I can confirm that this works. Both the button and the led.
substitutions:
plug_name: coolcam_plug1
# Higher value gives lower watt readout
current_res: "0.00221"
# Lower value gives lower voltage readout
voltage_div: "800"
esphome:
platform: ESP8266
board: esp8285
wifi:
ssid: 'MySSID'
password: 'MyPassword'
# Enable logging
logger:
# Enable Web server
web_server:
port: 80
# Enable Home Assistant API
api:
ota:
time:
- platform: homeassistant
binary_sensor:
- platform: gpio
pin:
number: GPIO0
inverted: True
on_press:
- switch.toggle: relay
switch:
- platform: gpio
pin: GPIO13
inverted: True
restore_mode: ALWAYS_OFF
- platform: gpio
pin: GPIO14
restore_mode: ALWAYS_ON
on_turn_on:
- switch.turn_on: red_led
on_turn_off:
- switch.turn_off: red_led
- platform: hlw8012
sel_pin:
number: GPIO12
inverted: True
cf_pin: GPIO04
cf1_pin: GPIO05
current_resistor: ${current_res}
voltage_divider: ${voltage_div}
current:
unit_of_measurement: A
voltage:
unit_of_measurement: V
power:
unit_of_measurement: W
change_mode_every: 8
update_interval: 10s
- platform: total_daily_energy
name: "${plug_name}_Total Daily Energy"
power_id: "${plug_name}_Wattage"
filters:
# Multiplication factor from W to kW is 0.001
- multiply: 0.001
unit_of_measurement: kWh
# Extra sensor to keep track of plug uptime
- platform: uptime
name: ${plug_name}_Uptime SensorPreformatted text
