Need some help with rules to turn on/off switches, based on numeric values
Hi guys,
I recently ordered a MH-Z19 CO2-sensor that i am going to use to control the mechanical ventilation in my house. I have the sensor connected to MQTT and i can see the values coming in fine. I have also ordered a Linknode R4 relay board (it is actually a board with a ESP8266 with four relays that i flashed ESPEasy on, so it can be controlled over MQTT, very nice board) which i want to use to control the different fan speeds of the ventilation unit (Itho Ecofan).
The ventilation unit has multiple wires:
  • Wire 1 is always connected to phase, so the box is always on the lowest speed to ensure minimal ventilation in the house
  • When wire 2 is connected to phase, the unit switches to medium speed
  • When wire 3 is connected to phase, the unit switches to high speed
However, how would i setup my rules?
I was thinking of something like this:
alias: 038 - Ventilation medium
  platform: numeric_state
  entity_id: sensor.co2
  above: 600
- service: switch.turn_on
  entity_id:
    - switch.relay1
alias: 039 - Ventilation high
  above: 800
  entity_id:
    - switch.relay2
But i’m getting a bit confused on how i can get it to switch back to lower speeds, without rules being conflicting each other? Can i just create two other rules with below: 800 + switch.turn_off to switch back to medium and another one (below: 600) to switch back to low? Isn’t this going to conflict each other?
I don’t want the relays to be on/off/on/off quickly after each other, some hysterese would be nice but i guess i can create that by expanding the ppm trigger values a bit (650 for on, 600 off etc) so the setup will get less nervous.
For someone not knowing anything about CO2-levels inside a livingroom, a basic pattern looks like this:
  • Nighttime: low levels, around 400-500 ppm
  • Someone in the room: ppm level increases to 550-650
  • Multiple people in the room: 800-900 ppm
  • A lot of people in the room: 1200 - 2000+ ppm
I want HASS to think about which fan speed is needed so i always have optimal fresh air, but don’t ventilate too much (and lose warm air in the winter).
