Hi members,
I have a little problem with some zwave nodes in my Home assistant zwave network.
I have 10 Neo Coolcam motions sensors (V2) But for some reason, they were not updating the temperature and the luminance!
I tried to heal the zwave network and did a server restart, but after the restart, the temperature, and luminance meters were on “unavailable”.
I did remove the nodes because the status was:
This entity is currently unavailable and is an orphan to a removed, changed, or dysfunctional integration or device. If the entity is no longer in use, you can clean it up by removing it.
Is there a way to re-add only those entities? From what I am seeing now, is that I have to remove all the nodes and add them again, but then I will lose all of my automation and it will be a lot of work to recreate the automation! the motion sensors on them are still doing fine and show no error at all.
