I am trying to use the theme mechanism so as to enforce a value-based color scheme on specific set of entities.
My yaml config files contains the following line:
frontend:
themes: !include_dir_merge_named themes
I am defining my target theme as follows:
theme1:
state-binary_sensor-door-open-color: "#FF0000"
state-binary_sensor-door-closed-color: "#008000"
state-binary_sensor-smoke-open-color: "#FF0000"
state-binary_sensor-smoke-closed-color: "#008000"
state-binary_sensor-gas-open-color: "#FF0000"
state-binary_sensor-gas-closed-color: "#008000"
state-cover-open-color: "#ff0000"
state-cover-closed-color: "#008000"
state-media_player-inactive-color: "#795548"
In order to inject that theme into my environment, I inserted the above theme1 code into a new file “theme1.yaml” that I placed into the “themes” directory referred to in my config file.
I then tried deploying my theme1 in the definition of some of my lovelace cards, as follows:
type: custom:popup-card
entity: binary_sensor.zones_alarme
title: Zones
dismissable: true
card:
type: entities
state_color: true
theme: theme1
entities:
- entity: binary_sensor.fumee
icon: mdi:smoke-detector-variant
name: Fumée (dét. panneau)
theme: theme1
- entity: binary_sensor.fumee_zigbee_avec_defaut
name: Fumée escalier (zigbee)
assumed_state: true
theme: theme1
- entity: binary_sensor.fumee_bureau_fumee
name: Fumée salle exercice (wifi)
assumed_state: true
theme: theme1
Unfortunately, my theme1 definitions fail to be enforced.
Your suggestions will be very welcome…
