Negative houseload
Hello, I shut down my HA server today to build on the server. When I booted it up, I now have negative house power consumption. Resetting to a backup didn’t work. All settings on the Solax inverter seem to be as usual
Is it sunny outside?
Yes, every day
Would it perhaps mean that you’re exporting more power than importing?
Yes, of course I do that with the PV system in the “today export energy” entity. But the entity for the total consumption of the house has recently started showing negative values
Where does this get measured? And if you’re exporting energy to the grid, wouldn’t it make sense that the total consumption of the house will be negative?
My home was also showing negative consumption because it was exporting more than I was using earlier today:
That’s correct, it’s the same for me in the energy dashboard. The entity that shows the total household consumption has been delivering negative values ​​since today
Same started happening to me today. I don’t have a solar system, only consumption for me, yet the total is now going into negative.
