Hello HA Community,
For past couple of weeks I have been trying to get in built home security system configured in HA setup. (Inspired By @CCOSTAN - http://www.vmwareinfo.com/2017/06/building-my-home-alarm-system-hardware.html) I have been successfully configure HA, ESP8266 and MQTT to get it working in my test environment (using jumper cables directly rather than actual reed sensors) but when I plug it in with actual reed sensors I don’t get any for of updates. I have checked reed sensors in with multimeter and they all are working properly. Below I’m including all my code. Please let me know if you see something that I am doing wrong or incorrectly. Any feedback / comment / pointers are highly appreciated.
ESP8266 Code
#include <PubSubClient.h>
#include <ESP8266WiFi.h>
#define wifi_ssid "wifi_ssid"
#define wifi_password "wifi_password"
#define mqtt_server "mqtt_server"
#define mqtt_user "mqtt_user"
#define mqtt_password "mqtt_pwd"
class ReedSensor {
public:
int pin;
int last_status;
unsigned long last_switch_time;
String mqtt_topic;
ReedSensor *front;
ReedSensor *back;
ReedSensor *deck;
#define FRONT_DOOR_STATUS_TOPIC "NodeMCU_Door/GPIO14/Status"
#define FRONT_DOOR_STATUS_PIN 14 //Black Wire
unsigned long FRONT_DOOR_LAST_SWITCH_TIME = 0;
int FRONT_DOOR_LAST_STATUS_VALUE = 2;
#define BACK_DOOR_STATUS_TOPIC "NodeMCU_Door/GPIO12/Status"
#define BACK_DOOR_STATUS_PIN 12 //White Wire
unsigned long BACK_DOOR_LAST_SWITCH_TIME = 0;
int BACK_DOOR_LAST_STATUS_VALUE = 2;
#define DECK_DOOR_STATUS_TOPIC "NodeMCU_Door/GPIO13/Status"
#define DECK_DOOR_STATUS_PIN 13 // Gray Wire
unsigned long DECK_DOOR_LAST_SWITCH_TIME = 0;
int DECK_DOOR_LAST_STATUS_VALUE = 2;
void init_reed_sensor(ReedSensor *senor, int pin, String mqtt_topic) {
senor->pin = pin;
senor->last_status = 2;
senor->last_switch_time = 0;
senor->mqtt_topic = mqtt_topic;
void setup_reed_switches() {
front = new ReedSensor();
init_reed_sensor(front, FRONT_DOOR_STATUS_PIN, FRONT_DOOR_STATUS_TOPIC);
back = new ReedSensor();
init_reed_sensor(back, BACK_DOOR_STATUS_PIN, BACK_DOOR_STATUS_TOPIC);
deck = new ReedSensor();
init_reed_sensor(deck, DECK_DOOR_STATUS_PIN, DECK_DOOR_STATUS_TOPIC);
//Doors
pinMode(FRONT_DOOR_STATUS_PIN, INPUT_PULLUP);
pinMode(BACK_DOOR_STATUS_PIN, INPUT_PULLUP);
pinMode(DECK_DOOR_STATUS_PIN, INPUT_PULLUP);
WiFiClient espClient;
PubSubClient client(espClient);
int debounceTime = 100;
void setup_wifi(){
delay(10);
Serial.println();
Serial.print("Connecting to ");
Serial.println(wifi_ssid);
WiFi.mode(WIFI_STA);
WiFi.begin(wifi_ssid, wifi_password);
while (WiFi.status() != WL_CONNECTED) {
delay(500);
Serial.print(".");
Serial.println("");
Serial.println("WiFi connected");
Serial.println("IP address: ");
Serial.println(WiFi.localIP());
void reconnect() {
// Loop until we're reconnected
while (!client.connected()) {
Serial.print("Attempting MQTT connection...");
// Attempt to connect
if (client.connect("NodeMCU_Door", mqtt_user, mqtt_password)) {
Serial.println("connected");
client.subscribe("NodeMCU_Door/#");
} else {
Serial.print("failed, rc=");
Serial.print(client.state());
Serial.println(" try again in 5 seconds");
// Wait 5 seconds before retrying
delay(5000);
void setup() {
Serial.begin(115200);
Serial.println("Booting Security System NodeMCU Door");
//Setup WiFi
setup_wifi();
client.setServer(mqtt_server, 1883);
client.setCallback(callback);
//Setup Reed Switches
setup_reed_switches();
// the loop function runs over and over again forever
void loop() {
if (!client.connected()) {
reconnect();
client.loop();
checkStatusForReedSensors();
void checkStatusForReedSensors() {
checkStatusFrontDoor();
checkStatusBackDoor();
checkStatusDeckDoor();
//Front Door
void checkStatusFrontDoor() {
int currentStatusValue = digitalRead(FRONT_DOOR_STATUS_PIN);
int lastStatusValue = lastStatusValueForSensor(FRONT_DOOR_STATUS_PIN);
unsigned long lastSwitchTime = lastSwitchTimeForSensor(FRONT_DOOR_STATUS_PIN);
if (currentStatusValue != lastStatusValue) {
unsigned int currentTime = millis();
if (currentTime - lastSwitchTime >= debounceTime) {
publishStatus(FRONT_DOOR_STATUS_PIN);
setLastStatusValueForSensor(FRONT_DOOR_STATUS_PIN, currentStatusValue);
setLastSwitchTimeForSensor(FRONT_DOOR_STATUS_PIN, currentTime);
// Back Door
void checkStatusBackDoor() {
int currentStatusValue = digitalRead(BACK_DOOR_STATUS_PIN);
int lastStatusValue = lastStatusValueForSensor(BACK_DOOR_STATUS_PIN);
unsigned long lastSwitchTime = lastSwitchTimeForSensor(BACK_DOOR_STATUS_PIN);
publishStatus(BACK_DOOR_STATUS_PIN);
setLastStatusValueForSensor(BACK_DOOR_STATUS_PIN, currentStatusValue);
setLastSwitchTimeForSensor(BACK_DOOR_STATUS_PIN, currentTime);
// Deck Door
void checkStatusDeckDoor() {
int currentStatusValue = digitalRead(DECK_DOOR_STATUS_PIN);
int lastStatusValue = lastStatusValueForSensor(DECK_DOOR_STATUS_PIN);
unsigned long lastSwitchTime = lastSwitchTimeForSensor(DECK_DOOR_STATUS_PIN);
publishStatus(DECK_DOOR_STATUS_PIN);
setLastStatusValueForSensor(DECK_DOOR_STATUS_PIN, currentStatusValue);
setLastSwitchTimeForSensor(DECK_DOOR_STATUS_PIN, currentTime);
void publishStatus(int SENSOR_PIN) {
String topic = statusTopicForSensor(SENSOR_PIN);
const char *stateTopic = topic.c_str();
if(digitalRead(SENSOR_PIN) == LOW) {
client.publish(stateTopic, "closed", true);
} else {
client.publish(stateTopic, "open", true);
int lastStatusValueForSensor(int SENSOR_PIN) {
switch(SENSOR_PIN){
case FRONT_DOOR_STATUS_PIN: return FRONT_DOOR_LAST_STATUS_VALUE;
case BACK_DOOR_STATUS_PIN: return BACK_DOOR_LAST_STATUS_VALUE;
case DECK_DOOR_STATUS_PIN: return DECK_DOOR_LAST_STATUS_VALUE;
default : return 2;
return 2;
unsigned long lastSwitchTimeForSensor(int SENSOR_PIN) {
switch(SENSOR_PIN){
case FRONT_DOOR_STATUS_PIN: return FRONT_DOOR_LAST_SWITCH_TIME;
case BACK_DOOR_STATUS_PIN: return BACK_DOOR_LAST_SWITCH_TIME;
case DECK_DOOR_STATUS_PIN: return DECK_DOOR_LAST_SWITCH_TIME;
default : return 0;
return 0;
void setLastStatusValueForSensor(int SENSOR_PIN, int statusValue) {
switch(SENSOR_PIN){
case FRONT_DOOR_STATUS_PIN: FRONT_DOOR_LAST_STATUS_VALUE = statusValue;
case BACK_DOOR_STATUS_PIN: BACK_DOOR_LAST_STATUS_VALUE = statusValue;
case DECK_DOOR_STATUS_PIN: DECK_DOOR_LAST_STATUS_VALUE = statusValue;
default : return;
return;
void setLastSwitchTimeForSensor(int SENSOR_PIN, unsigned long switchTime) {
switch(SENSOR_PIN){
case FRONT_DOOR_STATUS_PIN: FRONT_DOOR_LAST_SWITCH_TIME = switchTime;
case BACK_DOOR_STATUS_PIN: BACK_DOOR_LAST_SWITCH_TIME = switchTime;
case DECK_DOOR_STATUS_PIN: DECK_DOOR_LAST_SWITCH_TIME = switchTime;
default : return;
return;
String statusTopicForSensor(int SENSOR_PIN) {
switch(SENSOR_PIN){
case FRONT_DOOR_STATUS_PIN: return FRONT_DOOR_STATUS_TOPIC;
case BACK_DOOR_STATUS_PIN: return BACK_DOOR_STATUS_TOPIC;
case DECK_DOOR_STATUS_PIN: return DECK_DOOR_STATUS_TOPIC;
default : return "ERROR";
return "ERROR";
void callback(char* topic, byte* payload, unsigned int length) {
payload[length] = '\0';
String strTopic = String((char*)topic);
String payloadValue = String((char*)payload);
Serial.print("Topic - ");
Serial.println(strTopic);
Serial.print("Payload - ");
Serial.println(payloadValue);
HA Config File
binary_sensor:
- platform: mqtt
state_topic: "NodeMCU_Door/GPIO14/Status"
payload_on: "open"
payload_off: "closed"
device_class: opening
- platform: mqtt
state_topic: "NodeMCU_Door/GPIO12/Status"
payload_on: "open"
- platform: mqtt
state_topic: "NodeMCU_Door/GPIO13/Status"
payload_on: "open"
MQTT Broker Options
"plain": true,
"ssl": false,
"anonymous": false,
"logins": [
"username": "mqtt_username",
"password": "mqtt_password"
"customize": {
"active": false,
"folder": "mosquitto"
"certfile": "fullchain.pem",
"keyfile": "privkey.pem"
