1].precipitation }}"
      datetime2: "{{ daily['weather.homefc'].forecast[2].datetime }}"
      condition2: "{{ daily['weather.homefc'].forecast[2].condition }}"
      cond_icon2: >
        {% set weather = daily['weather.homefc'].forecast[2].condition %}
        {% else %}
        {% endif %}
      temperature2: "{{ daily['weather.homefc'].forecast[2].temperature }}"
      precipitation2: "{{ daily['weather.homefc'].forecast[2].precipitation }}"
      datetime3: "{{ daily['weather.homefc'].forecast[3].datetime }}"
      condition3: "{{ daily['weather.homefc'].forecast[3].condition }}"
      cond_icon3: >
        {% else %}
        {% endif %}
      temperature3: "{{ daily['weather.homefc'].forecast[3].temperature }}"
      precipitation3: "{{ daily['weather.homefc'].forecast[3].precipitation }}"
      datetime4: "{{ daily['weather.homefc'].forecast[4].datetime }}"
      condition4: "{{ daily['weather.homefc'].forecast[4].condition }}"
      cond_icon4: >
        {% set weather = daily['weather.homefc'].forecast[4].condition %}
        {% else %}
        {% endif %}
      temperature4: "{{ daily['weather.homefc'].forecast[4].temperature }}"
      precipitation4: "{{ daily['weather.homefc'].forecast[4].precipitation }}"
      datetime5: "{{ daily['weather.homefc'].forecast[5].datetime }}"
      condition5: "{{ daily['weather.homefc'].forecast[5].condition }}"
      cond_icon5: >
        {% else %}
        {% endif %}
      temperature5: "{{ daily['weather.homefc'].forecast[5].temperature }}"
      precipitation5: "{{ daily['weather.homefc'].forecast[5].precipitation }}"
