Need help with ESPHome
What is the difference between ESPHome and UGREEN Bluetooth 5.3 Adapter for PC, Long Range 328ft/100M?
I did watch YT videos about ESPHome still i don’t understand how it works with Home Assistant.
Can you recommend me ESPHome Bluetooth to buy from online store to use with Home Assistant?
Thank you
Hello
EspHome is a firmware you set-up to do what you want using an esp32 or an esp8266. It controls other hardware and lights and devices with direct wiring, talks on WIFI or serial, and can do MANY things…
The other thing is for bluetooth.
It’s like asking what’s the difference between a set of 5000 lego blocks and a pop-it fidget toy. One can do mamy mamy things, the other one thing.
Thank you so much to guide me to the right direction.
