Needing a second pair of eyes on my I2S/Sendspin player
After the I2S media player was removed, I tried my luck building a new media player for my bedroom with the old I2S amp module (WeAct I2S Speaker V1, PCM5100A + 2 amps) and an ESP32S3N16R8. All seems to work - I don't see any errors in the log, but there's no sound coming out of it. That new media_player - speaker architecture is a little more complicated than the old I2S media player, so I'd appreciate if somebody could take a look at the config and tell me if I missed anything?
# Board: ESP32-S3 DevKitC-1 (Espressif)
# Definition: definitions/boards/esp32-s3-devkitc-1/manifest.yaml
substitutions:
  i2s_lrclk: GPIO09
  i2s_bclk: GPIO10
  spk: GPIO11
  ledpin: GPIO42
  psram: octal
  volmin: 0.4
  volmax: 0.85
  flash: 16mb
  bufsize: 500000
  task: "true"
  bufdur: 100ms
esphome:
  friendly_name: sendspin-bedroom
esp32:
  variant: esp32s3
  flash_size: 8MB
  framework:
    type: esp-idf
    version: recommended
    sdkconfig_options:
      CONFIG_ESP32S3_DATA_CACHE_64KB: "y"
      CONFIG_ESP32S3_DATA_CACHE_LINE_64B: "y"
      CONFIG_ESP32S3_INSTRUCTION_CACHE_32KB: "y"
      CONFIG_SPIRAM_RODATA: "y"
      CONFIG_SPIRAM_FETCH_INSTRUCTIONS: "y"
      CONFIG_BT_ALLOCATION_FROM_SPIRAM_FIRST: "y"
      CONFIG_BT_BLE_DYNAMIC_ENV_MEMORY: "y"
      CONFIG_MBEDTLS_EXTERNAL_MEM_ALLOC: "y"
      CONFIG_MBEDTLS_SSL_PROTO_TLS1_3: "y"
logger:
api:
  encryption:
    key: "xxx"
ota:
  - platform: esphome
status_led:
  pin:
    number: ${ledpin}
    inverted: False
wifi:
  ssid: 'xxx'
  password: 'xxx'
psram:
  mode: ${psram}
  speed: 80MHz
  ignore_not_found: false
globals:
  - id: current_volume
    type: float
    initial_value: '0.2'
  - id: announcement_triggered
    type: bool
    initial_value: 'false'
sendspin:
  task_stack_in_psram: ${task}
 # kalman_process_error: 0.01
i2s_audio:
  - id: i2s_output
    i2s_lrclk_pin:
      number: ${i2s_lrclk}
    i2s_bclk_pin:
      number: ${i2s_bclk}
speaker:
  - platform: i2s_audio
    sample_rate: 44100
    i2s_dout_pin:
      number: ${spk}
    bits_per_sample: 16bit
    dac_type: external
    channel: stereo
    timeout: never
    buffer_duration: ${bufdur}
 # Virtual speakers to combine the announcement and media streams together into one output
  - platform: mixer
    output_speaker: i2s_audio_speaker
    num_channels: 2
   # task_stack_in_psram: ${task}
    source_speakers:
      - id: announcement_mixing_input
        timeout: never
      - id: media_mixing_input
        timeout: never
  # Vritual speakers to resample each pipelines' audio, if necessary, as the mixer speaker requires the same sample rate
  - platform: resampler
    output_speaker: announcement_mixing_input
    sample_rate: 44100
    bits_per_sample: 16
    output_speaker: media_mixing_input
    sample_rate: 44100
    bits_per_sample: 16
media_source:
  - platform: audio_http
    buffer_size: 250000
    buffer_size: ${bufsize}
  - platform: sendspin
media_player:
  - platform: speaker_source
    internal: false
    volume_increment: 0.05
    volume_min: ${volmin}
    volume_max: ${volmax}
    announcement_pipeline:
      format: NONE
      num_channels: 1
      speaker: announcement_resampling_speaker
      sources:
        - http_announcement_source
    media_pipeline:
      format: NONE
      num_channels: 2
      speaker: media_resampling_speaker
      sources:
        - http_media_source
        - sendspin_media_source
    on_state:
      if:
        condition:
          and:
            - lambda: return (!id(announcement_triggered));
            - not:
                media_player.is_announcing: external_media_player
        then:
          - mixer_speaker.apply_ducking:
              decibel_reduction: 0
              duration: 1.0s
switch:
  - platform: restart
  - platform: wifi_signal
    update_interval: 60s
  - platform: rotary_encoder
    min_value: 0
    max_value: 100
    resolution: 4
    publish_initial_value: True
    filters:
      debounce: 30ms
    pin_a:
      number: GPIO15
      inverted: true
      mode:
        input: true
        pullup: true
    pin_b:
      number: GPIO16
      inverted: true
      mode:
        input: true
        pullup: true
binary_sensor:
  - platform: gpio
    filters:
      - delayed_on: 30ms
      - delayed_off: 30ms
    pin:
      number: GPIO17
      inverted: true
      mode:
        input: true
        pullup: true
http_request:
text_sensor:
    type: title
    type: artist
    type: album
I can't spot anything obvious, but it is early in the morning :slight_smile:
Anyhow here are my configs which may give some clues.
Thanks. Yeah, I based my config on one of yours :smiley:
Oh well...
Is it a new esp32 you are using? If so did you short out the 5v out bit and are you getting power to your DAC?
Not much point in my last comment then :slight_smile:
Yeah, it is. Found the problem with my magnifier goggles :smiley:
Ah, not a software problem, a solderware problem!
FYI if you are joining two pads do not just bridge with solder. Solder is crystalline and will crack at some point causing reliability issues.
When joining pads or even repairing tracks ALWAYS embed a piece of fine wire in the solder.
Sure. It's just a prototype. Proper PCB are in the mail :slight_smile:
