Need Help ZHA Migration from 1 SMLIGHT SLZB-06M to another SMLIGHT SLZB-06M - Unknown Error
All
Per the title I had an initial SMLIGHT SLZB-06M that just failed and has approx 50 devices (now) connected to it. I have a replacement SMLIGHT SLZB-06M and want to migrate to the new one. However, when I go to migrate, ZHA integration sits for a second or 2 then states ‘Unknown Error Occurred’ and won’t let me continue.
Any ideas on how to get around this and successfully migrate since I don’t want to have to rebuild the entire Zigbee NW again. Again, the original unit is completely failed so won’t even boot etc, therefore cannot do anything with that. Hoping I can still use the new unit and migrate some way.
Thanks in advance
Error that I see in Logs:
  File "/usr/local/lib/python3.13/site-packages/aiohttp/web_protocol.py", line 480, in _handle_request
    resp = await request_handler(request)
  File "/usr/local/lib/python3.13/site-packages/aiohttp/web_app.py", line 569, in _handle
    return await handler(request)
  File "/usr/local/lib/python3.13/site-packages/aiohttp/web_middlewares.py", line 117, in impl
  File "/usr/src/homeassistant/homeassistant/components/http/security_filter.py", line 92, in security_filter_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/forwarded.py", line 83, in forwarded_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/request_context.py", line 26, in request_context_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 86, in ban_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 242, in auth_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/headers.py", line 32, in headers_middleware
    response = await handler(request)
  File "/usr/src/homeassistant/homeassistant/helpers/http.py", line 73, in handle
    result = await handler(request, **request.match_info)
  File "/usr/src/homeassistant/homeassistant/components/http/decorators.py", line 81, in with_admin
    return await func(self, request, *args, **kwargs)
  File "/usr/src/homeassistant/homeassistant/components/config/config_entries.py", line 295, in post
    return await super().post(request, flow_id)
  File "/usr/src/homeassistant/homeassistant/components/http/data_validator.py", line 74, in wrapper
    return await method(view, request, data, *args, **kwargs)
  File "/usr/src/homeassistant/homeassistant/helpers/data_entry_flow.py", line 121, in post
    result = await self._flow_mgr.async_configure(flow_id, data)
  File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 340, in async_configure
    result = await self._async_configure(flow_id, user_input)
  File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 387, in _async_configure
    result = await self._async_handle_step(
        flow, cur_step["step_id"], user_input
  File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 490, in _async_handle_step
    result: _FlowResultT = await getattr(flow, method)(user_input)
  File "/usr/src/homeassistant/homeassistant/components/zha/config_flow.py", line 774, in async_step_intent_migrate
    await self._radio_mgr.async_reset_adapter()
  File "/usr/src/homeassistant/homeassistant/components/zha/radio_manager.py", line 283, in async_reset_adapter
    await app.connect()
  File "/usr/local/lib/python3.13/site-packages/bellows/zigbee/application.py", line 154, in connect
    await self._ezsp.connect(use_thread=self.config[CONF_USE_THREAD])
  File "/usr/local/lib/python3.13/site-packages/bellows/ezsp/__init__.py", line 134, in connect
    self._gw = await bellows.uart.connect(self._config, self, use_thread=use_thread)
  File "/usr/local/lib/python3.13/site-packages/bellows/uart.py", line 154, in connect
    protocol, _ = await _connect(config, api)
  File "/usr/local/lib/python3.13/site-packages/bellows/uart.py", line 125, in _connect
    transport, _ = await zigpy.serial.create_serial_connection(
    ...<6 lines>...
  File "/usr/local/lib/python3.13/site-packages/zigpy/serial.py", line 117, in create_serial_connection
    transport, protocol = await loop.create_connection(
    ...<3 lines>...
  File "/usr/local/lib/python3.13/asyncio/base_events.py", line 1166, in create_connection
    raise exceptions[0]
  File "/usr/local/lib/python3.13/asyncio/base_events.py", line 1141, in create_connection
    sock = await self._connect_sock(
        exceptions, addrinfo, laddr_infos)
  File "/usr/local/lib/python3.13/asyncio/base_events.py", line 1044, in _connect_sock
    await self.sock_connect(sock, address)
  File "/usr/local/lib/python3.13/asyncio/selector_events.py", line 641, in sock_connect
    return await fut
  File "/usr/local/lib/python3.13/asyncio/selector_events.py", line 681, in _sock_connect_cb
    raise OSError(err, f'Connect call failed {address}')
OSError: [Errno 113] Connect call failed ('192.168.12.163', 6638)
Since I have Home Assistant backups (assume those include the ZHA NW as well) could I just remove the current failed coordinator, add the new and somehow migrate after the fact ? I know it states you can only have 1 controller so not sure how I would migrate after removing the old failed unit.
@dmulcahey @TheJulianJES @puddly @Adminiuga kindly tagging in case you can assist directly. Thanks
Answering my own question here to close loop and hopefully help others:
  • In looking into this further, the Migrate function does NOT work when you do not / cannot have the old/existing Zigbee Coordinator connected.
  • In my case I cannot connect the current coordinator as its completely failed.
  • To migrate in cases like this you need to instead click Configure then Reconfigure Radio.
  • When you get to the Serial path selection, choose Manual (if using the SLZB-06M like I am on POE).
  • Now choose Manually Enter. Select EZSP (Silicon Labs) as Radio Type then enter the new IP address associated with the NEW / REPLACEMENT coordinator.
  • Click Submit and after a while you will be presented with options to restore/erase etc. In my case I chose Restore from Automatic Backup.
  • After a minute or 2 the new/replacement coordinator is in place with the original Zigbee entities / NW attached.
Hope this helps others. Certainly would recommend a doc update on the integration page as I didn’t see this ‘migration’ option documented and this involves different steps than the traditional migration.
