Need help with input_number
Hi.
I have a input_number that I want to use to set brightness to a light.
I made a test script that looks like this:
'1232334232434':
  alias: testanumberslider
  sequence:
  - data:
      brightness: "{{ states('input_number.alarmminutes_weekdays') | int }}"
      entity_id: light.kallaren
      transition: 10
    service: light.turn_on
If I use a fixed number for brightness it works fine. But now a get the following error:
Error executing script script.1232334232434. Invalid data for call_service at pos 1: expected int for dictionary value @ data[‘brightness’]
In developer tools / states the input_number.alarmminutes_weekdays have state: 30.0
What I’m a doing wrong?
using Home Assistant 0.100.1
What does the template developer tool give when you put that template in?
You need to use data_template instead of data.
Tnx that did the trick.
