jr_sol
(Eduardo Junior)
March 31, 2023, 4:12pm
1
I have this part of the code
- service: mqtt.publish
qos: '2'
topic: cmnd/{{machine_4}}/PH_SERIAL
payload_template: >
{% set setpoint = states(set_modulado_ac04)|int %}
{% set liga = "ON" %} {% set modo = "COOL" %}
"STATUS":"{{liga}}","MODE":"{{modo}}","SETPOINT":{{setpoint}}
The part of “set_modulado_ac04” its a number variable, it seems that the number it’s been readed, but apears this error
“Error rendering data template: AttributeError: ‘dict’ object has no attribute ‘lower’”
tom_l
April 1, 2023, 4:59am
2
That is not an entity id, it has no domain (domain.object_id
) and it is not quoted. It should be something like this
{% set setpoint = states('sensor.set_modulado_ac04')|int(0) %}
Or this
{% set setpoint = states('input_number.set_modulado_ac04')|int(0) %}
Depending on what type of entity it is.
As Tom said, the states()
function takes an entity id as an argument. If set_modulado_ac04
is a variable defined elsewhere in the automation that already returns a number or numeric string, you shouldn’t be using the states()
function on it.
qos: '2'
payload_template: >
{% set setpoint = set_modulado_ac04 | int(0) %}
jr_sol
(Eduardo Junior)
April 3, 2023, 5:56pm
4
I made this change, but it does not worked
tom_l
April 3, 2023, 5:58pm
5
Where are you defining the value of set_modulado_ac04
jr_sol
(Eduardo Junior)
April 3, 2023, 6:01pm
6
I’m using input_number and saving in some variables like this:
variables:
set_modulado_ue01: !input set_modulado_ue01
qos: "2"
topic: cmnd/{{machine_1}}/irhvac
payload_template: >
{% set setpoint = states(set_modulado_ue01)|int %}
{"Vendor":"{{vendor_1}}","Power":"{{liga}}","Mode":"{{modo}}","FanSpeed":3,"Temp":{{setpoint}}}
tom_l
April 3, 2023, 6:04pm
7
So this is a blueprint. Moved to the correct category. Please provide the full configuration in future so we know what you are actually doing.
jr_sol
(Eduardo Junior)
April 3, 2023, 6:17pm
8
The full code has more than 5000 lines, but I can show you the resume:
blueprint:
name: Salon control with up to 1 splits machines v1
description: Turn on the machines using Google calendar
domain: automation
# inputs
machine_1:
description: Write the MAC of Machine 1, that will recieve the command
default: ""
vendor_1:
description: Write the protocolo of the machine(Ex: COOLIX | TCL112AC)
default: ""
machine_1_auto:
name: Machine 1 is auto?
description: Insert the switch of machine 1
default: {}
selector:
entity:
domain: input_boolean
comando_enviado01:
name: Decision entity generated machine 1
description: It will show the decision taken by the automation for machine 1
default: {}
selector:
entity:
domain: input_text
setpoint_enviado01:
name: Machine 1 generated setpoint decision entity
description: It will show which was the setpoint sent by the automation to machine 1
default: {}
selector:
entity:
domain: input_text
set_modulado_ue01:
name: Modulated setpoint for machine 1
description: This setpoint modulates according to the sensor graph, to leave the environment with the established goal.
default: {}
selector:
entity:
domain: input_number
setpoint_modular_ue01_auto:
name: Modular setpoint automation for machine 1
description: Place modular setpoint automation control switch for machine 1
default: {}
selector:
entity:
domain: automation
# automation
mode: single
- platform: time_pattern
minutes: /10
alias: Each 10 minutes
variables:
machine_1: !input machine_1
vendor_1: !input vendor_1
- parallel:
- if:
- condition: state
entity_id: !input machine_1_auto
state: "on"
then:
- if:
- condition: state
entity_id: !input setpoint_modular_ue01_auto
state: "on"
then:
qos: "2"
payload_template: >
{% set setpoint = states(set_modulado_ue01) |int %}
- service: input_text.set_value
value: "ON"
entity_id: !input comando_enviado01
data_template:
value: >
{{setpoint}}°C
entity_id: !input setpoint_enviado01
else:
qos: "2"
payload_template: >
{% set setpoint = states(meta) |int %} {% set liga = "ON" %} {% set modo = "COOL" %}
value: "ON"
data_template:
value: >
{{setpoint}}°C
