So about 2 years ago i decided to jump into rabbit hole of camera and door cams. I had decided to go with Eufy because my door lock was with them and to simplify things for the family everything would be in a single app. Now the App works great for viewing all the products but when you are not using the app, then the shortcomings are alot more visible.
So lets start with the doorbell (T8203)
It is hardwired and the dual cam is a great feature. However it doesnt support RTSP (officially) so trying to get it to work in HA via go2rtc and Eufy Security is a chore. The stream always needs to be restarted and via P2P_Start_Stream.
Camera (outdoor)
For outdoor i am using a T8424 which is also hardwired and it also suffered from all the same issue as the doorbell.
Camera (indoor)
For indoor i have 3 (only 2 installed) T8410 and those support RTSP but only have a single stream and no sub stream. I currently have a issue with one of them keeps flaking out on the wifi and i have yet to determine if it is the device or the wifi signal.
Adding them to my Home Assistant wasnt that difficult but using them for Automations has been very underwhelming because of the lack of RTSP for some and instability of others.
So I want to replace them all. Now i was looking at reolink or tapo as some of the devices are in my budget range .
Doorbell:
REOLINK Video Doorbell Camera WiFi, 2K Wired Doorbell Camera for Home Security, 2.4/5GHz WiFi,
Tapo TP-Link Smart Video Doorbell Camera Wired, 2K 5MP,
Cameras
REOLINK E1 Pro-Black 4MP
TP-Link Tapo Smart Pan/Tilt Indoor Security Camera, 360° Motion Tracking, 1080p Full HD WiFi
Camera outdoors
I havent really found anything that can be hardwired like the Eufy one that i have that is at a price point i can afford so i might just suffer with that one for the time being.
So looking for feedback from people with those devices or any better recommendations. Basically i want to be able to use theses devices via HA with Frigate or Shinobi. I also want them to be able to be view from Echo Shows and Google hub. I want to also be able to store the recordings on my server as i have a 10TB drive just for that on my Unraid server that hosts HA in a VM.
