Need value from webpage / EDIT: ESPhome?
hello,
with a esp8266 i read the value of my gas sensor. how can i add
this value to HA?
i had try it with:
  - platform: scrape
    resource: http://192.168.1.112
    select: 'GasMeter'
    unit_of_measurement: “m3”
but i get no values…
change now my script and my website, but this will also not work… i have no idea, need some help
  - platform: rest
    json_attributes_path: "$.ESP8266_ESP01_GasMeter"
    scan_interval: 15
    value_template: "OK"
    json_attributes:
        - "Device"
        - "MAC"
        - "StartTime"
        - "RunTime"
        - "WIFIConnectCounter"
        - "GasMeter"
Why are you trying to scrape it rather than integrating the esp properly?
See esphome
hi, i had try it with esphome. think that can work, but i cant change my value / state to the
correct value.
its the first time i used esphome.
i had try it here, change the value to 46000, press set state, but home assistant dont change the value
esphome:
esphome:
  platform: ESP8266
  board: esp01_1m
wifi:
    ssid: "myssid"
    password: "xxx"
    manual_ip:
        static_ip: 192.168.1.112
        gateway: 192.168.1.1
        subnet: 255.255.255.0
        dns1: 192.168.1.1
    ap:
      ssid: "Gaszaehler Fallback Hotspot"
      password: "xxx"
  - platform: pulse_counter
    pin: 2
    unit_of_measurement: 'm³'
    filters:
      - multiply: 0.001
api:
    password: "xxx"
ota:
    password: "xxx"
logger:
  level: DEBUG
I’m not sure what you’re trying to do there?
Please explain clearly?
i use a esp8266 to get values (counter) from my gasmeter. looks like:
now i want count the impulses.
my first solution was this arduino code, now i want try esphome
arduino-code:
 * Code for GasMeter
 * created: Alexander Kabza, 2017-03-15
 * V2.05: 2020-02-23  Minor code optimization
#include <ESP8266WiFi.h>
#include <ESP8266WebServer.h>
#include <ESP8266HTTPClient.h>
#include <TimeLib.h>
#include <WiFiUdp.h>
#include <ArduinoOTA.h>
#define LED_PIN 0
#define IN_PIN 2
String DEVICENAME = "ESP8266_ESP01_GasMeter";
String CODEVERSION = "V2.05 from 2020-02-23";
int actual = 1;
int prev = 1;
long int value = 0;
String MACStr;
unsigned long prevWIFIMillis = 0;             // WIFI check trigger
unsigned long prevNTPMillis = 0;              // Trigger per hour
unsigned long prevLEDMillis = 0;              // Trigger for LED
unsigned long WIFIConnectCounter = 0;
unsigned long startEpochTime = 0;
unsigned long elapsedEpochTime = 0;
String formattedDateTime;
String formattedStartDateTime;
float RunTimeHours = 0;
//WIFI
const char* ssid = "YourSSID";
const char* password = "YourPassword";
IPAddress ip(192,168,X,Y);  // Static IP
IPAddress gateway(192,168,X,1);
IPAddress subnet(255,255,255,0);
IPAddress nameserver(192,168,X,1);
//HTTP
ESP8266WebServer server(80);
// NTP Servers:
static const char ntpServerName[] = "de.pool.ntp.org";
const int timeZone = 1;     // Central European Time
WiFiUDP Udp;
unsigned int localPort = 8888;  // local port to listen for UDP packets
time_t getNtpTime();
void digitalClockDisplay();
void printDigits(int digits);
void sendNTPpacket(IPAddress &address);
String GetDateTime() {
  char dt[19];
  sprintf(dt, "%4d-%02d-%02d %02d:%02d:%02d", year(), month(), day(), hour(), minute(), second());
  String strdt = String(dt);
  return strdt;
}  // GetDateTime()
  // utility for digital clock display: prints preceding colon and leading 0
  Serial.print(":");
  if (digits < 10)
    Serial.print('0');
  Serial.print(digits);
/*-------- NTP code ----------*/
const int NTP_PACKET_SIZE = 48; // NTP time is in the first 48 bytes of message
byte packetBuffer[NTP_PACKET_SIZE]; //buffer to hold incoming & outgoing packets
time_t getNtpTime()
  IPAddress ntpServerIP; // NTP server's ip address
  while (Udp.parsePacket() > 0) ; // discard any previously received packets
  Serial.println("Transmit NTP Request");
  // get a random server from the pool
  WiFi.hostByName(ntpServerName, ntpServerIP);
  Serial.print(ntpServerName);
  Serial.print(": ");
  Serial.println(ntpServerIP);
  sendNTPpacket(ntpServerIP);
  uint32_t beginWait = millis();
  while (millis() - beginWait < 1500) {
    int size = Udp.parsePacket();
    if (size >= NTP_PACKET_SIZE) {
      Serial.println("Receive NTP Response");
      Udp.read(packetBuffer, NTP_PACKET_SIZE);  // read packet into the buffer
      unsigned long secsSince1900;
      // convert four bytes starting at location 40 to a long integer
      secsSince1900 =  (unsigned long)packetBuffer[40] << 24;
      secsSince1900 |= (unsigned long)packetBuffer[41] << 16;
      secsSince1900 |= (unsigned long)packetBuffer[42] << 8;
      secsSince1900 |= (unsigned long)packetBuffer[43];
      return secsSince1900 - 2208988800UL + timeZone * SECS_PER_HOUR;
  Serial.println("No NTP Response :-(");
  return 0; // return 0 if unable to get the time
// send an NTP request to the time server at the given address
  // set all bytes in the buffer to 0
  memset(packetBuffer, 0, NTP_PACKET_SIZE);
  // Initialize values needed to form NTP request
  // (see URL above for details on the packets)
  packetBuffer[0] = 0b11100011;   // LI, Version, Mode
  packetBuffer[1] = 0;     // Stratum, or type of clock
  packetBuffer[2] = 6;     // Polling Interval
  packetBuffer[3] = 0xEC;  // Peer Clock Precision
  // 8 bytes of zero for Root Delay & Root Dispersion
  packetBuffer[12] = 49;
  packetBuffer[13] = 0x4E;
  packetBuffer[14] = 49;
  packetBuffer[15] = 52;
  // all NTP fields have been given values, now
  // you can send a packet requesting a timestamp:
  Udp.beginPacket(address, 123); //NTP requests are to port 123
  Udp.write(packetBuffer, NTP_PACKET_SIZE);
  Udp.endPacket();
String ToHEX(unsigned char* bytearray, uint8_t arraysize){
  String str = "";
  for (uint8_t i = 0; i < arraysize; i++){
    if (i > 0) str += ":";
    if (bytearray[i] < 16) str += String(0, HEX);
    str += String(bytearray[i], HEX);
  return str;
void handleRoot() { //Handler
  String msg = "";
  msg += "<" + DEVICENAME + ">\n";
  msg += "<data name=\"Device\" value=\"" + DEVICENAME + "\" valueunit=\"text\"/>\n";
  msg += "<data name=\"Version\" value=\"" + CODEVERSION + "\" valueunit=\"text\"/>\n";
  msg += "<data name=\"MAC\" value=\"" + MACStr + "\" valueunit=\"AA:BB:CC:DD:EE:FF\"/>\n";
  msg += "<data name=\"SSID\" value=\"" + WiFi.SSID() + "\" valueunit=\"text\"/>\n";
  msg += "<data name=\"IP\" value=\"" + WiFi.localIP().toString() + "\" valueunit=\"xxx.xxx.xxx.xxx\"/>\n";
  msg += "<data name=\"StartTime\" value=\"" + formattedStartDateTime + "\" valueunit=\"YYYY-MM-DD hh:mm:ss\"/>\n";
  msg += "<data name=\"RunTime\" value=\"" + String(RunTimeHours, 1) + "\" valueunit=\"hours\"/>\n";
  msg += "<data name=\"WIFIConnectCounter\" value=\"" + String(WIFIConnectCounter) + "\" valueunit=\"\"/>\n";
  msg += "<data name=\"help\" value=\"use /SetValue?Value=xx to set new value\" valueunit=\"text\"/>\n";
  msg += "<data name=\"GasMeter\" value=\"" + String(float(value)/100) + "\" valueunit=\"m^3\"/>\n";
  msg += "</" + DEVICENAME + ">";
  server.send(200, "text/plain", msg);       //Response to the HTTP request
void handleGenericArgs() { //Handler
  String msg = DEVICENAME + ": Number of args received:";
  msg += server.args();            //Get number of parameters
  msg += "\n";                            //Add a new line
  for (int i = 0; i < server.args(); i++) {
    msg += "Arg no" + (String)i + " – ";      //Include the current iteration value
    msg += server.argName(i) + ": ";          //Get the name of the parameter
    msg += server.arg(i) + "\n";              //Get the value of the parameter
void handleNotFound(){
  String msg = DEVICENAME + ": File Not Found\n\n";
  msg += "URI: ";
  msg += server.uri();
  msg += "\nMethod: ";
  msg += (server.method() == HTTP_GET)?"GET":"POST";
  msg += "\nArguments: ";
  msg += "\n";
  for (uint8_t i=0; i<server.args(); i++){
    msg += " " + server.argName(i) + ": " + server.arg(i) + "\n";
  server.send(404, "text/plain", msg);
void handleSetValue() {
  String msg = "";
  String valuestr = "";
  if (server.arg("Value")== ""){     //Parameter not found
    msg = DEVICENAME + ": Value Argument not found!";
  } else {     //Parameter found
    msg = DEVICENAME + ": New Value = ";
    msg += server.arg("Value");     //Gets the value of the query parameter
    valuestr = server.arg("Value");
    value = valuestr.toFloat() * 100;
  server.send(200, "text/plain", msg);          //Returns the HTTP response
void wificonnect() {
  byte MAC[6];
  WiFi.setAutoConnect (true);
  WiFi.setAutoReconnect (true);
  WiFi.mode(WIFI_STA);
  WiFi.config(ip, gateway, subnet, nameserver);
  WiFi.begin(ssid, password); //Connect to the WiFi network
  Serial.println();
  WiFi.macAddress(MAC);
  MACStr = ToHEX(MAC, sizeof(MAC));
  Serial.print("MAC = ");
  Serial.println(MACStr);
  //Wait for WIFI connection
  while (WiFi.status() != WL_CONNECTED) { //Wait for connection
    digitalWrite(LED_PIN, HIGH);  // LED is OFF
    delay(100);
    digitalWrite(LED_PIN, LOW);  // LED is ON
    delay(100);
    Serial.print(".");
  delay(1000);
  Serial.println("");
  Serial.print("WIFI connected to: ");
  Serial.println(WiFi.SSID());
  Serial.print("IP address: ");
  Serial.println(WiFi.localIP());
  WIFIConnectCounter++;
long int GetActGasMeter() {
  long int ActGasMeter = 0;
  HTTPClient http;
  http.begin("http://192.168.X.Y/GetActualGasMeter.php");
  int httpCode = http.GET();
  // httpCode will be negative on error
  if(httpCode > 0) {
    // HTTP header has been send and Server response header has been handled
    //Serial.printf("[HTTP] GET... code: %d\n", httpCode);
    // file found at server
    if (httpCode == HTTP_CODE_OK) {
      String StrActGasMeter = http.getString();
      ActGasMeter = 100 * StrActGasMeter.toFloat();
  } else {
    Serial.printf("[HTTP] GET... failed, error: %s\n", http.errorToString(httpCode).c_str());
  http.end();
  return ActGasMeter;
void setupOTA() {
  ArduinoOTA.setHostname(DEVICENAME.c_str());
  ArduinoOTA.setPasswordHash("b096734cb8ca8d95d02e8a9c7f5b2cXXXYYYZZZ42435de7f8be");
  ArduinoOTA.onStart([]() {
    String type;
    if (ArduinoOTA.getCommand() == U_FLASH) {
      type = "sketch";
    } else { // U_FS
      type = "filesystem";
    // NOTE: if updating FS this would be the place to unmount FS using FS.end()
    Serial.println("Start updating " + type);
  ArduinoOTA.onEnd([]() {
    Serial.println("\nEnd");
  ArduinoOTA.onProgress([](unsigned int progress, unsigned int total) {
    Serial.printf("Progress: %u%%\r", (progress / (total / 100)));
  ArduinoOTA.onError([](ota_error_t error) {
    Serial.printf("Error[%u]: ", error);
    if (error == OTA_AUTH_ERROR) {
      Serial.println("Auth Failed");
    } else if (error == OTA_BEGIN_ERROR) {
      Serial.println("Begin Failed");
    } else if (error == OTA_CONNECT_ERROR) {
      Serial.println("Connect Failed");
    } else if (error == OTA_RECEIVE_ERROR) {
      Serial.println("Receive Failed");
    } else if (error == OTA_END_ERROR) {
      Serial.println("End Failed");
  ArduinoOTA.begin();
  Serial.println("OTA ready");
void setup() {
  pinMode(LED_PIN, OUTPUT);
  pinMode(IN_PIN, INPUT);
  Serial.begin(115200);
  wificonnect();
  delay(1000);
  server.on("/", handleRoot);
  server.on("/genericArgs", handleGenericArgs);
  server.on("/SetValue", handleSetValue);
  server.onNotFound( handleNotFound );
  server.begin();                                       //Start the server
  Serial.println("Server in now listening ...");
  actual = digitalRead(IN_PIN);
  Serial.println("Starting UDP");
  Udp.begin(localPort);
  Serial.print("Local port: ");
  Serial.println(Udp.localPort());
  Serial.println("waiting for sync");
  setSyncProvider(getNtpTime);
  setSyncInterval(300);
  startEpochTime = now();
  formattedStartDateTime = GetDateTime();
  Serial.println("Start: " + formattedStartDateTime + " " + String(startEpochTime));
  setupOTA();
  value = GetActGasMeter();
  Serial.println("Start value for GasMeter: " + String(float(value)/100));
} // end setup
void loop() {
  unsigned long currentMillis = millis();
  server.handleClient();    //Handling of incoming requests
  ArduinoOTA.handle();
  if (actual == 0 && actual != prev) {
    value++;
    Serial.println(value);
    delay(250);
  prev = actual;
  if (currentMillis - prevLEDMillis >= 2000) {    // blink every 2sec
    delay(10);
    prevLEDMillis = currentMillis;
  if (currentMillis - prevWIFIMillis >= 900000000) {    // check wifi every 15min
    if (WiFi.status() != WL_CONNECTED) {
      wificonnect();
      delay(200);
    prevWIFIMillis = currentMillis;
  if (currentMillis - prevNTPMillis >= 900000) {    // update NTP every 15min
    if (timeStatus() != timeNotSet) {
      elapsedEpochTime = now() - startEpochTime;
      RunTimeHours = float(elapsedEpochTime) / 3600;
    prevNTPMillis = currentMillis;
  delay(10);
} // end loop
source: http://www.kabza.de/MyHome/GasMeter/GasMeter.php
i ready now. esphome with pulse_counter or pulse_meter works not good in my case.
i try different settings, all values in home assistant are to high after a while. i dont know why.
esphome read more counters as in real.
so, im back to this arduino script, and change it to:
 * Code for GasMeter
 * use /SetValue?Value=xx to set new value
#define LED_PIN 0
#define IN_PIN 2
String CODEVERSION = "V2.05 xml mod";
int actual = 1;
int prev = 1;
long int value = 0;
String MACStr;
//WIFI
const char* ssid = "my_ssid";
const char* password = "my_password";
IPAddress ip(192,168,1,112);  // Static IP
IPAddress gateway(192,168,1,1);
IPAddress nameserver(192,168,1,1);
//HTTP
// NTP Servers:
WiFiUDP Udp;
  char dt[19];
  return strdt;
}  // GetDateTime()
  Serial.print(":");
  if (digits < 10)
    Serial.print('0');
time_t getNtpTime()
  Serial.print(": ");
  Udp.endPacket();
  String str = "";
  return str;
  String msg = "";
   msg +=  "<div class='gasvalue'>" + String(float(value)/100) + "</div>" ;
 // msg += "<data name=\"GasMeter\" value=\"" + String(float(value)/100) + "\" valueunit=\"m^3\"/>\n";
  msg += "URI: ";
  msg += "\n";
  String msg = "";
  byte MAC[6];
  Serial.println();
    delay(100);
    delay(100);
    Serial.print(".");
  delay(1000);
  Serial.println("");
  HTTPClient http;
  if(httpCode > 0) {
  } else {
  http.end();
  return ActGasMeter;
void setupOTA() {
    String type;
      type = "sketch";
    } else { // U_FS
  ArduinoOTA.begin();
void setup() {
  wificonnect();
  delay(1000);
  setupOTA();
} // end setup
void loop() {
    value++;
    delay(250);
  prev = actual;
    delay(10);
      wificonnect();
      delay(200);
  delay(10);
} // end loop
and add this to my sensor.yaml
# esp8266 Gassensor
  - platform: scrape
    select: ".gasvalue"
    authentication: basic
now, it works perfect.
no differents between HA and my Gasmeter.
with http://ip.of.esp/SetValue?Value=xxxxxx
you can set the actually valu
Edit: Works perfect since 7 days
i have flash my Wemos … now i try with you changes !! Thank you
my inpulse are not 0.01 my is 0.1 must i change this only
to String(float(value)/10)); ?
